Official DataSat RS20i thread. (Setup Tips, Questions,General Info, etc) - Page 40 - AVS Forum | Home Theater Discussions And Reviews
 590Likes
post #1171 of 4355 Old 01-11-2014, 05:14 PM
Interleave's Avatar
Dave,
With the current setup I believe I have done the minimum and that is to have the new side surrounds outputting on Channel 15&16 so that part is sorted and I am actually hearing the side surrounds audio tack on both sets.
What I dont understand is the switching of the XLR cables you refer to. The only other way I thought this could be done was to try and do two runs of Dirac and then somehow merge the optimisation for side surrounds. Not sure how I would even do that.
In the Dirac Live setup it talks about multiple speakers. I have checked that option as well. What I actually thought this would do is look at my routing and realise that I am outputting to Channel 5&16 / Channel 6&15 and treat each channel pair individually. Too much advanced thinking/hoping on my behalf smile.gif
Interleave is offline
post #1172 of 4355 Old 01-12-2014, 04:28 AM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Giving this some thought, you won't be able to do what I suggested. I think your best bet is to take as many measurements from both front and back rows when running Dirac to try and get the smoothest response for all positions.
But, putting the outs 15 & 16 on the surrounds 5 & 6 inputs will have you have two speakers playing simultaneously (Surround left and surround left back and the same for the right surrounds), so when running the Dirac software , it will apply filters for the two speakers combined on each side.
I am not sure what you want to do is possible????
My build thread
My 8 x RE XXX 18" Subwoofers, IB build
Couldn't pour water out of a boot with instructions on the heel.
Do you know what Nemesis means?
JapanDave is offline
post #1173 of 4355 Old 01-12-2014, 04:34 AM
Interleave's Avatar
Then how does one get side surround arrays going? I would have thought this is right up the alley of the RS20. I assume I dont have to invest in an external DSP to get this to work ?
post #1174 of 4355 Old 01-12-2014, 05:00 AM
ceenhad's Avatar
Quoted: 72 Post(s)
Liked: 62
You link them as you have done and use the multiple speaker option in Dirac so that it knows to correct on that basis. You can individually trim and delay and use manual output eq to sweeten if you really want to.
Neil Davidson - DT Screens
ceenhad is online now
post #1175 of 4355 Old 01-12-2014, 05:33 AM
djnickuk's Avatar
Quoted: 248 Post(s)
Liked: 62
As Neil says, you have set it up correctly. Just tick the multiple speaker option under the correct channel number in the first page of the Dirac setup.
But as you are sharing the same channels, if you want to adjust the trims on the channels you have moved you will need to do this in the channels and routing page as once you move a channel the faders for that channel under audio levels becomes redundant.
djnickuk is offline
post #1176 of 4355 Old 01-12-2014, 05:14 PM
Interleave's Avatar
Neil, that is what I have done, just wanted to see if I had to do anything more than that. I also assume that in order to send a pink noise to the speaker I have to move it back if I want to set trim levels in any shape or form. Also I noticed that my trim levels in the Levels screen has not come over to the routing screen. Do I need to copy that over if I want to keep the trims that I have set?
Thanks everyone for the input...................
post #1177 of 4355 Old 01-14-2014, 12:18 PM
sdurani's Avatar
Quoted: 4507 Post(s)
Liked: 2912
Posted this in the Dirac thread, worth re-posting in the Datasat thread (see paragraph 7 below). Brief description and discussion of Dirac Unity here.
Well, Unity is a tentative name for this new technology because a number of speakers will work in unison...
While we believe that Dirac Live offers the best possible solution as a state of the art Digital Room Correction, our researchers have found that if no cost constraints are imposed we can even go beyond Digital Room Correction with a new radical approach we call Active Room Treatment.
At this time I cannot disclose any deep technical details but I can say that it is based on ideas from the fields of active noise control, sound field synthesis and room correction where our company has conducted research for many years.
You may rightfully ask why did we have a booth at the CES if we want to keep it "undisclosed"
This really radical approach has substantial hardware and processing requirements (several channels and speakers are involved even if reproducing a stereo signal) and will consequently have a substantial price tag.
As of now we offer Active Room Treatment to Dirac Live OEM licensees only, for them to be able to offer something on the absolute leading edge to their customers.
For example Datasat which is a current Dirac OEM licensee is indeed eligible to offer this to their customers. (it is however their decision if they would like to do so)
I anyhow expect that carefully weighted pages about this technology will be available soon in the Dirac site.
Sanjay
sdurani is offline
post #1178 of 4355 Old 01-14-2014, 12:32 PM
djnickuk's Avatar
Quoted: 248 Post(s)
Liked: 62
Time to send in our emails to Datasat to request unity!
djnickuk is offline
post #1179 of 4355 Old 01-14-2014, 01:23 PM
sdurani's Avatar
Liked: 2912
If Unity can really turn all your speakers into active room treatments (electronic absorbers), that would be impressive for taming room modes.
Sanjay
sdurani is offline
post #1180 of 4355 Old 01-14-2014, 02:42 PM
sierraalphahotel's Avatar
I hope the other brand sporting Dirac can also consider offering it in the future smile.gif
sierraalphahotel is offline
post #1181 of 4355 Old 01-14-2014, 02:45 PM
djnickuk's Avatar
Quoted: 248 Post(s)
Liked: 62
Do you mean the Emotiva? If so, I'd be suprised if that would have the upgrade path available, or indeed the processing power. We shall see I guess.
djnickuk is offline
post #1182 of 4355 Old 01-14-2014, 03:33 PM
No, I was referring to Theta but didn't want to cross contaminate the Datasat thread smile.gif
These are exciting days for Datesat owners. So much new processing coming your way!
Cheers
post #1183 of 4355 Old 01-14-2014, 03:52 PM
djnickuk's Avatar
Quoted: 248 Post(s)
Liked: 62
I know, I was being facetious. Lol.
I am sure they will get it at some point, but I doubt just yet as they are only just rolling Dirac out. And I doubt we will see it on the rs20i within the next 6 months unless Datasat have been quietly working away at this behind closed doors! wink.gif
djnickuk is offline
post #1184 of 4355 Old 01-14-2014, 04:05 PM
stephenbr's Avatar
Quoted: 161 Post(s)
Liked: 72
It would be great if Dirac Unity was eventually provided on the Datasat RS20i - it would be another great function on an already impressive unit.
C'mon Datasat, you can do it!!
stephenbr is offline
post #1185 of 4355 Old 01-14-2014, 05:26 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
It is an interesting idea for sure. And if DataSat wants to keep ahead of the competition implementing something like this would certainly take the RS20i to the next level (Assuming that Dirac Unity is that good).
OF topic but this guy looks like Oliver Saxon in Dexter. LOL,
ceenhad likes this.
My build thread
post #1186 of 4355 Old 01-14-2014, 05:48 PM
thebland's Avatar
Quoted: 1496 Post(s)
Liked: 847
Any word on a low cost DATASAT? Hoping for a digital output with Auro in a low cost model sans Dirac.
Great stuff.
DATASAT at $10K less than a Theta looks almost like a bargain!
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is online now
post #1187 of 4355 Old 01-15-2014, 01:28 AM
Wookii's Avatar
Quoted: 954 Post(s)
Liked: 283
Glad you said that Dave, I was thinking the same thing. I'll be interested to see how this new Dirac software helps tame the effect of room modes using a surround speaker array, given most surround speakers roll-off at about the point room modes start to become an issue.
I also wonder what Dirac Unity can add if Dirac room correction has already been ran and is already correcting for in room frequency and impulse response problems.
I don't mean to sound like a party-pooper, anything new that gets added to the RS20i is most welcome, but personally, given a choice, I'd rather see something like Dirac Dimensions implemented which, if I am understanding its description on the Dirac website correctly, would likely be of much greater use in a home cinema setting.
Wookii is offline
post #1188 of 4355 Old 01-15-2014, 01:38 AM
Wookii's Avatar
Quoted: 954 Post(s)
Liked: 283
Great stuff.
I wouldn't hold your breath! No doubt Datasat are working on lower price point models given some of the press statements that have been released (intentionally and accidentally) that elude to it, but I would expect these models to have reduced feature sets. A $10k reduction could well see things such as digital outputs removed, or the channel count reduced, maybe Auro 3D limited to 9.1 etc.
Wookii is offline
post #1189 of 4355 Old 01-15-2014, 11:01 AM
SoundChex's Avatar
Quoted: 355 Post(s)
Liked: 297
Agreed, and without some idea as to what is meant by "entry level price point", this Press Release (link) is not very informative:
"LAS VEGAS, 8 January 2014 – Datasat Digital Entertainment, the world leaders in audio solutions for home cinema, has today announced a technology partnership agreement with Auro Technologies. The deal will see the companies collaborate in the development of a range of processors incorporating the Auro-3D® immersive sound format. The new processors will make Auro-3D® available across price points from entry level to high-end home cinema."
_
[Home Office system schematic]
"My AV systems were created by man. They evolved. They rebelled. There are many speakers. And they have . . . A PLAN."
SoundChex is online now
post #1190 of 4355 Old 01-15-2014, 11:21 AM
sdurani's Avatar
Liked: 2912
In the CES demo, they were addressing room modes up to 500Hz. Below that frequency, the before/after waterfall measurements of the hotel room showed a drastic reduction in long decay times. The repeated On/Off comparisons made it clear that Unity was definitely improving the sound.
Dirac Live room correction is applied to the source channel that each speaker is reproducing, which attempts to smoothen out the frequency response (reduce peaks & dips). Dirac Unity is a separate set of cancellation signals, which attempts to make each speaker serve double duty as an active absorber for its location.
From reading the description, that's their re-mapping feature, at the moment only "used in select luxury cars to give all passengers an impression of sitting in a reference room with reference speakers placed outside of the car". Don't know how useful it would be for home theatres, since speaker placement typically isn't fixed/restricted the way it is in a car cabin.
Sanjay
sdurani is offline
post #1191 of 4355 Old 01-15-2014, 12:04 PM
Wookii's Avatar
Quoted: 954 Post(s)
Liked: 283
That's good hear from someone who has experienced it directly then. We're obviously all working blind here, and guessing what is going on, but I'm still unclear how a speaker that can't physically produce sound below, say, 50Hz, can contribute towards taming a room mode at say, 30Hz. Did they cover how the tech was working at the demo? That said, if it sounds good, bring it on!
Dirac Live does this also in a similar fashion to correct the impulse response, by generating a secondary signal from the speaker, designed to cancel the reflection, it also corrects for differences in driver phase, not just targeted frequency response. Granted each speaker does work alone however. I guess Unity builds on that by having the system work together as a whole, and looking at the interactions between speakers.
Given that the vast majority of home cinema systems cannot achieve reference layout speaker positions, even those in dedicated rooms, it would actually be an incredibly useful feature. Even more so if it could be applied to Auro3D speaker layouts, where achieving the vertical 40 degree angles is tricky at best.
Wookii is offline
post #1192 of 4355 Old 01-15-2014, 12:33 PM
djnickuk's Avatar
Quoted: 248 Post(s)
Liked: 62
Gareth. I'm guessing all frequencies sub 50hz will be handled by subs?
When I asked Dirac about there remapping feature for cars, they said its no where near as powerful as Dirac live! And as such Dirac live, loosely incorporates this feature.
djnickuk is offline
post #1193 of 4355 Old 01-15-2014, 12:45 PM
Wookii's Avatar
Quoted: 954 Post(s)
Liked: 283
I guess so - assuming the sub isn't up front next to the speakers it's trying to correct. I'm not saying Unity doesn't work, just keen to understand how it does work.
There is precious little on the Dirac site on Dimensions, so I'm just surmising it would be similar to the Trinnov remapping. Maybe not. What does Dirac live do to correct for non-reference speaker positions though?
Wookii is offline
post #1194 of 4355 Old 01-15-2014, 01:56 PM
sdurani's Avatar
Liked: 2912
Who said it could? The idea is to use it for taming room modes from 50Hz up.
They described the approach without going into the math.
Dirac Live can address some of the effects of room reflections, like peaks & dips, as well as improve the impulse response (at least for minimum-phase low frequencies). Dirac Unity actually attempts to remove the boundry, the way a double bass array does to the back wall of a room (akin to noise cancelling headphones).
Tricky to create virtual speakers for multiple seats in a home theatre, since phantom images aren't stable. If you ever get a demo of any re-mapping technology, try moving out of the sweet spot.
Sanjay
sdurani is offline
post #1195 of 4355 Old 01-15-2014, 02:25 PM
Wookii's Avatar
Quoted: 954 Post(s)
Liked: 283
Fair enough, 'twas just an an example, I hadn't seen that limit mentioned.
. . . as well as improve the impulse response (at least for minimum-phase low frequencies) . . .
I'm not expert on this, and without wishing to split hairs, I believe the Dirac impulse response correction used a mixed phase, rather than minimum phase approach, and is designed to correct higher frequencies where the reflections are strongest, most consistent and have the greatest impact on audibility - One of the main reasons for applying Dirac to the whole frequency range on all channels, not just on bass frequencies.
Fair one, I haven't actually heard Trinnov in action, so I wasn't aware it wasn't stable outside of the sweet spot.
It does sound very cool. When you heard the Unity demo, how would you describe the change in sound when it was applied?
Wookii is offline
post #1196 of 4355 Old 01-15-2014, 03:18 PM
sdurani's Avatar
Liked: 2912
Because it isn't a system limit, just something obvious: if a speaker has no useful output below 50Hz, then it can't help correct frequency response below 50Hz. That doesn't have anything to do with Dirac Unity, just plain reality.
I believe the Dirac impulse response correction used a mixed phase, rather than minimum phase approach, and is designed to correct higher frequencies where the reflections are strongest, most consistent and have the greatest impact on audibility...
If you believe that, then I won't try to tell you otherwise.
It's not about Trinnov in particular but phantom imaging in general. If you're going to map a sound to a location where there is no physical loudspeaker, like where you hear vocals in a 2-speaker set-up, then that location won't be the same for all listeners. Phantom images are created in the brain, so when you move they move with you.
The most audible change was the improvement in clarity. Lower frequency sounds that were ringing (had longer decay times) got tightened up and sounded sharper; most noticable on bass guitar plucks, drum whacks, etc. In addition, since these lower frequency sounds were decaying quicker, the side effect was that they no longer masked sounds at higher frequencies, exposing details that were previously obscured by the lingering bass. I could hear more clarity, for example, in the upper range of female vocals even though Unity wasn't correcting those particular frequencies.
It's a difference I'm very familiar with, having added room correction in 2004 to my old Lex processor. DSP horsepower wasn't anywhere near as powerful back then, so they concentrated the correction below 300Hz and just targeted frequencies with the longest decay times. This yielded the dual improvements I recognized with Unity: sounds in the correction range got tighter/clearer, while details above that range were unmasked and easier to hear. Of course the technology has come a loooong way in the 10 years since I first got it.
Sanjay
sdurani is offline
post #1197 of 4355 Old 01-15-2014, 03:53 PM
djnickuk's Avatar
Quoted: 248 Post(s)
Liked: 62
Dirac are aiming Unity at the ultra high end, re their comment about it costing a fair amount to implement. And as such I expect they expect most users to be using at least 4 subs in their system.
But here is a copy and paste from Computer Audiophile
Originally Posted by dallasjustice
Flavio,
If I wanted full range down to 20hz 2 channel using a Unity 7.1 setup, would all of the speakers need to be capable down to 20hz as well?
Michael.
Hello Michael,
as I said it has substantial hardware requirements... no, all speakers do not need to contribute all the way but the resulting treatment would be limited by the fact that they don't.
So the use of more than one subwoofer (or bass capable speaker) would be recommended.
Flavio
http://www.computeraudiophile.com/f23-dsp-room-correction-and-multi-channel-audio/dirac-unity-ces2014-18972/
djnickuk is offline
post #1198 of 4355 Old 01-15-2014, 04:05 PM
Wookii's Avatar
Quoted: 954 Post(s)
Liked: 283
Flavio,
Michael.
Hello Michael,
Flavio
Thanks Nick, that was precisely the point I was trying to establish.
Wookii is offline
post #1199 of 4355 Old 01-15-2014, 04:30 PM
Wookii's Avatar
Quoted: 954 Post(s)
Liked: 283
Ha! Lol, there's no need for that mate! I'm just going of Diracs own description of the tech they use in Dirac Live. So what are you saying, their description is incorrect, or Dirac Live doesn't work as they say it does?
Thanks for the description. Did they say whether it could be applied to multi-channel playback, or just stereo tracks?
Wookii is offline
post #1200 of 4355 Old 01-15-2014, 04:55 PM
3D Audio Consultant
Curt_Trinnov's Avatar
Quoted: 72 Post(s)
Liked: 118
.....Tricky to create virtual speakers for multiple seats in a home theatre, since phantom images aren't stable. If you ever get a demo of any re-mapping technology, try moving out of the sweet spot.
Are there any other remapping technologies out there besides Trinnov??
Concerning phantom images- you would be correct.   However, with Trinnov, it's not the complete story.  As you say, where there there are no speakers, Trinnov will rely on a phantom image- and it will collapse as a function of how wide it is- typical phantom image behavior.
The opposite is also is true- a wider sweet spot is possible- where a Trinnov Remapped loudspeaker improves a broader listening area because the added speaker is used to fill in a spatial gap.  A great example of this is the typical front to side speaker gap.  Placing a speaker in the 50-70 degree axis on the sides provides a sometimes dramatic spatial fill that enlarges the sweet spot.  There are many other examples of this- and it's why high channel count Trinnov's are favored.
Cheers,
___________
Curt Hoyt
3D Audio Consultant
Trinnov Audio
USA
Curt_Trinnov is offline
