The Official Quested LT Series Thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 41Likes
post #91 of 356 Old 12-17-2013, 05:10 PM
LJG
LJG's Avatar
Quoted: 471 Post(s)
Liked: 234
Originally Posted by CINERAMAX View Post
Hi Lon these speakers can be ordered vertical for lcr functionality, it is not a matter of just flipping them sideways I want the tweeter center aligned to the woofer.
Peter:
I am sorry but I still don't get it, wouldn't the tweeter still be center aligned to the woofer if you flipped a horizontal speaker vertical or a vertical speaker horizontal?
LJG is online now
post #92 of 356 Old 12-17-2013, 09:57 PM
3D Audio Consultant
Curt_Trinnov's Avatar
Quoted: 72 Post(s)
Liked: 120
Originally Posted by LJG View Post
Peter:
Yes, the tweeter would remain center aligned as you suggest,  but it's dispersion pattern is dependent on orientation.  Notice in the pic the ribbon runs vertically-  that would be the ideal orientation,  thus providing better side to side dispersion, with more limited vertical dispersion.  Accordingly, this speaker requires horizontal placement for best ribbon dispersion.  Rotating this cabinet vertically would collapse the tweeter's side to side dispersion as frequency rises.  The LT-10 may be specified for horizontal or vertical orientation, the change being the ribbon alignment.
Cheers,
___________
Curt Hoyt
3D Audio Consultant
Trinnov Audio
USA
Curt_Trinnov is offline
post #93 of 356 Old 12-18-2013, 03:52 AM
thebland's Avatar
Quoted: 1676 Post(s)
Liked: 1011
Originally Posted by Glimmie View Post
I think you could also timbre match dissimilar heights to the mains especially within the same speaker family? Does the Trinnov offer full independent EQ of each speaker output?
This may be a non starter for me unless I can come up with another solution. I don't believe Quested has anything the sized of a LT-8 that will give the output needed. From the screen to my prime seat is about16-18 ft (5-6 meters). I know Lon had trouble matching the ribbons to his speakers. Hmm...
Goodbye to a great audio and video genius and writer... JOHN GANNON. I enjoyed your friendship, wit and a nice long run we took around Indianapolis at CEDIA years back... and for buying my Runco 980 Ultra years back... you saved my ass! Rest in peace.
thebland is online now
post #94 of 356 Old 12-18-2013, 05:39 AM
b curry's Avatar
Quoted: 477 Post(s)
Liked: 278
What is actually changed in the Quested speaker to orient it for horizontal vs vertical placement? The LT8's will be sent tomorrow to Curt for evaluation.
I understood that the baffle board the AMT is mounted on unscrews and rotates to accommodate horizontal - vertical alignment.  This would position the AMT to the side of the woofer for vertical alignment but the left and right could be mirror imaged; not so bad.
So Peter, you're saying you can custom order the AMT mounted on the same axis as the woofer cone for vertical alignment?  If this is the case, what happens to the port placement; two smaller ports?
b curry is online now
post #95 of 356 Old 12-18-2013, 06:04 AM - Thread Starter
CINERAMAX's Avatar
Quoted: 2273 Post(s)
Liked: 1296
Send a message via Skype™ to CINERAMAX
Jeff, If you find any dimensions that need massaging to fit your setup pass it on and I'll send it up the pole. Roger is very quick at customizing these boxes.
In response to B Curry:
I believe so unless he makes the cabinet taller. But for LCR I think the AMT needs to be aligned with the woofer.
Actually Roger did a custom design for me of a new LT-18 LCR using the big bad 18 Volts that I think my have a leg up on the lt-20 and again the drivers are vertically aligned.
I am thinking of replacing the LCR at SKOLL which currently have 2215 pro with these then use LT-10s for the heights.
CINERAMAX is offline
post #96 of 356 Old 12-18-2013, 06:05 AM
b curry's Avatar
Quoted: 477 Post(s)
Liked: 278
Jeff you might want to take a look at these:  http://www.adam-audio.com/en/installation/products
The GTC 55 is about the same size as the LT-8 and has an AMT tweeter.  The GTC 88 is very similar to the LT-10 in spec'd SPL and sensitivity.  Of course you don't get Roger Questeds pedigree but the components appear to be of similar quality.  The AMT units in the all GTC's can be reconfigured for vertical or horizontal placement.
post #97 of 356 Old 12-18-2013, 06:14 AM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
Crap, I don't even know if I have the room t for 5 LT10s up front! I'm going to test the LT8s behind the screen and see how they come up. I was planning on LT10s for LCRs but my space is very limited up high behind the screen as the ceiling slopes downward and there is a lot of baffle wall bracing up high (and low).... We'll see!
I am asking now for a low profile lt-10 horizontal using two woofers. let you know what transpires.
post #98 of 356 Old 12-18-2013, 06:46 AM
LJG
LJG's Avatar
Quoted: 471 Post(s)
Liked: 234
Jeff:
If you are replacing all your speakers with Quested the Timbre matching should not present a problem. Bottom line for me was the Aerials sounded very different then the LT8's even after equilization and the Trinnov full calibration, and this was on axis in the sweet spot.
LJG is online now
post #99 of 356 Old 12-18-2013, 06:52 AM
b curry's Avatar
Quoted: 477 Post(s)
Liked: 278
Thanks Peter, very cool...
I see the benefit of time alignment, maybe not so much for absolute alignment to the woofer cone.  As you pointed out the LT-20 sort of shoots a hole in the idea and maybe that's why the LT-18 gets a leg up.  It's really great that Roger is so responsive to customizing the boxes.
My experience with AMT's have been mostly dipole arrangements which present a different sort of problem.
For me the the mention of an AMT driver brings to mind the ESS marketing phrase "Sound as clear as light"; an elegant and ubiquitous statement as to what an AMT driver can do for the enjoyment of audio.  I hope someday to have the good fortune to see one of your projects with the Quested units.  Thanks for the info Peter and keep posting your progress.
post #100 of 356 Old 12-18-2013, 08:29 AM
thebland's Avatar
Liked: 1011
Peter,
I'd like an LT-8 / LT-8 Surround sized box with an LT-10 'air motion' tweeter'. Depth and height are critical.
Possible?
post #101 of 356 Old 12-18-2013, 08:54 AM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
It was already in the works 2 x 5's and a amt, that means depth and height WILL BE MUCH LESS. I've requested drawing, maybe tomorrow.
post #102 of 356 Old 12-18-2013, 01:51 PM
sierraalphahotel's Avatar
Please excuse my ignorance, but do you suppose that Quested could offer a smaller 3-way active unit? Like a miniature LT-20 type of thing?
Cheers,
Sean
sierraalphahotel is offline
post #103 of 356 Old 12-18-2013, 02:03 PM
thebland's Avatar
Liked: 1011
Perfect. The last hurdle.
post #104 of 356 Old 12-18-2013, 03:18 PM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
Cheers,
Sean
Hi Sean,YES YES! In fact to go out the door January it has to be active, passive will take longer to develop proper x-over which he is finicky about getting to sound right.
post #105 of 356 Old 12-18-2013, 03:21 PM
Wow, that's exciting news! Thanks, Peter!
post #106 of 356 Old 12-19-2013, 06:40 PM
Nyal Mellor's Avatar
Quoted: 462 Post(s)
Liked: 342
Jeff:
Failure to timbre match via EQ would indicate different off axis radiation patterns (directivity) between the two speakers.
EQ can only go so far, and if you are EQing then what do you EQing...the on axis? the early reflections? the late reflections? You only have one EQ control and it applies to all angles of speaker radiation.
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is offline
post #107 of 356 Old 12-26-2013, 09:34 AM
b curry's Avatar
Quoted: 477 Post(s)
Liked: 278
Peter, would the one you speak of above be in addition to the LT24?
Also Peter, I believe the  LT10 is using a Volt woofer; do you know, is it using a Beyma AMT unit?
post #108 of 356 Old 01-01-2014, 10:26 PM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
Yes, although I have been asked not to post details. Not sure about woofer but yes to AMT.
post #109 of 356 Old 01-05-2014, 08:04 AM
b curry's Avatar
Quoted: 477 Post(s)
Liked: 278
Thank you Peter.  Looking forward to the details when they become available.
post #110 of 356 Old 01-15-2014, 10:34 PM
Bassfeen's Avatar
Quoted: 113 Post(s)
How do the Quested Amplifier Sound? Which ones would you recommend for the LT20s?
Bassfeen is offline
post #111 of 356 Old 01-16-2014, 11:07 AM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
Hi Basfeen,
They sound great better than more fuller sounding than Bryston, Ada, warm but very fast. Perhaps better than the ML we used at Prometheus. They do have a fan that kicks in so your rack has to be isolated.
Norman here compared them to tubes. They are made by a company pro company Mc2 that has excellent pedigree. Only amp that I am familiar is way more expensive: D'agostino. smile.gif
This is the rack as we did it:
the lt-20's used the ap-950 for mids and highs and the ap-2800-4 for the bass and sub bass.
post #112 of 356 Old 01-16-2014, 09:02 PM
Bassfeen's Avatar
Quoted: 113 Post(s)
I am familiar with MC2 Amplifier I picked up there older MC1250 over 2 years ago but never really played around with it just left it in the store room till over a month ago when I compared them to the ATI amplifiers.
Bassfeen is offline
post #113 of 356 Old 01-19-2014, 03:35 AM
Elill's Avatar
Quoted: 109 Post(s)
Liked: 91
Perhaps I have missed it, but does Quested publish measurement data for the speakers? importantly radiation and off axis?
Peter the Greek
Downunder Theatre MkII
List of Pro Designers
Elill is offline
post #114 of 356 Old 01-20-2014, 09:55 PM
Bassfeen's Avatar
Quoted: 113 Post(s)
Hi Basfeen,
Would a Single AP1550 be sufficient for a Single LT20 using one channel for the Lower Bass and the second channel to power up the Mids and Tweeter? Essentially using 3 Dedicated amps for the Front LCR?
Bassfeen is offline
post #115 of 356 Old 01-23-2014, 05:48 PM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
HI Bassfeen,
I believe so as there is a mid high passive crossover option that we were considering.
post #116 of 356 Old 09-05-2014, 02:55 PM
thxman's Avatar
Quoted: 643 Post(s)
Liked: 678
I don't understand why these speakers don't have more traction on this site. I see a lot of folks in this price range with other companies, some with far less of a "pro" reputation. Honestly, I never looked because I just assume these speakers were in the $25K+ each range.
thxman is online now
post #117 of 356 Old 09-05-2014, 03:59 PM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
Well Jeff here is a trend setter and no one influenced his decision, in 2 weeks he is more power user on datasat than ill ever be, I just set it up where he fields questions straight to the top engineer now. As he has a lot of gatherings it will catch no doubt.
I am system agnostic but after being given unlimited budgets by my last 5 Saturn Moons, it's hard to find better for the app. at 5 times price too. Of course the 34 channel d'agostino/raidho with 10 inch diamond woofers (zero Compression at high spl's) still gives me chills to envision but being less than a mile from mr. bad boy himself Putin, not holding my breath for that one to go down any time soon.
For quested the build threads are fascinating My homies here get special treatment from Roger, over every other channel im told.
So now the lt-8 comes with high power amt single passive or two way (there are three dispersion patterns being studied). so it can be used for main channels too.
LT8iS AMT Passive
2-way, active-drive speaker, 8", binding posts
$3,350.00 you could easily do a 5.1 for 15 grand with these.
thxman likes this.
post #118 of 356 Old 09-05-2014, 04:05 PM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
Since Meyer acheron is considered Atmos Studio Premier the Quested line compares better with the more compact models matching the next size up in meyers acheron. Get it? Ollie is making very detailed spec sheets following their presentation format, Im waiting to give to the atmos brass myself. There is no contest horns need to go....
post #119 of 356 Old 09-05-2014, 10:06 PM
Elill's Avatar
Quoted: 109 Post(s)
Liked: 91
No arguments there, I was sold on AMT's 3-4 years ago. I just want to see the data on the LT series. I am amazed people are buying them without seeing it. Unless of course it is available?
Peter the Greek
Elill is offline
post #120 of 356 Old 09-06-2014, 12:00 AM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
http://www.meyersound.com/products/e...eron_designer/
expect similar spec sheets.
To be honest specs I read after I like what I hear.transient response is not well represented in grphics, and that is the ticket.
