Who's converting to iRule remote control? - Page 9 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #241 of 256 Old 12-06-2011, 05:09 AM
yin
yin's Avatar
Quoted: 23 Post(s)
Hi
has anyone here programmed a RTI xp-8?
yin is online now
post #242 of 256 Old 12-06-2011, 05:13 AM - Thread Starter
thebland's Avatar
Quoted: 1490 Post(s)
Liked: 841
Originally Posted by yin View Post
Hi
Via iRule?? Yes. Requires creating a new remote in ID. As far as I know, you can only control via IR and not use serial commands with the serial cables connected to the XP-8.
I do not know how to have iRUle find the XP-8 on the network and control it completely. Not sure it can be done.
Mark Rubin here is the XP-8 expert. PErhaps he can chime in.
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is online now
post #243 of 256 Old 12-06-2011, 05:39 AM
Super Moderator
markrubin's Avatar
Quoted: 1035 Post(s)
Liked: 2273
I think IR control of the XP-8 is the only option
I think iRule is a great program but the iPanel app from RTI is superb
my opinion only!
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
post #244 of 256 Old 12-08-2011, 09:15 AM
Chrisx510's Avatar
Have you guys seen the iPod Touch remote device from Savant or the iPanel from Crestron? Is it possible to make these hard button add on's work with iRule?
My First Home Theater
300 Blu-Rays, 150 DVD's loaded in my Movie Server!
Thanks AVS for making me addicted to this hobby!
Chrisx510 is offline
post #245 of 256 Old 01-09-2012, 02:30 AM
BladeRnR's Avatar
Mani or Jeff,
Can you please share your panel(s) in iRule that contain Feedback? I believe they were available for a time but they no longer seem to be there. As Jeff suggested earlier it would be quicker if others can see how it was done and reverse engineer it from there for their specific application.
Many thanks indeed
Blade
BladeRnR is offline
post #246 of 256 Old 10-18-2012, 05:14 PM
George7806's Avatar
Has anyone managed to integrate iRule into a Landmark system using the existing systems IR cards serial controllers? Ir there a way to capture the commands that the landmark system using and send it with the iRule? I have quite a few devices etc. to control, so it would be a lot easier to use the existing IR, Serial etc controllers that are part of the original system. Thanks, for any help!
George7806 is offline
post #247 of 256 Old 10-23-2012, 10:57 AM
modernlegends's Avatar
I haven't researched iRule much. However, if iRule has the capacity to create custom device modules, then in theory it should work fine. If iRule can do custom modules, and/or custom serial strings, then I would do the following:
- Create a custom device module in iRule, using distinct serial commands (i.e. button 1 = "btn001", button 2 = "btn002", feedback event = "fdbck001", etc...)
- Create a "GenCombo" device in Landmark. Do this by going to the "Inventory page" in Landmark. Under "equipment types", click the "ADD" button. A dialogue window will appear, then select "Combination", then click next. Give it a identifiable name, and toolbar location (so you can locate it to drag into your project). Click next. Click "Add RS-232", leave the name Serial 232 on popup, then click "Ok". Then click next. You can click "Next" on the bitmap page without assigning one. You'll see a status page "assigning serial rs-232 attributes", then click next. The next page is for your "Commands" (i.e. the strings you'll be sending to iRule). Select the desired baud rate & serial parameters. Enter any command names and associated serial strings here. Click next. The next page is the "Event" page. This is where Landmark looks for incoming serial strings from iRule. Enter event names and associated strings here. Click next, and then click "Finish". You've just created the link between Landmark and iRule.
- Now go to the tab in which you created your "Gencombo" device on the Landmark "Design" page. Drag and drop into the desired room/page. Hit "F5" to spec hardware. This will populate the new GenCombo device onto a RS-232 card in your cardframe view.
- On the "program" page, under the room in which your placed your GenCombo device. Select the device and you will see the "Event" strings for the device you just created. This is where you add the programming. Whenever Landmark Gencombo device sees "feedback event 1", then do XYZ.
- If you need to add more Gencombo commands or feedback events, you can go back to the inventory page, find the device, and click "Edit". Make sure you save your work. smile.gif This is a laborious process, but it should work just fine.
Thanks for the fun memory of creating Landmark Gencombo devices. Brings me back to my days at PHAST/AMX.
Good luck!
Michael
modernlegends is offline
post #248 of 256 Old 10-30-2012, 01:35 AM
Deepsky4565's Avatar
Anyone here use irule with Kindle Fire HD? I'm thinking of switching to this.
Deepsky4565 is offline
post #249 of 256 Old 02-19-2013, 07:31 PM
Peter M's Avatar
Quoted: 162 Post(s)
Liked: 177
Digging up an old thread as I've been fiddling a fair bit with feedback from my Oppo.
Using all the advice above I've got feedback working pretty well but Audio Type seems to have some issues. Based on my testing it seems that some audio types aren't reported correctly. First problem was with SACD passing DSD direct to my processor. The audio type feedback display doesn't change from whatever it was previously. This makes me think that the Oppo either isn't returning any update or is returning a code that isn't in the manual. Playing MLP from DVD-A returns "Unknown" so that's not the problem. DTS encoded CDs do the same thing and most bizarrely so does plain old red book CD.
Is anyone able to test this and confirm ?
Also parsing the feedback using prefix "UAT " and suffix " *" returns just the two letter code for audio type which can be replaced with the full name. Using prefix "UAT * * * " gives the channels ie 2.0, 5.1 etc. So two iRule feedbacks can be used on the same Oppo response to show something like "Dolby True-HD 5.1".
Cheers,
Peter M is offline
post #250 of 256 Old 02-23-2013, 06:14 AM
Bulldogger's Avatar
Quoted: 204 Post(s)
Liked: 46
I had to use Docklight scripting to see exactly what codes were being returned with Irule.
Never become so involved with something that it blinds you.
Bulldogger is offline
post #251 of 256 Old 10-02-2014, 07:08 AM - Thread Starter
thebland's Avatar
Liked: 841
Thumbs up Update
Just wanted to update a post that after originally posting this thread, I switched over my whole theater, and various TVs around the house to iRule after my theater renovation.
I had been using it for a couple TVs but nothing serious.
I put it on my iPhone 6 PLUS and the size seems ideal. My older, smaller iphone was so small, I just didn't like it or use it much. I also have the same program on an old iPad I keep in the theater. I put it also on my phone as it is convenient is it to power on the theater, set lighting, etc without going into the room to do so, like when guests are over or we are finishing up dinner. Very convenient package and so responsive. Also, feedback on most components.
My RTI XP8 control processor and remotes are about to be packaged up and sold. Way more costly, too!!
Here's a few screen shots from my iPhone and iPad (note the 'drawer' pull out on a couple screenshots). Also, SYSTEM POWER ON Macro.
I use one 8-input Port Server and one iTach.
ID:	290929   Click image for larger version
ID:	290937   Click image for larger version
ID:	290945   Click image for larger version
Name:	Screen Shot 2014-10-02 at 9.04.02 AM.jpg
ID:	290953   Click image for larger version
Name:	Screen Shot 2014-10-02 at 10.29.39 AM.png
CINERAMAX likes this.
post #252 of 256 Old 10-02-2014, 09:15 PM
Peter M's Avatar
Quoted: 162 Post(s)
Liked: 177
So Jeff ... you've finally caught up to the rest of us !!
Did Theta do your iRule programming ?!
Cheers,
Peter M is offline
post #253 of 256 Old 10-03-2014, 04:29 AM - Thread Starter
thebland's Avatar
Liked: 841
Cheers,
Ha!! Actually, i had Itai from iRule come over and do initial set up and a basic remote. Now that's service!!! *But he he's a buddy of mine. I've known him far before he started iRule).
post #254 of 256 Old 07-29-2015, 11:03 AM - Thread Starter
thebland's Avatar
Liked: 841
Just made this splash page from an old photo as a reminder to pour a glass of wine before firing up the TV!!
Irule now has native Apple TV support. It's just getting better and better!
Now I'll never forget!
Jeff
post #255 of 256 Old 07-29-2015, 09:43 PM
Peter M's Avatar
Quoted: 162 Post(s)
Liked: 177
You need a reminder ??!!
Must be getting old !
Cheers,
Peter M is offline
post #256 of 256 Old 03-20-2016, 11:02 AM
howieshel's Avatar
Quoted: 82 Post(s)
Hi, Is there anyone out there that offers a service to set up IRule with all of my devices and includes me in on the programming/setup? I just can't get this stuff and don't have the patience for it, I would rather have it all done and i just use it. Thanks
howieshel is offline
