Official DataSat RS20i thread. (Setup Tips, Questions,General Info, etc) - Page 84 - AVS Forum | Home Theater Discussions And Reviews
 80Likes
post #2491 of 2495 Old 07-01-2015, 10:01 PM
IMMERSION GURU
CINERAMAX's Avatar
Quoted: 518 Post(s)
Liked: 162
Originally Posted by Lasalle View Post
Does anyone know if Datasat has committed to supporting Dirac Unison? I understand Dirac Unison is do to be released in the next year and unlike Dirac live it will optimize multiple subs discretely on separate channels. The challenge with that is it takes channels so a Atmos 9.1.6 becomes a 7.4.4. The current base management on the RS20i will mix the LFE into the L,R,Ls,Rs if they are set to large and base management is set to no subs. If you crossed over 4 subs with full range speakers on those channels would Dirac Unison's bass management handle them optimally
(and effectively change the channel capability from 15.1 to 16.4)?
Hi Brad, good questions, will ask their techs. If it has to treat each 4 as a channel quite a trade-off. If by adding an expansion card just for the bass I would be happy.
Lasalle likes this.
CINERAMAX is online now
post #2492 of 2495 Old 07-02-2015, 12:26 AM
mhafner's Avatar
Quoted: 29 Post(s)
Liked: 32
Originally Posted by CINERAMAX View Post
That was my original idea but alas wrong for 1 (for 2 should be right.:-)). For 1 You need to net furthest distance MINUS closest speaker distance differential to plug figure.
The farthest speaker has 0 delay. The others according to difference to farthest relative to listening position. Should work correctly.
mhafner is offline
post #2493 of 2495 Old 07-02-2015, 01:20 AM
Wookii's Avatar
Quoted: 291 Post(s)
Liked: 63
Just be aware physical distances don't work for subs generally, measured distances using REW are best.
Wookii is offline
post #2494 of 2495 Old 07-02-2015, 02:06 AM
mhafner's Avatar
Quoted: 29 Post(s)
Liked: 32
(Very) Low frequencies are not delay sensitive, are they?
mhafner is offline
post #2495 of 2495 Unread Today, 07:28 PM
The Bogg's Avatar
Quoted: 182 Post(s)
Liked: 72
Many subs have dsp in their amps which introduces delay that can affect the blend with the other speakers at crossover frequency if not accounted for.
Design by Rives...dollars by The Bogg
Click for my build thread
The Bogg is online now
