Summer Project - Replication of MBL loudspeaker 101mkII - AVS Forum | Home Theater Discussions And Reviews
Old 09-25-2012, 10:10 PM - Thread Starter
phenosity's Avatar
As the tittle suggest I am on a journey to try and replicate my dream speakers. Here is a link to my thread which is located over at Diyaudio.com. I need a little help determining the measurements as seen in the illustration provided. If you or anyone you know can and will help I would love to hear from you. Pm or post here.
Mbl mid measurments.jpg 46k .jpg file
http://www.diyaudio.com/forums/planars-exotics/220145-summer-project-replication-mbl-loudspeaker-101mkii.html
Name:	Mbl mid measurments.jpg
phenosity is offline
