Interesting read on 2K, 4K - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-01-2012, 05:44 AM - Thread Starter
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 101
Many of you will have your arms around this already; but, for those jumping into the 4K world, this is a worthwhile read.
http://magazine.creativecow.net/arti...ture-of-pixels
Also, "Home Theater Video Design" best practices document (CEA/CEDIA-DEB23-A) is now available at www.CE.org
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Board of Directors
www.erskine-group.com
Dennis Erskine is offline
post #2 of 6 Old 06-01-2012, 09:49 AM
Andrikos's Avatar
Great read!
Even though it's 3 years old it's amazing how relevant all the info still is.
Who knew that a 4k print was actually a 38MP picture!
Next projector will have LEDs, >=1080 res, >=10 bit color, >14bit CR, >9 bit ANSI CR, >=120Hz, >16ft.L on 12ft 2.35:1 screen, <$12bit price
My 1st line array design
My ongoing Line Array Design
Andrikos is offline
post #3 of 6 Old 06-01-2012, 11:17 AM
noah katz's Avatar
Quoted: 882 Post(s)
Liked: 304
I started to read but stopped; does counting as 3 pixels the R/G/B subpixels needed to make one "real" pixel have any relevance these days?
I don't see any of the mfgr's of 3-chip displays tripling their res spec's like some of them used to back n the day.
Noah
noah katz is offline
post #4 of 6 Old 06-03-2012, 05:00 PM
Joelc's Avatar
Dennis, thanks for the article, enjoyed reading it...
Dennis or others, being less technical than some here let me see whether or not I can summarize some of the key points:
1. 4K with a lower frame rate will produce a softer image than 2K with higher frame rates...in other words, we would be better off focusing on higher frame rates over a higher pixel count.
2. 4K (with a given frame rate) will not generate a noticeable better image than 2K (with the same frame rate) unless one sits closer which, the author argues, likely is not going to happen.
3. 4K (with a given frame rate) will not generate a noticeable better image than 2K (with the same frame) even were one to sit closer unless the lens and other components are up to the task.
The point being that one needs to think through much more simply the pixel density before considering a change.
With that the follow up items I am interested in are:
1. Is my understanding correct?
2. How does one determine whether the move from 2K to 4K is warranted based on the other components because unlike Panavision, there is little opportunity to do a side by side comparison or, better yet, even rent projectors for evaluation.
TIA...
Joel
Some people choose to have a pool, I choose to have a home theater!
Joelc is offline
post #5 of 6 Old 06-03-2012, 06:40 PM
Art Sonneborn's Avatar
Quoted: 238 Post(s)
Liked: 295
If you sit at or near the SMPTE minimum viewing distance pixels are visible at focused 2K . This may not be where you sit or something you care about but fact none the less.
Art
My HT
iRule rules my theater
Art Sonneborn is offline
post #6 of 6 Old 06-04-2012, 02:04 AM
Andrikos's Avatar
I think that regarding optimal resolution we still have a long way to go, but that also applies to color-depth, DR and CR of projectors.
I'm sure in 10 years we'll look back and smirk at the "primitive projectors" of the 2010s.
Andrikos is offline
