Official DataSat RS20i thread. (Setup Tips, Questions,General Info, etc) - Page 148 - AVS Forum | Home Theater Discussions And Reviews
 981Likes
post #4411 of 5312 Old 03-09-2017, 08:42 AM
Quoted: 53 Post(s)
Liked: 29
Originally Posted by audioguy View Post
Great looking room.
Who is doing the RS20i audio/room calibration for you, if you don't mind me asking?
Datasat Team. While I like to tinker I am NOT a do it yourselfer. I prefer a professional setup.
jazzrock is offline
post #4412 of 5312 Old 03-09-2017, 10:42 AM
The Bogg's Avatar
Quoted: 443 Post(s)
Liked: 179
Anyone ever have the RS20i volume control knob come loose, quit functioning and then come off?
I just saw this post now as I was searching back through the thread to see where people are getting breakout cables from. Anyway, did you get this sorted out?
I had an ATC SCA2 preamp and was having a bunch of my audio buddies over. One of them goes to adjust the volume on the preamp itself and doesn't the volume knob
come off. Kind of embarrassing, lol, but at least it was just a matter of tightening the set screw.
Design by Rives...dollars by The Bogg
Click for my build thread
The Bogg is offline
post #4413 of 5312 Old 03-09-2017, 12:22 PM
audioguy's Avatar
Quoted: 2581 Post(s)
Liked: 1714
I know how to fix it but to do so requires disconnecting everything and removng from the rack. Then removing the faceplate!! What a pain !!!
audioguy is online now
post #4414 of 5312 Old 03-09-2017, 12:52 PM
The Bogg's Avatar
Quoted: 443 Post(s)
Liked: 179
oy. yeah having to remove anything out of the rack with a gajillion cables in it is a pita.
The Bogg is offline
post #4415 of 5312 Old 03-09-2017, 01:09 PM
The Bogg's Avatar
Quoted: 443 Post(s)
Liked: 179
I was reading a previous post which mentioned that the pin out standard for the RS20 is "Dolby cinema standard", is that the same as Yamaha pinout standard?
The Bogg is offline
post #4416 of 5312 Old 03-10-2017, 06:09 AM
Quoted: 53 Post(s)
Liked: 29
Great looking room.
Audioguy....I just tried to respond to your pm but dont know if my limited number of posts will allow that to be delivered to you
jazzrock is offline
post #4417 of 5312 Old 03-10-2017, 06:21 AM
Quoted: 53 Post(s)
Liked: 29
post 14
post 14
jazzrock is offline
post #4418 of 5312 Old 03-10-2017, 06:22 AM
Quoted: 53 Post(s)
Liked: 29
post 15
post 14
post 15. This should do it!
jazzrock is offline
post #4419 of 5312 Old 03-10-2017, 11:58 AM
audioguy's Avatar
Liked: 1714
Got the PM and have responded. Thanks.
sdrucker likes this.
post #4420 of 5312 Old 03-10-2017, 11:25 PM
Raul GS's Avatar
Quoted: 21 Post(s)
I don't think so.
Dunning–Kruger effect - a cognitive bias where individuals exhibiting poor ability suffer from an illusion of superiority, due to their mistaken assessment of their cognitive ability. That is, a high level of incompetence prevents such individuals from cognitively recognizing their own ineptitude. Yeah, I know...the irony.
Raul GS is offline
post #4421 of 5312 Old 03-21-2017, 07:24 AM
Mr. Integration's Avatar
Quoted: 266 Post(s)
Liked: 204
Great News! Beta for DTS-X for RS20 is coming to me this week!
I know it sounds great and looks great.....but can we communicate with it? If not it is useless:)
Mr. Integration is online now
post #4422 of 5312 Old 03-21-2017, 07:25 AM
audioguy's Avatar
Liked: 1714
That's encouraging !!
llang269 likes this.
post #4423 of 5312 Old 03-21-2017, 06:14 PM
The Bogg's Avatar
Quoted: 443 Post(s)
Liked: 179
Originally Posted by Raul GS View Post
I don't think so.
ok thanks. I'll just buy from proaudiola as mentioned earlier in this thread...they seem to know how to build cables to work with the RS20
The Bogg is offline
post #4424 of 5312 Old 03-22-2017, 03:59 AM
audioguy's Avatar
Liked: 1714
I'm not sure exactly what cables you are looking for but Datasat sells them --- but of course at top dollar. I purchased their extra length XLR output cables and their digital input cables as well.
post #4425 of 5312 Old 03-22-2017, 04:43 AM
Ganymed4's Avatar
Quoted: 203 Post(s)
Liked: 119
Do you need the pin-outs for the DB25 connectors? It is on the last pages of the RS20i manual, in case you need this. Tell me which one you need and I post it here. There is no secret about it.
Ganymed4 is offline
post #4426 of 5312 Old 03-22-2017, 10:43 AM
matted's Avatar
Quoted: 16 Post(s)
I'm not sure what the Dolby Cinema standard is, but I compared the pinout of the RS20i with the "common" Tascam and Yamaha standards and it is different from both of them.
A Dolby Reference decoder that I use at work has DB25 connectors on it which use the Tascam standard, however this is a Dolby Broadcast decoder and likely comes from a separate division of Dolby then the Cinema products.
To have any cable made, pretty much any Pro Audio dealer/rental house for recording/DJ/musical instruments should be able to custom order anything you need as long as you can specify the pinout, length, and gender of the cables required. In my experience even these custom cables should be considerably cheaper then what Datasat provides. If the custom cable can use Mogami parts then it will even be identical to the Datasat cable, although there will be a small premium for Mogami cable/connectors.
matted is offline
post #4427 of 5312 Old 03-22-2017, 11:51 AM
The Bogg's Avatar
Quoted: 443 Post(s)
Liked: 179
I'm just looking for a digital out cable - I will connect my turntable prepreamp to the analog input on the Datasat and I wanted a digital out from the RS20 to go into my Alesis digital recorder. Also, since the Datasat will be located fairly close to my multichannel amp I was going to have a cable made up that would go from db25 to male xlr directly into the amp rather than having a jumper cable between the Datasat cable that came with the RS20 and the amp.
I saw the pinout arrangement on the cd version of the manual and could always photocopy it and send it to the cable maker. As noted, Datasat does sell the cables but for my needs I don't think I want to spend the Datasat bucks for their cable.
The Trinnov Altitude wins hands down for connectivity options - digital in with xlrs, digital outs, etc... but at least it's only a minor inconvenience and expense to get things for the RS20.
The Bogg is offline
post #4428 of 5312 Old 03-22-2017, 12:30 PM
sdurani's Avatar
Quoted: 5143 Post(s)
Liked: 3624
I think the current Dolby cinema decoder (CP-850) uses the Tascam pin-out while the previous model (CP-750) used the THX pin-out (as does the Datasat AP20). See attached.
Sanjay
sdurani is online now
post #4429 of 5312 Old 03-23-2017, 01:36 PM
mhafner's Avatar
Quoted: 190 Post(s)
Liked: 71
The secondary server has V1.05 alpha builds with DTS:X. If you know how to download non release builds you can install the latest alpha 4.
I felt reckless and installed it. Did not brick my unit and sounds good so far with the samples from the 2015 DTS Sampler Disc.
Any UHD BDs I should try? Which one has the best DTS:X soundtrack?
(Don't ask how to access these builds if you don't know already. I don't want to be responsible if you brick your unit.)
grtuck likes this.
mhafner is offline
post #4430 of 5312 Old 03-23-2017, 02:25 PM
stephenbr's Avatar
Quoted: 180 Post(s)
Liked: 92
Great to hear DTS:X is on its way - did you notice any other changes with this update?
stephenbr is offline
post #4431 of 5312 Old 03-23-2017, 03:56 PM
Quoted: 53 Post(s)
Liked: 29
Off Topic Question
My Datasat is being installed next week with calibration the following week. Getting pumped!
Two Questions;
While there are more Bluray discs being released with Atmos/dts-X there are also several being released on 4k discs. To be able to take advantage of the soun dtracks on 4k discs I was thinking of replacing my Oppo 105D with the new 203 4k unit. The issue is I have a Runco VX22-d 1080 projector that i will not be replacing for couple years. Is it possible to play 4k discs to get the 3-d audio but send a 1080 video to the projector? Even if this is possible, will it end up delivering an inferior video image to the projector than the standard 1080 Bluray? I don't want to degrade my picture quality just to get the 3d audio.
Lastly, for those who listen to hi-res audio.....I have always listened to my SACD and DVD-A music discs in direct mode by-passing all processing. I know this isn't exactly available in the Datasat and, in many respects, isn't as much of a necessity to get the best direct playback quality from source audio since I now will be able to send the audio signal into the processor for conversion to analogue....but I still would like to get the most accurate playback from the source without coloring it or adding unecessary eq. How do you listen to hi res discs to maintane the purest stream from the disc?
Really value the experience you guys have and appreciate any feedback.
jazzrock is offline
post #4432 of 5312 Old 03-23-2017, 04:54 PM
The Bogg's Avatar
Quoted: 443 Post(s)
Liked: 179
Jazzrock, I assume you realize you will need to have the Oppo convert the sacd to output pcm and not dsd. Then you will be basically using the dacs in the RS20. You can do this with no processing if you want, but if you do any bass management or if you are using multichannel sacd then you may as well enjoy the benefits of the RS20 such as dirac, peq etc...
The Bogg is offline
post #4433 of 5312 Old 03-23-2017, 04:55 PM
The Bogg's Avatar
Quoted: 443 Post(s)
Liked: 179
I don't even know where the primary server is.
The Bogg is offline
post #4434 of 5312 Old 03-23-2017, 05:02 PM
The Bogg's Avatar
Quoted: 443 Post(s)
Liked: 179
Sometimes it pays to just look at the manual, or in this case actually look at the cable. It already has male xlr connectors so it can plug directly into the amp. yay, now I don't have to buy one.
Just need a digital out cable. Too bad they didn't have just one digital out connector on the RS20. Or do they? Maybe I'll read the manual.
The Bogg is offline
post #4435 of 5312 Old 03-23-2017, 05:05 PM
mhafner's Avatar
Quoted: 190 Post(s)
Liked: 71
No.
stephenbr likes this.
mhafner is offline
post #4436 of 5312 Old 03-23-2017, 05:06 PM
Quoted: 53 Post(s)
Liked: 29
Get your point. For 5.1 in particular. Had forgotten the need to decode DSD IN THE PLAYER. I did read that quite a few pages back.
Thx Bogg
jazzrock is offline
post #4437 of 5312 Old 03-24-2017, 03:48 AM
westmd's Avatar
Quoted: 827 Post(s)
Liked: 291
No.
Did you compare upmixer for DTS:X, Atmos and Auro?
westmd is offline
post #4438 of 5312 Old 03-24-2017, 03:54 AM
mhafner's Avatar
Quoted: 190 Post(s)
Liked: 71
Not really. I wait for the final release for that.
mhafner is offline
post #4439 of 5312 Old 03-24-2017, 04:00 AM
Wookii's Avatar
Quoted: 1321 Post(s)
Liked: 481
You're a braver man than me, being willing to load an Alpha release, I've been waiting for the beta version to appear on that server!
Is the DTS Neural X upmixer working on the version you tested?
Wookii is offline
post #4440 of 5312 Old 03-24-2017, 04:05 AM
mhafner's Avatar
Quoted: 190 Post(s)
Liked: 71
Yes. And no "scary" sounds during playback so far.
mhafner is offline
