Official DataSat RS20i thread. (Setup Tips, Questions,General Info, etc) - Page 67 - AVS Forum | Home Theater Discussions And Reviews
 590Likes
post #1981 of 4333 Old 12-01-2014, 02:07 PM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
Since you guys in this thread have the most real world experience with Dirac, I thought I would ask here. Emotiva is about to enable Dirac on the XMC-1. The XMC has two independent sub outputs, and I have 4 subs. I can set this up one of two ways..
1) Use my current setup where I have time aligned the 4 subs with an outboard Xilica processor and the help of some fine folk at the Home Theater Shack and REW. I would connect the 4 subs to just one output of the XMC as I have now and let Dirac do its thing while "hearing" the combined response of all 4 subs on that one output.
2) Connect the front and rear subs to one output and left and right subs to the second output, turning off all attempts to time align the subs in the Xilica. The front and rear are pretty close to the same distance from the MLP (maybe a foot difference at most I think) and the left and right are also similar. Then just let the XMC Dirac setup hear each set of subs separately and do its calculations.
I realize the XMC's iteration of Dirac may differ a bit from the Datasat, but if you assumed that the Datasat had only two sub outputs, which of the above methods would you use?
... I also suppose that if it mattered I could attempt to make the time alignment of the front/rear and left/right even closer by still using the delays of the Xilica even if I chose option #2 above instead of just letting them pass the signals through.
Thanks for any help and I don't want to hijack a Datasat thread, but there will be limited users of the XMC with 4 subs and an outboard EQ at their disposal and you guys have great experience with this.
hifiaudio2 is online now
post #1982 of 4333 Old 12-01-2014, 02:33 PM
sdurani's Avatar
Quoted: 4476 Post(s)
Liked: 2896
During normal playback will each set of subs be getting different signals?
Sanjay
sdurani is offline
post #1983 of 4333 Old 12-01-2014, 02:43 PM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
No.
post #1984 of 4333 Old 12-01-2014, 02:48 PM
sdurani's Avatar
Liked: 2896
No.
Then I wouldn't EQ them independently. IF you're going to be hearing the interaction of all 4 subs, then EQ the interaction of all 4 subs.
Sanjay
sdurani is offline
post #1985 of 4333 Old 12-01-2014, 02:53 PM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
Ok cool...so I will stick with option #1 . Its the easiest to setup anyway since it is basically done except for enabling Dirac and running it.
post #1986 of 4333 Old 12-01-2014, 03:17 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
I put all 12 subs on one channel and time align them in the RS20i. I then run Dirac on that channel. I tried separating them and I found I had best results grouping them.
My build thread
My 8 x RE XXX 18" Subwoofers, IB build
Couldn't pour water out of a boot with instructions on the heel.
Do you know what Nemesis means?
JapanDave is offline
post #1987 of 4333 Old 12-01-2014, 03:42 PM
Wookii's Avatar
Quoted: 946 Post(s)
Liked: 275
What device do you use to time align the individual subs Dave?
I have just set mine up on a miniDSP running out of a single RS20i channel - excellent little device, let's me adjust delays and levels and add a bit of initial PEQ to each sub individually.
Wookii is offline
post #1988 of 4333 Old 12-01-2014, 10:15 PM
stephenbr's Avatar
Quoted: 161 Post(s)
Liked: 72
In my set up I master and slave my 2 F113s (they are symmetrically placed in my room) so they are running from one channel and are then EQ'd as a single unit. This allows me to have the 15 other channels free for a full 15 channel Auro set up (which I have yet to install!).
stephenbr is offline
post #1989 of 4333 Old 12-02-2014, 07:16 AM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
Cool thanks for the input. Sounds like grouping them all as one sub output and time aligning before handing off to Dirac is the consensus.
post #1990 of 4333 Old 12-02-2014, 06:00 PM
DanFrancis's Avatar
Quoted: 44 Post(s)
Liked: 42
When I had the RS20i in our demo room I fed 8 subwoofers with 1 input signal (via channel routing), this was before he bass management system was finalized- so we had to play with different configurations to get the various channels to work well.
Initially, I paired our front 2 side woofers with the mains as the lowpass, the side 2 and rear 2 and front 2 were all fed the LFE signal. the levels screen was great for getting things nice and tight balance-wise.
Dan
Dan Francis
DanFrancis is online now
post #1991 of 4333 Old 12-02-2014, 06:24 PM
GGA
GGA's Avatar
Quoted: 198 Post(s)
Liked: 39
Dan
Hi Dan, I am a little confused by your old setup.
You have a total of 8 subs, two each of the following:
front side (these are located somewhere between the front and side subs?)
front
side
rear
You say that all 8 subs were driven with one input signal (the LFE I assume), but I think you mean only 6 subs were so driven, the fronts, sides, and rears, as you state in second paragraph. The front side left sub received only the LP from the left front main speaker and same for right main front and right front side, effectively making the front main left and right full range speakers. Is that right? Where did the LP from all the other speakers go?
GGA is offline
post #1992 of 4333 Old 12-02-2014, 07:25 PM
DanFrancis's Avatar
Quoted: 44 Post(s)
Liked: 42
Yup, sorry, I mistyped. I meant 6 off lfe and 2 off full range mains. Back then the prototype had really basic bass management: like only large or small with rather limited options beyond crossover frequency (you also had frequency at the channel mapping screen). Even basic bass management will steer bass from all channels to the sub output, in this particular case I grouped it so I had 12 Dirac channels to cover the entire theater: 7 high pass and the 8 subs (paired some up).
I think what I ended up doing was run all 7 channels as small and send bass to all 8 subs since the sound wasn't all that different between the 2 scenarios and I had the added benefit of the extra subs during stereo playback (smoother and tighter bass).
When I received the final production unit the bass management was vastly more flexible and offered better options for bass steering. That unit was tested purely for menu functionality feedback, the sound hadn't changed at all.
Dan
Dan Francis
post #1993 of 4333 Old 12-06-2014, 06:23 AM
thebland's Avatar
Quoted: 1490 Post(s)
Liked: 841
Anyone using IRULE with the DATASAT??
I need help figuring out FEEDBACK showing the SURROUND MODE that is in use (e.g. AURO 3D, PLL IIx, PL IIz, DTS NEOx).
Anyone??
Thanks!!
Name:	Screen Shot 2014-12-06 at 8.22.13 AM.png
ID:	405050   Click image for larger version
Name:	Screen Shot 2014-12-06 at 8.22.13 AM.jpg
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is offline
post #1994 of 4333 Old 12-09-2014, 07:29 PM
yapota's Avatar
Quoted: 16 Post(s)
Best way to listen to 2 channel audio
Hi
Over the weekend I connected my Astell & Kern 120MKII digital audio player via optical out to the Datasat RS20i using a Toslink optical cable. The foramt being out put by the Datasat is shownig as PCM2.0. Whilst the sound quality is very good on standard 16nit/44KHZ tracks, when I played DSD or 24bit/192khz tracks it still outputted PCM 2.0. Is this correct and what is the best way to listen to 2 channel audio on a processor like Datasat? What is the configuration that most people use for 2 channel audio?
Thanks in advance for your help.
yapota is offline
post #1995 of 4333 Old 12-10-2014, 01:18 AM
Wookii's Avatar
Quoted: 946 Post(s)
Liked: 275
Originally Posted by yapota View Post
Hi
Is the Astell & Kern device able to output DSD over its optical connection? Though its a mute point, as the RS20i can't handle DSD streams sadly, they have to be pre-converted to PCM.
Well its a perfectly acceptable way to get digital music into the RS20i, but given that it has balanced digital inputs it might be worth trying those if you have device that supports them.
For most of my 2 channel music I use my seperate two channel stereo system, but when using the RS20i in my multi-channel system, pretty much exclusively via the Auro3D upmixer.
Wookii is offline
post #1996 of 4333 Old 12-14-2014, 11:00 AM
Quoted: 63 Post(s)
Liked: 7
The Atmos sound is coming only in 2015 (February maybe) on the Datasat because they are making improvments in the sound.
One thing is buying a Denon with Atmos decoding, another thing is a High End Processor to deliver the full scale detailed sound.
Back_to_the_Sound is offline
post #1997 of 4333 Old 12-16-2014, 08:41 PM
Bassfeen's Avatar
Quoted: 113 Post(s)
Hi All,
Been following this thread for few months now but giving up on my Home Theatre hobby due to life style change, moving out of a home and into a apartment. I am selling all my Gear including my Datasat.
I have a Datasat RS20I advertised at the Classified section for $15,000 dollars Including the Microphone Kit and Dirac License. This is upgraded to latest firmware but with out the Auro3d upgrades. 2 ~Year warranty is included the unit is logged with Datasat USA. Just trying to get rid of my speaker and processor the amps are all sold.
Price of the Unit with out the Microphone Kit & Diract License CD. $13,500.00
Link: Datasat RS20I Processor with Diract Microphone Kit & License
Bassfeen is offline
post #1998 of 4333 Old 12-20-2014, 03:14 PM
Wookii's Avatar
Quoted: 946 Post(s)
Liked: 275
Can anyone with the Auro3D upgrade AND dirac engaged, confirm for me whether you can get the Auro upmixer (or indeed any of the upmixers) to work on 24/192 stereo files?
Mine seems to be working fine on all files of 24/96 or below, but as soon as I switch to 24/192 all I get is stereo?!
Not sure if its a setting error on my part or a Datasat limitation?
Wookii is offline
post #1999 of 4333 Old 12-20-2014, 09:39 PM
djnickuk's Avatar
Quoted: 248 Post(s)
Liked: 62
Yeah no go here also. Do have support of 88.2khz tho. Which is nice as one can now upmix SACD played from oppo. But they clearly by pass the processing with 96k and up.
djnickuk is offline
post #2000 of 4333 Old 12-22-2014, 01:40 AM
Wookii's Avatar
Quoted: 946 Post(s)
Liked: 275
Thanks Nick - yeah that is a shame. I thought I got 96Khz tracks upmixing, but I can't be sure so I'll retest - certainly nothing above does.
I assume its an Auro limitation rather than a Datasat one? (I might try and get one of the Denon owners to test it out to see if they are similarly afflicted), I thought the down sampling to 96Khz by Dirac, was bad enough but not being able to upmix hi-res tracks is a real PITA.
Wookii is offline
post #2001 of 4333 Old 12-22-2014, 03:17 AM
djnickuk's Avatar
Quoted: 248 Post(s)
Liked: 62
Yeah sorry. I miss typed. 96 kHz is fine. It's just anything over. And not AURO. It's the DATAsat. It has the capability it's just dirac and its EQ shelving operates at 96. What it should do is down sample... And I'm sure it used to.
djnickuk is offline
post #2002 of 4333 Old 12-22-2014, 03:24 AM
Wookii's Avatar
Quoted: 946 Post(s)
Liked: 275
That's a good point, I have not tried it both with and without Dirac engaged to see if the upmixer works if Dirac is turned off?
That would a little odd though as doesn't the decoder sit upstream of Dirac?
As you say, what should be happening is that the decoder should apply Auro to the incoming 2 channel 24/192 stream and then down sampling to 96KHz should occur in order to allow Dirac processing.
Dan if you are watching, can you shed some light on this?
Wookii is offline
post #2003 of 4333 Old 12-22-2014, 05:00 AM
djnickuk's Avatar
Quoted: 248 Post(s)
Liked: 62
Again sorry I typed that badly, when I say Eq shelving I didn't mean that of dirac, the whole dirac, PEQ and 1/3rd octave runs at 96. But yes it should just bypass all that if over 96k.
djnickuk is offline
post #2004 of 4333 Old 12-22-2014, 09:29 PM
thebland's Avatar
Liked: 841
The best demo disc I've had in my system. Peter was right. Up mixed Atmos sounds Dwan native like in Auromatic!
Santa (err, Peter) shipped up a great gift!
thebland is offline
post #2005 of 4333 Old 12-22-2014, 10:59 PM
djnickuk's Avatar
Quoted: 248 Post(s)
Liked: 62
Yes it's good isn't it!
djnickuk is offline
post #2006 of 4333 Old 12-23-2014, 01:12 AM
kamenoff's Avatar
Quoted: 88 Post(s)
Liked: 27
Jeff, if I understand correctly you playing Atmos disc in Auro 3D set up?Are they compatible?
kamenoff is offline
post #2007 of 4333 Old 12-23-2014, 03:11 AM
djnickuk's Avatar
Quoted: 248 Post(s)
Liked: 62
Well it compatible as one is taking the dolby true hd stream and putting it thru auromatic. And in my head I think it sounds better in AURO but the processor used to compare against with Atmos is not really up to DATASAT standards.
djnickuk is offline
post #2008 of 4333 Old 12-23-2014, 06:15 AM
thebland's Avatar
Liked: 841
Even compared to the Auro Native Demo disc (which I have), this disc is the more impressive listening experience. The recordings are incredibly more dynamic and the spatial effects seem almost native. Not to mention, the bass on this mix is far hotter than the Auro disc. It was hard for me to believe but this disc is amazing...
And to give credit to Peter, he predicted this excellent effect with Atmos native discs on Auromatic.
thebland is offline
post #2009 of 4333 Old 12-30-2014, 05:38 PM
stephenbr's Avatar
Quoted: 161 Post(s)
Liked: 72
Interesting to note that Datasat has not been specifically mentioned as a manufacturer supporting DTS:X.
post #2010 of 4333 Old 12-30-2014, 06:02 PM
7channelfreak's Avatar
Quoted: 286 Post(s)
Liked: 190
Originally Posted by stephenbr View Post
Interesting to note that Datat has not been specifically mentioned as a manufacturer supporting DTS:X.
Oh I Know it'll have it but that stood out when I read the press release as well. Aren't they sister companies?
7channelfreak is offline
