No sound out of my Theta CBIII? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-30-2012, 09:37 AM - Thread Starter
speters's Avatar
The other day I was watching my satellite and all of a sudden I had no sound. This has happened before but usually if after I change a channel, but I don't recall if that was the case this time. This time it may have just stopped while I was watching the show but I can't say for sure. In the past when I lost sound, which maybe only happened once or twice a month I just turn off the Theta and turn it back on or turn off the satellite and turn it back and and everything is fine. But this time that didn't work and I can not get sound out of any of my devices, bluray, hd-dvd, cd player or satellite. I have tried all of them on different inputs, analog and digital and I get no sound. Obviously I needed to rule out that the issue was not some cables, amps or speakers. I first tried swapping out cables, still no sound. Then I decided to try the internal test tone from the Theta, and I was able to get sound from every speaker. So I know that at least the amps, speaker wires, and cables to the amps all work. So then I went back to swapping out different devices and different cable still with no luck? Does anyone have any ideas? I am confused that I am able to get sound from the test tone bu now from any input digital or analog?
Steve
PS: I did send my CBIII back to Theta about 6-8 months ago to have a power supply replaced and they updated the software on it then.
speters is offline
post #2 of 8 Old 11-30-2012, 10:06 AM
edorr's Avatar
Quoted: 41 Post(s)
Liked: 27
Steve
This is because your satellite is a jittery source - I had the same issue. There is a setting somewhere to increate the jitter tolerance for a specific input.
edorr is offline
post #3 of 8 Old 11-30-2012, 12:35 PM - Thread Starter
speters's Avatar
Yes, I do remember reading about that. I thought that I had already adjusted for that, at least I know I did before I sent it back to Theta the last time. I know that wold explain why I had lost sound in the past, but not this time.This was part of the reason that I first tried switching devices to see if I could get sound from anything else, and I couldn't.
Thanks for you input,
Steve
speters is offline
post #4 of 8 Old 11-30-2012, 04:53 PM
Stereojeff's Avatar
Quoted: 134 Post(s)
Liked: 63
Steve:
I have already relayed your issue to John Baloof, Theta's head of technical support. I'm sure you will hear from him promptly.
Jeff
Stereojeff is offline
post #5 of 8 Old 11-30-2012, 06:52 PM - Thread Starter
speters's Avatar
I tried calling today and they are closed on Fridays, so thanks Jeff.
Steve
speters is offline
post #6 of 8 Old 12-12-2012, 12:36 PM
DanielKGalvin's Avatar
I have a CB II-HD. Occasionally, usually on my Blue Ray input ( HDMI of course) I loose sound. Powering off the CB has always fixed it.
My source is a Pana BD-55. I've swapped the cables several times to no effect.
Sounds like you occasionally have this problem. So far, powering off has fixed the problem for me...
Cheers.
d
DanielKGalvin is offline
post #7 of 8 Old 12-13-2012, 09:35 AM
k_lewis's Avatar
Quoted: 65 Post(s)
Liked: 48
Pretty common issue even with the CBIII-HD. Theta is aware of it and working on fixes to improve. overall, just about any processor will occasionally lose digital lock or hdmi handshake, and result in no audio. some processors are fixed by switching the input source back / forth, others such as the CBIII need to be turned off / on. This happens with my CBIII-HD on occasion with BD, and more often with DirecTV- even FF / Pause / channel changing can kick the audio off once in awhile.
I programmed a macro on my remote called "audio fix", which essentially turns the CB off - wait 10 seconds - back on.
01010100 01101000 01100101 01110100 01100001 00100000 01000011 01000010 01001001 01010110 00101100 00100000 01010100 01101000 01100101 01110100 01100001 00100000 01100001 01101101 01110000 01110011 00101100 00100000 01101100 01101111 01110100 01110011 00100000 01101111 01100110 00100000 01100101 01111000 01100011 01100101 01110011 01110011 01101001 01110110 01100101 00100000 01100001 01110101 01100100 01101001 01101111 00100000 01100111 01100101 01100001 01110010 00101110
k_lewis is offline
post #8 of 8 Old 01-21-2013, 05:55 PM
adanny's Avatar
I just stumbled on this thread. Have these problems stopped for you guys? My new theta cbiii also lost sound, went back to theta, cam back, lost sound again and is back in the shop. I am curious about how to set the jitter tolerance higher to prevent this? Alas, powe cycling did not fix it for me. Worrying.....
adanny is offline
