Official DataSat RS20i thread. (Setup Tips, Questions,General Info, etc) - Page 46 - AVS Forum | Home Theater Discussions And Reviews
 590Likes
Old 02-18-2014, 07:28 PM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
When is the new ATI signature amplifier coming out? Any word on it yet?
Started to liquidate some of my stuff to make an attempt at getting the ATI + Datasat combination but I am considering the Avantgarde Acoustics XA amplifier + Datasat also.
The Avantgarde XA is very likely to be ultraquiet with my horn speakers since it was made by the manufacturer that makes my Avantgarde Duo Omega Horns... I find that Avantgarde's claims are never just marketing fluff so I can buy their stuff with confidence. It is unclear how the ATI amp will operate with my horns. I don't need massive wattage, but the first watt performance needs to be AWESOME.
Blazar!
blazar is offline
Old 02-19-2014, 08:55 AM
Stereojeff's Avatar
Quoted: 112 Post(s)
Liked: 60
We're hoping for April/May.
Jeff
Stereojeff is offline
Old 02-27-2014, 02:40 AM
stephenbr's Avatar
Quoted: 161 Post(s)
Liked: 72
Software V1.02.02 now available - quite a few updates with this one.
stephenbr is online now
Old 02-27-2014, 02:49 AM
Wookii's Avatar
Quoted: 955 Post(s)
Liked: 284
Interesting - so what is the HSR-41 HDMI card????
Wookii is offline
Old 02-27-2014, 02:56 AM
stephenbr's Avatar
Quoted: 161 Post(s)
Liked: 72
Had me stumped too!
Old 02-27-2014, 02:59 AM
Wookii's Avatar
Quoted: 955 Post(s)
Liked: 284
I'll kick off the random speculation then . . . a HDMI 2.0 board with additional inputs and and output to bring it in line with the LS10's compliment of ports?
Wookii is offline
Old 02-27-2014, 03:11 AM
stephenbr's Avatar
Quoted: 161 Post(s)
Liked: 72
And also includes Datasat's answer to Theta's Jitter Jail 2.
Old 02-27-2014, 03:30 AM
Wookii's Avatar
Quoted: 955 Post(s)
Liked: 284
Well, this is the HSR-41 HDMI board, which support 4K:
www.mds.com/system/resources/.../HSR-3rd_rev1c.pdf‎
According to that PDF, this is a 3rd generation board, where as the HSR5, which I believe (please correct me if I'm wrong) is the current HDMI board in the RS20i, is a 2nd generation board not capable of handling 4K.
EDIT: Sorry, link doesn't seem to work - try this and click on the datasheet: http://www.mds.com/products/hsr--2
stephenbr likes this.
Wookii is offline
Old 02-27-2014, 10:06 AM
sdurani's Avatar
Quoted: 4515 Post(s)
Liked: 2918
According to the data sheet, it is HDMI 1.4 and has 5 ports (4 in, 1 out).
Sanjay
sdurani is online now
Old 02-28-2014, 01:38 AM
Wookii's Avatar
Quoted: 955 Post(s)
Liked: 284
Yep, it turns out that new RS20i's are shipping with this board as the HSR5 in the current RS20i's are now end of life. The new HSR41 boards can pass 4K (at limited frame rate), but as I understand it this isn't enabled in the Datasat firmware, so operationally the two boards are the same.
The HSR41 is, apparently, being used as something of a stopgap until the new HDMI 2.x boards become available, and suitable HDMI 2.x sources and display devices are available.
This was all posted on the UK forum by Graham at Genesis (UK Distributor) if you want to read the full reply:
http://www.avforums.com/threads/datasat-rs20i-processor.1625856/page-37#post-20395905
Wookii is offline
Old 03-01-2014, 07:03 PM
stephenbr's Avatar
Quoted: 161 Post(s)
Liked: 72
Anyone downloaded the new software yet? I've struck some problems updating by USB - first off I get a message that I am updating to an earlier version, if I continue past that message I then get an error message 'uncompressing images ERROR: update script failed failed to uncompress images'.
Old 03-01-2014, 09:25 PM
Carl_Huff's Avatar
Quoted: 83 Post(s)
Liked: 104
Stephen,
I updated my RS20i using USB just this morning. It went off without a hitch. Perhaps you attempted to load a corrupted file. I invite you to download it onto your thumb drive once more and give it another try.
______________
Best Regards,
Carl Huff
Carl_Huff is online now
Old 03-01-2014, 09:58 PM
stephenbr's Avatar
Quoted: 161 Post(s)
Liked: 72
Thx Carl. I have reloaded the file 3 times and no luck. Could be because I am going from v1.02.00 rather than v1.02.01?
Old 03-01-2014, 10:27 PM
Carl_Huff's Avatar
Quoted: 83 Post(s)
Liked: 104
I don't think so because as it worked out I was updating from an older version as well. Do you have another thumb drive to try? Not all thumb drives are equal in compatibility.
______________
Best Regards,
Carl Huff
Old 03-01-2014, 10:38 PM
stephenbr's Avatar
Quoted: 161 Post(s)
Liked: 72
I am using the Datasat supplied thumb drive that has been fine previously. I did try another thumb drive but that didn't even register with the RS20i.
Old 03-02-2014, 03:57 AM
djnickuk's Avatar
Quoted: 249 Post(s)
Liked: 62
I updated mine via the main server, have you tried that?
djnickuk is offline
Old 03-02-2014, 11:04 AM
GGA
GGA's Avatar
Quoted: 206 Post(s)
Liked: 55
Do you have the latest H335?
From the update pdf:
16.
An RS20i with a H335 rev 5 or below as shown on the Sy
stem info screen will not be allowed to downgrade
the software below this version (V1.02.02)
c.
Latest release version for HSR5 board is
Release 39 Version 11 Rev 5 (unchanged).
There is a pdf on how to update the H335.
GGA is offline
Old 03-03-2014, 02:57 AM
stephenbr's Avatar
Quoted: 161 Post(s)
Liked: 72
16.
c.
I am on the latest release version for HSR5 board. I will wait and see what Datasat Tech Support suggest before I try anything else (eg trying an network update which I am not currently set up to do).
Old 03-03-2014, 04:30 AM
Masterkale's Avatar
Quoted: 36 Post(s)
Anybody heard a datasat R20 next to a bryston sp3?
how much difference is between them? There is no datasat dealer near my place.
Masterkale is offline
Old 03-04-2014, 11:13 PM
stephenbr's Avatar
Quoted: 161 Post(s)
Liked: 72
Datasat have advised that there is a problem downloading the latest firmware onto a thumbdrive from their website. I also struck the same problem however with the firmware file they sent by email. May have to get a long cable to connect my unit to the internet.
Old 03-06-2014, 03:56 AM
Interleave's Avatar
Just completed the online upgrade and went off without a glitch......................
Interleave is offline
Old 03-06-2014, 03:57 AM
Interleave's Avatar
Quick question for the gurus out there, is there a way to power off/on the unit via net commands or RS232 inputs?
Old 03-06-2014, 04:25 AM
Wookii's Avatar
Quoted: 955 Post(s)
Liked: 284
Yep, this should help:
RS20iControlRS232.pdf 216k .pdf file
There may be an updated version, but most of the commands are here I think.
Interleave likes this.
Wookii is offline
Old 03-06-2014, 04:45 AM
Interleave's Avatar
Brilliant mate! Thanks for that just what I needed!
Old 03-06-2014, 05:16 AM
Wookii's Avatar
Quoted: 955 Post(s)
Liked: 284
No problem! Out of interest what control system are you going to be using to control the RS20 via RS232?
Wookii is offline
Old 03-06-2014, 05:28 AM
Interleave's Avatar
Not sure I was looking at RTi but dont know if it is a viable option I know iRule has capabilities but not keen on designing it myself I have a CBF attitude so I need to find someone that can help me out with it. I enjoyed building my room now I just want thing done and dusted. Any recommendations?
Old 03-06-2014, 05:41 AM
thebland's Avatar
Quoted: 1497 Post(s)
Liked: 849
I use RTI in the theater and around the house. Great system and very sophisticated. Can do it all. When I fire up my system, I have a macro fire ~ 15 commands (most all serial). I have a touch controller and use my iphone to control.
I am getting ready to integrate iRule to try something new but more time to program - but equally or more so powerful.
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is offline
Old 03-06-2014, 05:43 AM
Wookii's Avatar
Quoted: 955 Post(s)
Liked: 284
Well I was originally going to do a full on Demopad contol interface with an iPad etc, but as it turned out a) its too much of a hassle to program it all, b) I don't actually like using an iPad as a controller, its too clunky. Call me a traditionalist, but I like a simple hard button remote, at least for the main basic functions, that can sit easily on the arm of the chair next to me.
So I'm getting a product from a company called Celadon:
http://www.celadon.com/infrared-receiver-specs/RCV-5000_infrared_receiver_specs.html
It is basically an IR to RS232 converter. They program it for you with all the HEX codes appropriate for the RS20i, and supply a master remote:
http://www.celadon.com/remote-control-specs/SC-45-low-volume-remote.htm
the buttons of which correspond to each RS232 command (there are a few different remotes to choose from).
I am then going to use that to program my Harmony Ultimate which will control everything in my cinema room, including lighting and air-con (it also has a matching iPhone app it I want that as an alternative controller also), and soon . . the RS20i too!
Total cost is just over $320 including delivery to the UK, which I didn't think was bad!
Wookii is offline
Old 03-06-2014, 05:46 AM
Interleave's Avatar
Does RTi have preconfigured command sets or are they all learnt / built? I like the idea of the RTi system but I want something that will do RS20i, Oppo, Dune Player, Popcorn Hour, JVC projector and Cineslide. Ideally something that is robust and easy to maintain as well. Ideally I want CBus integration for the lighting system and I know RTi does CBus.
Old 03-06-2014, 05:48 AM
Interleave's Avatar
I currently use the iPad mini in the theatre room and its fine for what I use it but its a pain when I flip between say VNC / Dune Player / Oppo etc.
