Qualia 004 replacement bulb (LMP-H700) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 05-06-2011, 10:56 AM - Thread Starter
keithbostic's Avatar
Does anybody know of any place to purchase a replacement lamp for a Qualia 004? (It's Sony part #LMP-H700.)
I'm still getting delivery dates from Sony, but after spending some time on the phone with them, I suspect the part is no longer available.
As far as I can tell, the last ship of the Qualia 004 was June 2006, which means Sony supported a $30K projector for less than 5 years.
--keith
keith@bostic.com
keithbostic is offline
post #2 of 10 Old 05-06-2011, 11:17 AM
Glimmie's Avatar
Quoted: 732 Post(s)
Liked: 596
--keith
keith@bostic.com
Keep in mind Japan was devistated with the earthquake and sunami. Even the plants and warehouses that were not directly damaged may still be without power and utilities.
I can tell you getting any parts out of Japan right now is sketchy.
Glimmie is offline
post #3 of 10 Old 05-06-2011, 11:23 AM
thebland's Avatar
Quoted: 1493 Post(s)
Liked: 847
There is a bulb placed that stocked this bulb. Atlas Bulb. It was around $700
Jeff
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is online now
post #4 of 10 Old 05-06-2011, 11:38 AM - Thread Starter
[quote=thebland;20401929]There is a bulb placed that stocked this bulb. Atlas Bulb. It was around $700
You can find the bulb at lots of on-line web sites (for between $2200 and $3000), but nobody stocks a $2500.00 lamp, which means they all re-order it from Sony.
Anyway, I'm looking for "verified sightings", if you will.
post #5 of 10 Old 05-06-2011, 11:49 AM
thebland's Avatar
Liked: 847
I called these guys and they stocked it for about $700 3 years ago. Same bulb but no chassis (keep your current one). Phone: 1-813-238-6481. Verified by me. Likely, they still have it. It was a Cermax 700W Xenon. THe same bulb Sony OEM'd.
At $2200, I'd still say it's not horrible unless you are using your projector for hours per day. I had my Qualia 004 for almost 4 years years and had about 700 hours on the bulb when I sold it. Great machine!
post #6 of 10 Old 05-06-2011, 12:50 PM
thebland's Avatar
Liked: 847
Also, do a search. Someone here did a thread on how to insert the bulb into the chassis. If your bulb is shot, I'd remove it and send it to Atlas bulb to verify things (though they did so over the phone for me) and see if they might insert it into the chassis or have further instructions to do so.
A lot of info here:
http://www.avsforum.com/avs-vb/showt...ht=qualia+bulb
post #7 of 10 Old 12-08-2013, 09:21 AM
audvid's Avatar
Quoted: 348 Post(s)
Liked: 94
I did buy a bulb from Atlas. I kept it in storage and am now going to use it. Hopefully, it would work fine.
I have an email out to them to see what the price is for my spare.
Wondering if there are any other less expensive options for these bulbs.
audvid is online now
post #8 of 10 Old 10-16-2015, 07:49 PM
audvid's Avatar
Quoted: 348 Post(s)
Liked: 94
I was reading this review
http://www.projectorcentral.com/part...inion_id=14106
He writes that the luxtel would have the cermax 700w bulb for my qualia for $500 to $700 range.
Can someone help me find this?
I need a replacement lamp for my Qualia.. It is doing amazingly well..
I have had no trouble with it at all.
post #9 of 10 Old 07-22-2016, 08:50 PM
audvid's Avatar
Quoted: 348 Post(s)
Liked: 94
Here is another thread on the same subject
I am still using my qualia and would want to buy another bulb..
post #10 of 10 Old 07-22-2016, 11:36 PM
KRGM1's Avatar
Quoted: 73 Post(s)
Liked: 32
I think I would upgrade projectors before I spent that for the lamp. I just bought a Qualia for $1500 to trade in on my Sony 5000. It was a beautiful machine with all accessories in original boxes. I could not believe the condition of the projector when my dealer unboxed it for the trade, gorgeous machine, but not worth much.
KRGM1 is offline
