Speakers for new build - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 42 Old 01-20-2012, 03:59 AM
Chrisx510's Avatar
Has anyone heard both Seaton and Genelec? I've been considering Seatons speakers but haven't heard them. I have demoed Genelec and didn't care for them. I preferred B&W over them. Is Genelec similar sounding to Seaton? Meridian is so far my favorite sounding speaker.
My First Home Theater
300 Blu-Rays, 150 DVD's loaded in my Movie Server!
Thanks AVS for making me addicted to this hobby!
Chrisx510 is offline
post #32 of 42 Old 01-20-2012, 08:32 AM
Rick Craig's Avatar
Quoted: 82 Post(s)
Liked: 78
Thanks for your comments on the CBT. I would invite anyone within driving distance of Detroit to come hear some arrays. We'll be at the AK Fest in Novi,MI April 28/29.
Originally Posted by Kishore View Post
If you want to venture into something new/cool, I highly recommend Don Keele's CBT Line Array speakers Link I have not heard them but it is easy to grasp their objectives we chase for getting better directivity/coverage in larger setting.
Monte Kay's project/center speaker pic is below
Rick Craig from Selah Audio can custom build for you.
Kishore
Selah Audio
Thinking Inside the Box...
Rick Craig is offline
post #33 of 42 Old 01-20-2012, 08:36 AM
FOH
FOH's Avatar
Quoted: 39 Post(s)
Liked: 236
I've heard both, however not extensively enough to give a full comparative opinion. That said, I'm familiar with the thoughts of others that have, and the differences existed in the area of subjective smoothness, and listen-ability with no apparent listening fatigue,...all positive traits of the Seaton Catalyst and those comments were in comparison to the Genelec.
I'd not consider these findings surprising either, as a studio monitor and a high-output, low-distortion HT main have entirely different tasks and environments in which they need to excel. Then, considering the value of the Seaton, I find it a very attractive option. A fully active 3-way 2kw, DSP optimized, coaxial compression HF/MF with freedom from off axis lobing effects, and perhaps the finest mid-bass section in existence, the Catalyst is quite the offering.
Genelec also has an active, three-way coaxial at almost twice the price. However it's output capability isn't geared toward HT, with ~150watts per driver. Their bigger, more powerful monitors like their 1038 is more comparable wrt to output with the Seaton, however it's a bit expensive. Sure, there's other very important elements aside from low distortion, high output capability, but I'm confident the Seaton Catalyst would be viewed very favorably up against comparably priced Genelec offerings.
Good luck
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #34 of 42 Old 01-20-2012, 11:21 AM
zamboniman's Avatar
With the outlined budget... Seaton is the top choice.
zamboniman is offline
post #35 of 42 Old 01-20-2012, 02:18 PM
mani's Avatar
Quoted: 65 Post(s)
I f you are on budget , Seaton's will be hard to beat for HT.
I dont think Genelec's output is any lessthan Seatons. I have owned both.
Genelec lists their max SPL for one speaker and for a pair at 1 and 1.7 mt. If you got upto 1034 and 1039 , the output is upward of 130dB. Seaton doesnt list the max SPL in typical room, so its hard to say one has more output than other.
mani is online now
post #36 of 42 Old 01-21-2012, 02:20 AM
Chrisx510's Avatar
Good luck
I do have my heart set on the Catalyst. Genelecs were just to bright for my ears.
It would be nice if Seaton made some type of Dipole surrounds. Their sparks are just to big for surrounds for my room. I might look at using another brand for surrounds as I have seen many others do that with their Catalyst.
post #37 of 42 Old 01-21-2012, 08:52 AM
SierraMikeBravo's Avatar
Quoted: 349 Post(s)
Liked: 222
Originally Posted by jayhawk913 View Post
Starting a new theater with a budget of 75-100K or so...
Need speaker recommendations from folks who have actually heard some higher end products. Will take a listen when I narrow my choices.
First choice would be Procella... but kinda pricey.
I've read about JTR, Seaton, Danley... Will probably drop 10-15 k for the LCR and surround speakers (6). Any other recommendations in this price range for speakers that would meet THX certification.
Not interested in the common players PSB, Klipsch, JBL, AT, Snell, Polk, B&W ect... Looking for gear that is great for HT that I may not have run across in local shops.
Hawk
I am sure we can arrange a full Procella setup demo for you if you are in the Kansas area...by your handle I assume you are...if you are interested.
Shawn Byrne
CEDIA Certified Professional EST II - HAA, THX.
Theater Design Information and Examples
skbyrne@sbcglobal.net
shawn@questai.com
SierraMikeBravo is offline
post #38 of 42 Old 01-24-2012, 08:06 PM
TedO's Avatar
Quoted: 26 Post(s)
Liked: 27
In this price range, I would look into a matching set of 5 VMPS RM40s (LRC & surrounds) along with a couple of good subs.
TedO is offline
post #39 of 42 Old 01-25-2012, 05:40 AM
Bulldogger's Avatar
Quoted: 236 Post(s)
Liked: 55
Originally Posted by mani View Post
Very uniformed and misleading statement. I have auditioned two very nicely done theaters with CAT's and they are second to none for HT . If I go with passive speakers , they will be on top of my list if I can afford their higher end setups. Depending how much of the services you can afford , they can completely customize the audio install for you. They can make the baffles/walls and install multiple drivers in the baffle (so there is no cabinet) and custom make /tune crossovers for your room etc etc .Obviously that kind of install will be north of 100-200K I believe. They are the most dynamic passive speakers I have heard. I have owned B&w's, Paradigms, Kef's , Genelc's, Seatons etc. Even for music they are second to none. The theater I auditioned was setup by CAT engineers and tuned by them . I believe it had either 8 or 12 subs. I don't know if you just buy three of their entry level speakers from net and put them in
Second recommendation for the CAT. Set-up featuring that brand in a specially built room remains the best surround sound I have heard.
Never become so involved with something that it blinds you.
Bulldogger is offline
post #40 of 42 Old 01-25-2012, 07:44 AM
Bulldogger's Avatar
Quoted: 236 Post(s)
Liked: 55
Kishore
Those do look cool! Selah Audio is a place I would like to visit.
post #41 of 42 Old 01-25-2012, 07:53 AM
Mike Garrett's Avatar
Quoted: 7073 Post(s)
Liked: 4779
If you do not like the sound of the Genelec, then you might want to listen to Triad Platinum's. One of the few speakers out there that use soft domes, but can do the dynamics required for HT.
mjgarrett100@gmail.com
Mike Garrett is offline
post #42 of 42 Old 01-28-2012, 08:23 AM - Thread Starter
jayhawk913's Avatar
What dipoles are folks using with the seatons?
Also anyone use a HT designer other than those that are popular on the forum and feel that they did superior work?
Hawk
jayhawk913 is offline
