Low Frequency Definition? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 03-10-2012, 10:51 AM - Thread Starter
mikesorensen06's Avatar
What is the frequency range, from lowest to highest for the phrase "low frequency"?
Cheers,
Mike
mikesorensen06 is offline
post #2 of 14 Old 03-10-2012, 12:06 PM
Bigus's Avatar
Quoted: 397 Post(s)
Liked: 385
19.7 Hz to 63.39 Hz.
Bigus is offline
post #3 of 14 Old 03-10-2012, 05:09 PM
fastl's Avatar
Quoted: 22 Post(s)
I don't think there is any exact frequency range that falls into the "low frequency" category, since that is descriptive terminology. Are you trying to define this frequency range for any particular purpose?
fastl is offline
post #4 of 14 Old 03-10-2012, 05:47 PM
Glimmie's Avatar
Quoted: 760 Post(s)
Liked: 632
Depends who you ask.
I say it is anything below 1ghz
Glimmie is offline
post #5 of 14 Old 03-10-2012, 06:12 PM
rovingtravler's Avatar
lol
true and there is no low end maybe a top of low but the military uses ultra low freq radio for underwater radio transmission.
David
"You buy a Ferrari when you want to be somebody. You buy a Lamborghini when you are somebody." - Frank Sinatra
rovingtravler is offline
post #6 of 14 Old 03-10-2012, 09:39 PM
Bigus's Avatar
Quoted: 397 Post(s)
Liked: 385
Not true, I gave the range above. It is valid for any definition of low frequency for any use, anywhere, at all times.
Bigus is offline
post #7 of 14 Old 03-10-2012, 11:24 PM
bigbrother52's Avatar
That is a pretty bold and broad statement!
Although I have seen that definition before, "for any use, anywhere, at all times" cannot apply.
For instance, many will define the range of "audible" sound as differentiated into 3 main categories.
1. Subsonic or "low frequency" sound being in the range of 20Hz to about 500Hz.
2. Midrange frequencies are said to inhabit the realm of 500Hz to 6KHz (6000Hz)with
3. high frequency sound being in the 6KHz to 20KHz range.
Then again, if you were talking "radio" freq., the definition would be
ELF Extremely Low Frequency 3 - 30 Hz
SLF Super Low Frequency 30 - 300 Hz
ULF Ultra Low Frequency 300 - 3000 Hz and
VLF Very Low Frequency 3 - 30 kHz
There are other examples as well.
So it really depends on how the term low freq. is being used, and often, who it is that defines it.
Saying "for any use, anywhere, at all times" simply does not work.
TURN IT UP!
bigbrother52 is offline
post #8 of 14 Old 03-11-2012, 09:46 AM
Bigus's Avatar
Quoted: 397 Post(s)
Liked: 385
Erm, I thought the sarcasm was obvious. The question isn't even answerable. First, it isn't made clear whether we are talking about sound or photons, and then we don't know the application in mind, from navy sonar to CT scanners.
But if we assume that the question was directed at home audio, then we can quickly agree it still isn't answerable as there is no standard definition.
BTW, subsonic does by definition mean that which is below our limit of hearing, thus even your attempt at a definition might need to be adjusted a bit.
Bigus is offline
post #9 of 14 Old 03-11-2012, 10:50 AM
Sorry, your posts seemed so emphatic that the sarcasm was not obvious to me at all
My own posted definition was not meant to be "thee" definitive answer to the question, it just seemed like something reasonable to say because I just could not read your statement and let it stand unchallenged, even if it was the middle of the night!
How can you even tackle a word like subsonic when most subwoofers on the market barely go down to 20hz?
I suppose we can all agree that descriptive words in audio are for the most part disam-Bigus at best.
TURN IT UP!
post #10 of 14 Old 03-11-2012, 02:23 PM
noah katz's Avatar
Quoted: 1032 Post(s)
Liked: 366
Actually subsonic is less than the speed of sound; I believe infrasonic is the correct term.
Noah
noah katz is offline
post #11 of 14 Old 03-11-2012, 03:08 PM
Bigus's Avatar
Quoted: 397 Post(s)
Liked: 385
Doh! The foot is nearing...
Bigus is offline
post #12 of 14 Old 03-11-2012, 05:08 PM
fastl's Avatar
Quoted: 22 Post(s)
The OP doesn't seem to be responding, so it's anyone guess as to why he asked the question? The latest research into the psychoacoustics of low frequency sound perception indicates that the 1st critical band actually runs all the way from 20 Hz up to 100 Hz, so I guess you could say that anything below 100 Hz could be considered as "low frequency".
fastl is offline
post #13 of 14 Old 03-11-2012, 10:23 PM
I now recall reading a short thread he started a couple of months back about quadratic diffusion in our rooms.
One would hope that the guy who started that thread should already have a pretty good handle on what range could be considered low frequency.
TURN IT UP!
post #14 of 14 Old 03-11-2012, 10:50 PM
gamelover360's Avatar
Quoted: 14 Post(s)
Cheers,
Mike
You may also think of 20hz-80hz as low frequency as well in a very practical sense, as that is the general frequency range that most people have their subwoofer operating.
gamelover360 is offline
