Multiple Sub Woofers - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 65 Old 04-18-2012, 07:11 PM
scanido's Avatar
Quoted: 99 Post(s)
Liked: 35
Originally Posted by Talk2Me View Post
Are you referring to my post?
http://mehlau.net/audio/multisub_geddes/
No, but thanks for that informative link.
See Profile
scanido is offline
post #62 of 65 Old 04-19-2012, 01:10 PM
lymzy's Avatar
Is room shape and treatment still important for four sub setup?
HDPLEX
lymzy is offline
post #63 of 65 Old 04-19-2012, 02:06 PM
sdurani's Avatar
Quoted: 5135 Post(s)
Liked: 3614
Sure, because bass isn't limited to the subwoofer region, where you have the luxury of using multiple mono signals AND moving tranducers around the room to improve results. That flexibility isn't an option above the crossover point, so how do you address bass problems above, say, 70/80/90 Hz? You're not going to destroy the front soundstage or surround field by moving your speakers to optimal low frequency locations in the room. So this is where room shape and treatments remain useful. What you can't accomplish with room design and bass trapping can then be address with EQ as the finishing touch.
Sanjay
sdurani is online now
post #64 of 65 Old 04-23-2012, 09:57 AM
Rod#S's Avatar
Quoted: 387 Post(s)
Liked: 55
Originally Posted by audvid View Post
My processor is Lexicon MC 12 and it has L, R and C sub out with individual cross over.
Just a quick correction to that statement, the Lexicon MC-12 has a Left and Right mono sub out which can be combined to run in stereo plus a dedicated LFE out. You are correct that it has 3 outputs but it doesn't have a center sub out, that's the LFE output and it only carries the .1 signal if it exsists in the source. If there is no .1 in the signal the LFE output is silent.
Rod#S is offline
post #65 of 65 Old 04-23-2012, 12:56 PM
NIN74's Avatar
Yes, I have 4 right now, thinking about getting 2 or 4 more. I would never ever use just one subwoofer in my system.
Sound and video is not magic, it is pure physics. Physics that can be magical
NIN74 is offline
