Official DataSat RS20i thread. (Setup Tips, Questions,General Info, etc) - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 948Likes
post #181 of 5199 Old 01-01-2013, 12:02 PM
schlitzie's Avatar
Might have found a couple of bugs... Then again, maybe I'm just doing stuff wrong as usual.
I decided to hook up an iPod to RS20i for music for a NY's Eve party... At first I just plugged a simple 2 channel analog cable in to the RS20 out of the headphone jack -- not pleasing, as I had suspected, but most concerning was the complete lack of bass from the subs either with BM engaged or not, so the lack of an LFE signal was not a factor. That, plus the rear surrounds were not firing even though I had them turned on -- And I triple checked all the settings to make sure I didn't have something goofy going on - all looked correct.
So I figured maybe it doesn't like analog signals so much - luckily I have an Onkyo iPod digital interface (kinda like a Wadia), so I broke that out and plugged it all in via digital coax. Good news - sounded fuller, rear surrounds were firing, but still no bass from the subs. Gotta play with it some more to really document the situation to understand the symptoms further.
I have also noticed that my screen does not time out no matter what it is set to - I currently have it set to dim at 1 minute, but it just stays on. Anybody else have this issue?
It is kind of odd since my AP20 before this was much less finicky - Granted I have really dug into this machine more than I did with the older box, but I am surprised by the variety and quantity of new issues I am running into.
Doubtful it is a bad unit -- I must be doing things wrong. I've been a DIY home theater guy for a long time with a multitude of different boxes in the rack over the years, but I'm getting to the point that I really wish there was a trained Datasat person that could come by and make everything better. Carl, are you going to be in Philadelphia any time soon?!
OK, I'll stop whining now -- Happy New Year all!
schlitzie is offline
post #182 of 5199 Old 01-01-2013, 12:20 PM
stephenbr's Avatar
Quoted: 180 Post(s)
Liked: 92
Mike - setting the display to 'dim' means the display will stay on, just dimmer. At work at the moment so just going on my memory, if you want the display to turn off I think the option is 'blank' or 'black' screen. Can't help you with the subwoofer problem but when I have run two channel analogue (rather than through HDMI) my subwoofers have fired up.
stephenbr is online now
post #183 of 5199 Old 01-01-2013, 12:33 PM
schlitzie's Avatar
Stephen - I wasn't clear in what I wrote - it doesn't dim, nor does it black out. It just stays exactly the same after whatever the seconds/minutes it is set for have elapsed. The logo setting works though. Unfortunately that's not what I want!
post #184 of 5199 Old 01-01-2013, 12:54 PM
stephenbr's Avatar
Quoted: 180 Post(s)
Liked: 92
OK - I read your post too quickly - hmmm, sounds strange!
post #185 of 5199 Old 01-04-2013, 03:30 AM
DanFrancis's Avatar
Quoted: 44 Post(s)
Liked: 43
schlitzie,
There was a bug in the software early on with the prototype that I had where I couldn't use the dim feature on the display. Try turning the dimming off and see what happens. I can't remember the specifics to the problem, it was very early on - I would have figured that was solved by now, but perhaps the bug persists.
Dan
Dan Francis
DanFrancis is offline
post #186 of 5199 Old 01-04-2013, 04:23 AM
schlitzie's Avatar
Hi Dan
I have switched the dimming feature on and off, and have also re-booted several times now, and the problem persists. I plan to mess with it all some more this weekend as I have just been too busy this week to dedicate several more hours to the unit in order to document the list of issues.
Mike
post #187 of 5199 Old 01-04-2013, 11:49 AM
Carl_Huff's Avatar
Quoted: 87 Post(s)
Liked: 117
Hi Dan
Mike
Mike,
The display of your RS20i will always dim to a 'hard coded' fixed level. If the brightness of your screen is set low in normal operation you wouldn't notice a visible difference when dimming kicks in. I suggest that you check the brightness of your screen to see if this is your problem.
_____________
Best Regards,
Carl Huff
Carl_Huff is offline
post #188 of 5199 Old 01-04-2013, 02:45 PM - Thread Starter
JapanDave's Avatar
Quoted: 171 Post(s)
Liked: 124
Mike, just to clarify, when you say "Stay on" , are you not getting the screen saver or it stays on the setup screen?
B/C the RS20i should revert to the screen saver (Which is the DataSat logo by default) , but not completely turn off. Just wanted to clarify.
My build thread
My 8 x RE XXX 18" Subwoofers, IB build
Couldn't pour water out of a boot with instructions on the heel.
Do you know what Nemesis means?
JapanDave is offline
post #189 of 5199 Old 01-04-2013, 02:51 PM
djnickuk's Avatar
Quoted: 271 Post(s)
Liked: 72
What i believe mike is referring to is the selection of black screen option.
I se ths option set to 5 seconds. So after 5 secs my screen goes black.
Now I know you can put in your own jpg image, it's in the manual somewhere. Perhaps the black screen is just another jpg and for some reason Mikes is missing or corrupt.
djnickuk is offline
post #190 of 5199 Old 01-04-2013, 02:57 PM
schlitzie's Avatar
The screen remains on the home screen with the VU meters. That stays on continuously...
I'll look at it more in depth tomorrow to see if Carl's thought about the brightness setting has any effect.
While the screen is an issue, I am much more concerned about why the subs aren't firing correctly. I'll explore it all within the next 24 hours or so. Hopefully it's just me screwing up a setting, and not something funky with the machine or a long drawn out software repair
post #191 of 5199 Old 01-04-2013, 03:34 PM
Carl_Huff's Avatar
Quoted: 87 Post(s)
Liked: 117
Dave,
How are you coming on your 'Wall of Sound" that you were trying to pull together?
You must have tons of dynamic headroom! I am sure that when you finally get tweaked it will sound phenomenal.
_____________
Best Regards,
Carl Huff
post #192 of 5199 Old 01-04-2013, 04:52 PM - Thread Starter
JapanDave's Avatar
Quoted: 171 Post(s)
Liked: 124
Originally Posted by Carl_Huff View Post
Dave,
_____________
Best Regards,
Carl Huff
Hey Carl,
I have been making all sorts of changes and measurements and I am trying to figure out which sounds the best. The one thing I do encounter every time is that even when I match the SPL of the mains to the subs at measurement time, I have to turn the levels or gain down on the subs by at least 15db's. I am concerned that this will give me and funky in room response. Could it be that the galaxy 140 SPL meter is not working well at low frequencies?
The below graph is a basic sample of what I am trying to put across. The red line would be the room response with the levels left @ 85db with the driac filters in place and the balck line would be the room response with the levels turned down on the subs. So I would get a very uneven in room response and be very lacking in mid bass.
My build thread
post #193 of 5199 Old 01-04-2013, 07:59 PM
Carl_Huff's Avatar
Quoted: 87 Post(s)
Liked: 117
"Could it be that the galaxy 140 SPL meter is not working well at low frequencies?"
Dave,
Turning on the Dirac filters will change levels, but what you are seeing is more than what I would expect to see. You might well be seeing the affects of a 'C' versus 'A' filter on your SPL meter. If I were you I would fall back to using the SPL function that is in REW. I have limited experience with REW but it looks to have what you need. The fact that REW is not calibrated is not a problem if you set a master level using your mains and your Galaxy SPL meter and noting what that level is in REW. Then simply use that 'known reference level' for your subwoofer measurements using REW and your measurement microphone. You know that you can trust what you see using that combination.
______________
Best Regards,
Carl Huff
post #194 of 5199 Old 01-04-2013, 11:46 PM - Thread Starter
JapanDave's Avatar
Quoted: 171 Post(s)
Liked: 124
Carl, that is a great idea! I will give that a try.
BTW, I bought TrueRTA a while back.
My build thread
post #195 of 5199 Old 01-08-2013, 01:57 PM
schlitzie's Avatar
Spent some more time with the RS20i, and it has become clear to me that something is funky - but perhaps not with the box... I decided to re-run Dirac as it just wasn't a satisfying sound - It was clear and all, but just no horsepower on the low end. My previous AP20 was much better, so I do know what these things are capable of. I broke out the SPL meter, and this time got very different results than last time, from 5DB low on the main and surround channels, and 15db low on the subs. And yes, all the other settings, inputs, and outputs were consistent. So now my culprit is a rogue meter - I just ordered another one, so I can report back in a few days once it gets delivered.
Also, Carl was right -- the dimming feature is non-existent when you normally set the screen to be semi-dim in the first place. When I cranked the brightness up, it became apparent the dimmer does indeed work. Unfortunately even at the dim setting it is way too bright, so I ended up just going with the black screen option.
post #196 of 5199 Old 01-08-2013, 03:26 PM
stephenbr's Avatar
Quoted: 180 Post(s)
Liked: 92
Mike - good to hear things appear all OK with your unit. When I use the dim function I have set it to the lowest possible brightness and contrast settings and when watching a movie it is still quite noticable as you have also stated - but I do like to see the channels in action at times!
post #197 of 5199 Old 01-08-2013, 04:08 PM
schlitzie's Avatar
Stephen -- Well, I wouldn't go that far... It still does not like signals that are not HDMI based -- I'm not getting any bass through the analog or SPiF inputs, hence my desire to start over. I'll know more the end of this week.
post #198 of 5199 Old 01-08-2013, 07:12 PM
djnickuk's Avatar
Quoted: 271 Post(s)
Liked: 72
Mike, out of interest. Have you tried a dts / ac3 5.1 signal via coax or toslink? If not can you give it a whirl and check if your subs are firing.
djnickuk is offline
post #199 of 5199 Old 01-08-2013, 07:58 PM - Thread Starter
JapanDave's Avatar
Quoted: 171 Post(s)
Liked: 124
Can ask if anyone has tried to setup macros yet on the RS20i?
My build thread
post #200 of 5199 Old 01-08-2013, 08:10 PM
DanFrancis's Avatar
Quoted: 44 Post(s)
Liked: 43
Sorry Dave, not I.
Dan Francis
post #201 of 5199 Old 01-08-2013, 08:40 PM
stephenbr's Avatar
Quoted: 180 Post(s)
Liked: 92
Me neither Dave - sounds all too complicated for my setup (and I actually am a bit odd - I don't mind my routine of 'firing' eveything up, I actually want it hard for my kids to play with 'my' system and my wife is not interested)smile.gif
post #202 of 5199 Old 01-12-2013, 01:17 PM
kamenoff's Avatar
Quoted: 97 Post(s)
Liked: 30
Originally Posted by GGA View Post
HDMI can go up to 192kHz. It is only if you try to output a digital signal from the RS20i that it will be downsampled to 48kHz.
This is very interesting and I think limits the use of the Datasat (in my case). I was contemplating connecting Datasat to Trinnov MC8 but if this is the case I rather stick to the Rhapsody and save a few $$$$. I won't be able to use the 192 kHz ability of Trinnov...
HT Gear: Altitude 24/32, Quested Lt8 x 11, Paradigm Sub 1, ATI AT6000 Reference, Anthem Statement P5; PJ JVC X9000, PJ Screen: Screen Excellence (Reference)
kamenoff is offline
post #203 of 5199 Old 01-12-2013, 01:41 PM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 403 Post(s)
Liked: 298
There is no 192kHz ability in Trinnov - yet! Still on their "To do" list.
RUR is offline
post #204 of 5199 Old 01-12-2013, 01:47 PM
schlitzie's Avatar
I re-ran Dirac yet again -- Still no subs. The guys at Datasat are looking at my config file, so hopefully they'll see what I did wrong and help me to fix it. Praying it's me and not the hardware!
post #205 of 5199 Old 01-13-2013, 01:08 PM
schlitzie's Avatar
Just a quick update -- We watched Frankenweenie last night even though the bass is not optimal -- And I do have to say that the sound generated by the RS20i with Dirac is phenomenal! Incredible clarity, amazing, seamless separation. There is one part where there is a tremendous amount of activity on the screen, and the datasat's ability to distinctly render the mix of sounds and directions was so engaging it struck me in the midst of it all. Granted it was a 7.1 DTS soundtrack, but I am most impressed.
If I can just get the subs to work I think my head might explode with satisfaction.
post #206 of 5199 Old 01-13-2013, 02:09 PM
DanFrancis's Avatar
Quoted: 44 Post(s)
Liked: 43
I'm sure you're almost there. It's probably something like; "Oh, with x subs you need to..." one of those pointers that never makes it into a manual.
Dan
Dan Francis
post #207 of 5199 Old 01-16-2013, 06:23 AM - Thread Starter
JapanDave's Avatar
Quoted: 171 Post(s)
Liked: 124
Anyone know how to set up the VPN to work on an iPad? Could someone walk me through it?
My build thread
post #208 of 5199 Old 01-16-2013, 07:26 AM
schlitzie's Avatar
Dave --
Download the VNC app to the iPad (I use the original one, not any of the others)
input the RS20i's IP (on the network page) into the app - it will find the RS20i
input the password (it is "-" just the dash!)
It should now be running. It is a little clunky but it works
Mike
post #209 of 5199 Old 01-16-2013, 07:46 AM - Thread Starter
JapanDave's Avatar
Quoted: 171 Post(s)
Liked: 124
Dave --
Mike
Where is the VNC app? Or are you talking about the file that comes with the device? If so, how do you download that to the iPad?
Edit: Never mind , I think I see what you mean.
Edit: I have it working now. Thanks.
My build thread
post #210 of 5199 Old 01-16-2013, 07:53 AM
DanFrancis's Avatar
Quoted: 44 Post(s)
Liked: 43
Mocha Lite VNC works perfectly fine.
Free apple App store
Dan Francis
