Official DataSat RS20i thread. (Setup Tips, Questions,General Info, etc) - Page 76 - AVS Forum | Home Theater Discussions And Reviews
 654Likes
Old 03-01-2015, 08:52 PM
yapota's Avatar
Quoted: 16 Post(s)
Hi All
I need some advice. Since the last software update on the Datasat RS20i, I have been having a lot of HDMI handshake issues between my Oppo 103D and the Datasat. I only pass the audio signal from the second Oppo output suing the spit A/v function. The Datasat does no video processing at all and has nothing connected to the HDMI output connection.
In order to establish the handshake I have had to turn off and on the Datasat a couple of time and then the handshake occurs. I change input to say Apple TV and then go back to the Oppo input it will not switch sound back I have turn the Datasat off again. Since last night its got even worse, I am not getting any sound through the HDMI inputs. The GUI shows No Audio on the upper right hand corner.
I have tried different cables and different sources to no avail. The Optical (Toslink) and Coaxial inputs seem to be unaffected. My delaer commented that the HDMI card is very sensitive to the current being carried via HDMI cables. The dealer thinks the HDMI card will need to be replaced.
I would appreciate any suggestions on things to double check or try to get this working in case its not the HDMI card
Thanks for your help
yapota
yapota is offline
Old 03-02-2015, 01:00 AM
LICENSED TO THRILL
CINERAMAX's Avatar
Quoted: 1888 Post(s)
Liked: 1072
Send a message via Skype™ to CINERAMAX
In realm of the famous video processor people use a lot here, we have heard the subject of cable reflections, where short hdmi cables get some kind of ricochet effect, 2 years ago they said best to use 10 foot long cables, now with 4k they are saying 15 foot longs, try an input cable that long and see if any difference. This has to do with the gain on the MDS input card , they have been creeping up to try guarnatee stability, the reflection could be an issue.
PRETERNATURAL IMMERSOPHILE rAVe Best ATMOS DEMO CEDIA 2016. Most Envied Installation In Europe ( Until July). PREPARING A VERY SPECIAL CEDIA EXPO 2017 DEMO WITH ULTIMATE HDR PROJECTION AND HI-POTENCY ATMOS... OR THREE.WHEN THE LIVING ROOM WALL RIVALS YOUR 100 MILLION DOLLAR VIEW...
CINERAMAX is online now
Old 03-02-2015, 05:58 AM
thebland's Avatar
Quoted: 1529 Post(s)
Liked: 880
Originally Posted by yapota View Post
Hi All
yapota
What handshake issue? No audio? No video?
Goodbye to a great audio and video genius and writer... JOHN GANNON. I enjoyed your friendship, wit and a nice long run we took around Indianapolis at CEDIA years back... and for buying my Runco 980 Ultra years back... you saved my ass! Rest in peace.
thebland is offline
Old 03-02-2015, 07:38 AM
joerod's Avatar
Quoted: 682 Post(s)
Liked: 590
Hi All
yapota
I also use a 103D with my RS20i. Both have the latest updates. I know another owner who had the same issue as yours using a Marantz 7009. Have you updated the 103D recently? Also, to make sure it is not the RS20i I would use just one Hdmi cable from the 103D and connect the RS20i's Hdmi out to wherever you are sending it the image. Also, try another blu-ray player. And lastly you do know you can hit UPDATE on the RS20i and select the source as Main Server. There all the previous updates will appear (about 45 seconds later). You could always as a last resort roll back to 1.03.02 and see if that solves it.
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is offline
Old 03-02-2015, 11:36 AM
JlgLaw's Avatar
Quoted: 83 Post(s)
Liked: 140
Hi All
yapota
These HDMI handshake problems are being investigated by Datasat. There are several of us (probably many) that are experiencing exactly what you described. After many attempts at fixing the problem, it is still a problem. It is likely not your Oppo. I tested it with my Oppo and K Players, and Dish Receiver, and have the same problem with each. Sometimes the audio works on startup, sometimes it does not (and like you, I have to power the RS20i Off and On to get the correct handshake). I have not spoken to Datasat about this recently, but I assume they are still trying to find a fix.
Jim
JlgLaw is offline
Old 03-02-2015, 04:05 PM
Steve Bruzonsky's Avatar
Quoted: 454 Post(s)
Liked: 111
For regular HD Lumagen, etc say 1.5M or 6 foot HDMI cables. As I don't have 4K for my projector,I can't comment on that.
However, I think you might be real surprised. Get the Monoprice 18gbs Redmere cables. Redmere is tech with a computer chip at each end to ensure what goes in goes out. Been using lately for all my HD needs (except for "thick" 24 guage BlueJeans Cable in wall to projector - that would be a pain to replace) and I feel the picture is as good or better than ever. I would be curious if one of these excellent but el cheapo cables might cause your problem. Oh - I am also using one from my Media Server to Theta CBIV over HDMI, and subjectively am of the impression that my multi-channel sonics over HDMI are somewhat better than the BlueJeans thick HDMI cable I had been using.
You mean you don't remember me? Back 1999 - 2003, I started and moderated the AVS Tweaks forum and also the AVS Special Guests forum.
My home theater at:
http://www.avsforum.com/avs-vb/showthread.php?t=1158431
Steve Bruzonsky is offline
Old 03-02-2015, 07:48 PM
yapota's Avatar
Quoted: 16 Post(s)
I only pass the audio signal to the HDMI input in the Datasat. I dont use the Datasat for any video processing.
yapota is offline
Old 03-02-2015, 08:29 PM
davelittle's Avatar
I also have had this HDMI handshake problem with my RS20i, where no audio is heard when you first turn the unit on. I think this is a problem with the RS20i not successfully accomplishing the handshake during its boot sequence. My workaround, rather than rebooting the Datasat every time, is to switch to an analog source prior to turning it off each night. That way, when I power up the RS20i the next day, the source is an analog (non-HDMI) source. After the startup is complete, I switch to my HDMI source (Kaleidescape in my case). It seems to handle the HDMI handshake every time.
davelittle is offline
Old 03-02-2015, 11:31 PM
yapota's Avatar
Quoted: 16 Post(s)
Hi
Thanks for your suggestion there, I shall try it tonight. The frustrating thing is the failure happened exactly at the point when someone who had come round to my place noticed the Datasat and after I had waxed lyrical about its capabalites and sound, the Datasat would not output any sound!!
Quick question. Would your suggestion work with a Toslink (optical) source.
yapota is offline
Old 03-03-2015, 09:39 AM
westmd's Avatar
Quoted: 810 Post(s)
Liked: 277
Hi
The same problem with my LS10 in connection with an OPPO 103D! I had a HDMI 1:4 matrixer which I took out of the chain and using a new 2:4 HDMI matrix/swz. Have way less problems now!
westmd is offline
Old 03-03-2015, 12:48 PM
GGA
GGA's Avatar
Quoted: 231 Post(s)
Liked: 58
Hi
Toslink should be a good choice. You can program the RS20i to go to whatever source you want when you boot up. I forget which menu has the choice, but it is there.
The few times I had a problem with the HDMI handshake (loss of sound) just going into and out of standby fixed the problem (very quick), had no need to power down.
GGA is offline
Old 03-03-2015, 01:57 PM
djnickuk's Avatar
Quoted: 251 Post(s)
Liked: 63
It's really odd all these handshake issues. I run an oppo 93, Apple TV, ROKU, TIVO all hdmi and I don't think I have ever had a single issue. It's been completely stable since I took delivery, probably nearly two years ago now?
But, if you go to Inputs there is a drop down that will allow you to choose what input it switches to when powering on.
djnickuk is offline
Old 03-03-2015, 02:05 PM
thebland's Avatar
Liked: 880
Is the Oppo 103 a consistent player in those with the handshake issues? The 103 is my 'player #1 ' where it is source of choice on power up.
Anyone else?
thebland is offline
Old 03-03-2015, 06:58 PM
stephenbr's Avatar
Quoted: 166 Post(s)
Liked: 74
My experience has been the same as Nick's - never had a problem although my sources are few in only having 2 BD players (a Sony and a Panasonic) and a STB. My downstream hdmi chain is a little more complicated (includes a Darblet, a Lumagen and an 'edge blender/warp processor').
stephenbr is online now
Old 03-03-2015, 10:14 PM
davelittle's Avatar
I heard the HDMI handshake issue revolves around the newest HDMI card Datasat is using. I received my RS20i in December. I'm hoping that the 2.0 HDMI card will solve the problem.
Old 03-03-2015, 11:31 PM
Bassfeen's Avatar
Quoted: 113 Post(s)
There is a HDMI update section in the decoder option I did this and it fixed up my issues now I don't have this problem anymore.
Bassfeen is offline
Old 03-04-2015, 06:01 AM
thebland's Avatar
Liked: 880
I tried that as well... great at first, but oddly, the fix was temporary.
thebland is offline
Old 03-04-2015, 06:23 AM
Wookii's Avatar
Quoted: 1057 Post(s)
Liked: 353
Must admit to never having encountered this issue as far as I can remember on my unit, either with an Oppo 95 or my Kaleidescape Cinema One. Like Nick and Stephen, I bought fairly early on. I'm getting the impression from ready comments above that earlier units may be okay, but later units (which I think were a newer HDMI board) may have this issue.
Wookii is offline
Old 03-04-2015, 08:33 AM
djnickuk's Avatar
Quoted: 251 Post(s)
Liked: 63
I'm glad you have mentioned this as I was not 100% sure if there was another board in newer units, but now you bring it up, for sure it's the newer hdmi boards that must be the issue. Whether firmware can sort it or if the whole MDS board needs replacing I don't know.
djnickuk is offline
Old 03-04-2015, 09:19 AM
Bassfeen's Avatar
Quoted: 113 Post(s)
I think this is a more firmware issue rather than a board. I had to keep turning the Projector on and off to get it to work. When I reported the problem to Datasat the Customer service was fast and the problem was solved quickly. Never experienced it again and it was just a forced firmware update in the HDMI section.
Bassfeen is offline
Old 03-04-2015, 09:43 AM
JlgLaw's Avatar
Quoted: 83 Post(s)
Liked: 140
Same here.
Jim
JlgLaw is offline
Old 03-04-2015, 10:16 PM
LICENSED TO THRILL
CINERAMAX's Avatar
Liked: 1072
Its not really up to Datasat, I think one of the guys at Momentum Data Systems is Bruce Macaglia, or he may be the east coast guy(did quite a bit of 3d debugging with him). There are two guys at MDS that are responsible for fielding bugs from all manufacturers, a highly unenviable job description.
Old 03-05-2015, 02:04 AM
yapota's Avatar
Quoted: 16 Post(s)
Hi
My Datasat was purchased in July 2013 so would that have the old HDMI board or new HDMI board. The HDMI board has the latest software.
yapota is offline
Old 03-05-2015, 09:57 AM
djnickuk's Avatar
Quoted: 251 Post(s)
Liked: 63
Hi
Pretty certain that you have the old board, same as mine.
djnickuk is offline
Old 03-05-2015, 10:09 AM
thebland's Avatar
Liked: 880
Do all users with issues have a Oppo 103? Seems like it from what I've seen here..
thebland is offline
Old 03-05-2015, 10:14 AM
JlgLaw's Avatar
Quoted: 83 Post(s)
Liked: 140
Yup, Datasat was not able to duplicate the handshake issue with the older boards, even suggested I change back to the old board. I declined and said I'd wait for the fix. Apparently the older version does not have this problem.
Jim
JlgLaw is offline
Old 03-05-2015, 10:18 AM
djnickuk's Avatar
Quoted: 251 Post(s)
Liked: 63
Jim
Yeah I have put all kinds of HDMI sources into mine, live swapping as well. And even my really dodgy hdmi pc works absolutely fine.
So clearly an issue between the new board and the 103d.
djnickuk is offline
Old 03-05-2015, 10:30 AM
thebland's Avatar
Liked: 880
My Oppo 103D is n HDMI 1 and is the start up source.
I might switch around and have another BD player be the start up player...
For those having issues, does this start up always occur when powering up the OPPO? Not other sources?
thebland is offline
Old 03-05-2015, 12:48 PM
JlgLaw's Avatar
Quoted: 83 Post(s)
Liked: 140
My start up problems exist with any HDMI source (for me, that's a Kaleidescape Player, Oppo, and Dish Receiver). Regardless of the source, the RS20i will only work correctly on start up 50% of the time. That also makes it more difficult to determine the problem, there is no single source or start up process that causes the problem.
Jim
JlgLaw is offline
Old 03-05-2015, 12:58 PM
djnickuk's Avatar
Quoted: 251 Post(s)
Liked: 63
Jim
Have you tried changing your startup to one that is a non hdmi source?
djnickuk is offline
