Lens Memory - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-19-2012, 05:53 PM - Thread Starter
David Shapiro's Avatar
Quoted: 66 Post(s)
Which projectors have lens memory? I'm getting intrigued by the thought of a 12 foot wide 2.0 aspect screen, to shift between a 12 foot scope screen and a 10 ft. wide 16:9 screen. This was suggested to me by Dan Francis a couple of days ago.
David Shapiro
DES
David Shapiro is online now
post #2 of 10 Old 02-20-2012, 05:46 PM
noah katz's Avatar
Quoted: 887 Post(s)
Liked: 305
You could also do it electronically with a VP like Lumagen, which also gives you the option of always filling the screen with a bit of stretching and/or cropping
Noah
noah katz is online now
post #3 of 10 Old 02-20-2012, 08:54 PM - Thread Starter
Quoted: 66 Post(s)
I have a Lumagen Radiance XE. So. I could have the Lumagen toggle between a 144" wide scope view, and a 120" wide 16:9 view? I'm asking since I'm processor challenged.
David
DES
post #4 of 10 Old 02-20-2012, 10:05 PM
noah katz's Avatar
Quoted: 887 Post(s)
Liked: 305
yep
don't ask me how, but I know that they can do it
Noah
post #5 of 10 Old 02-21-2012, 04:26 AM
DanFrancis's Avatar
Quoted: 44 Post(s)
Liked: 42
You would lose resolution in the 1.78 frame in this case (using the lumagen to digitally zoom the image). It would require adjusting the image of the Highlite to fill the 12 foot wide screen; then crop down the image to 1.78 aspect digitally- the projector is still zoomed out optically, the only way to make the image smaller is to reduce resolution because the Highlite does not have lens memory.
The Titan chasis, I'm guessing Christie chasis, probably the Projection Design (Avielo) Helios chasis, Barco, NEC DCI, and the more expensive Runcos should have the ability to zoom in and zoom out via lens presets. I know for sure the Titan and Barco projectors do.
Dan
Dan Francis
DanFrancis is offline
post #6 of 10 Old 02-23-2012, 07:41 PM
rabident's Avatar
Quoted: 340 Post(s)
Liked: 110
It's trickled down to the new Sony and JVC projectors too.
rabident is offline
post #7 of 10 Old 02-24-2012, 09:11 AM - Thread Starter
Quoted: 66 Post(s)
Which Sony's?
David
DES
post #8 of 10 Old 02-24-2012, 09:27 AM
Brad Horstkotte's Avatar
Liked: 68
I ended up with something similar to what you're thinking about - in my case a 2.125:1 aspect screen, 136" wide, 64" high, using a JVC RS-20. With the blu-ray player, I manually zoom when necessary. But since I got my HTPC in place, running XBMC, I can now set up the XBMC dashboard to fill the screen, 2.35:1 titles use the full width, and 16:9 titles use the full height, using XBMC's scaling. I lose some resolution for 16:9 - but I don't watch many of them, and in cases where it matters a lot to me to have best PQ for a 16:9 title - say Avatar - I can always switch out of that mode (re-adjust the zoom and turn off scaling, or switch to a BD).
Brad Horstkotte is offline
post #9 of 10 Old 02-24-2012, 06:53 PM
mookie b's Avatar
Quoted: 17 Post(s)
Liked: 26
Originally Posted by David Shapiro View Post
Which Sony's?
David
VPL-VW95ES and VPL-VW1000ES
mookie b is offline
post #10 of 10 Old 02-24-2012, 07:35 PM
donaldk's Avatar
Quoted: 419 Post(s)
Liked: 93
And the Panasonic 1080P 3LCD projectors.
donaldk is offline
