Heat load of HT equipment - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 07-11-2012, 12:52 PM - Thread Starter
rabident's Avatar
Quoted: 337 Post(s)
Liked: 110
How much cooling is needed for a reasonably large HT?
rabident is offline
post #2 of 12 Old 07-19-2012, 02:30 PM
Peter Nielsen's Avatar
One important thing to consider is a large number of registers (vents) and big diameter duct. The goal is to be able to move a large amount of air at low speed in order to reduce AC noise. (Too few vents and/or too small ducts causes a more rapid movement of air and as a result more noise). You will probably also want an AC return in the HT.
The 24x16x8' bonus room that now is my HT originally only had one single 12x4" vent and no return. The air conditioning was very noisy as a result. After upgrading the ductwork and installing 4 additional 10x4" vents, the AC is now quiet and not disturbingly noisy as it used to be.
Peter Nielsen is offline
post #3 of 12 Old 07-21-2012, 07:34 PM
PRETERNATURAL IMMERSOPHIL
CINERAMAX's Avatar
Quoted: 1696 Post(s)
Liked: 931
Send a message via Skype™ to CINERAMAX
I am struggling with heat loads for this systems.
Sincerely, GC*
rAVe Best ATMOS DEMO CEDIA 2016. HOARDS AWARDS, ACCOLADES, 1ST ART CREDS.,WLD. RECORDS, & HI PERFORMANCE 16-24-32-48 CH. MIDI-PLF CINEMAS WW. - CUSTODIAN HIGH END IMMERSIVE CINEMAS TO SMPTE & ADV. IMAGING SOC. HELP Combat Channel Insufficiency with Altitude 48!*GC = GANGSTA C. genus: cineramus maximus. GC Twitter (Now staging Humanitarian Relief Aide to Great Bel-Air Circuit B-chain & 6P/HDR Projection Famine of 2017)
CINERAMAX is offline
post #4 of 12 Old 08-07-2012, 11:03 PM
Frosteh's Avatar
Are you wondering about the interior space where people sit, or the equipment room/racks? If it's the people space, just have an AC installer come give you a quote because they'll know exactly how to cool your room. If it's the equipment racks, it's not so much an issue of the ambient temperature as it is moving the air away from the individual components. When I stack servers, I put no more than two atop another at a time, and even that pushes it sometimes. If the equipment doesn't have an internal fan (only heatsinks) don't put anything on top of it and draw as much heat away as you can with external fans. To cool servers I've had good success with something as simple as putting a box fan behind the components to draw heat away. Then the cooling system of the room takes care of the heat once it's away from the components.
Frosteh is offline
post #5 of 12 Old 08-08-2012, 12:15 PM
Not all AC installers take noise into account! Remember to tell them that the AC has to be silent, otherwise they may quote you for the most cost effective solution that does the job, and you may have to redo it because it ends up too noisy... cool.gif
post #6 of 12 Old 08-11-2012, 01:30 PM
Glimmie's Avatar
Quoted: 732 Post(s)
Liked: 596
In the class you deal with Peter, don't you have a dedicated equipment room / booth? And that looks like power amps and audio processors. That stuff is usually set and forget and has some form of remote control via ethernet. Couldn't you put that gear just about anywhere keeping speaker cable distances in mind?
Glimmie is offline
post #7 of 12 Old 08-12-2012, 06:22 PM
mmiles's Avatar
Quoted: 467 Post(s)
Liked: 214
Look at that rack how can you not love this guy?
Mike Miles
mmiles is offline
post #8 of 12 Old 08-12-2012, 10:01 PM - Thread Starter
rabident's Avatar
Quoted: 337 Post(s)
Liked: 110
It's new construction. I had to build a new house to get the theater I wanted. I've been focused on the room itself and haven't picked my equipment yet. HVAC company did their calcs for space/people, then asked for the btu's of my equipment. My room is similar in size to many here, assuming it will be filled with similar gear, so I was looking for a rough estimate.
I brought Dennis back in for some design changes and hopefully to do the build. He was able to supply my HVAC contractor with some numbers & guidelines.
rabident is offline
post #9 of 12 Old 08-13-2012, 07:17 AM
Super Moderator
markrubin's Avatar
Quoted: 1044 Post(s)
Liked: 2297
agreed this is the biggest issue aside from oversizing the HVAC for equipment heat loads
I think Dennis would specify a lower HVAC air flow (in terms of FPM) to address the noise issue: this makes the ducting and HVAC installation more expensive
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
post #10 of 12 Old 08-17-2012, 05:38 AM
CINERAMAX's Avatar
Liked: 931
Hi Glimmie, This is a penhouse, we would have to eliminate the butler's bed in order to do that.
Sincerely, GC*
post #11 of 12 Old 08-18-2012, 02:18 PM
Glimmie's Avatar
Quoted: 732 Post(s)
Liked: 596
Then throw the amps in the Butler's room. A good butler always tends to his master's amps!
Glimmie is offline
post #12 of 12 Old 08-21-2012, 04:15 PM
What needs to be done is keeping the air conditioning *pressure* low, while still achieving the required CFM. This usually means oversized ducts and increasing the number and/or size of the registers. (High pressure = high localized air speed. Increase the air exit area, and you can move the same volume at lower speed and thus reduce noise).
