Spec an Audiophile PC With Me Using CAPS 3.0 as a Starting Point, Adding HDMI for Multi-Channel Hi Rez Audio!!! - Page 26 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
Old 06-06-2014, 06:09 AM
edorr's Avatar
Quoted: 41 Post(s)
Liked: 26
Originally Posted by 3ll3d00d View Post
There are some new scripts around this problem that might be worth a try
http://yabb.jriver.com/interact/index.php?topic=89627
This looks interesting. I'm going to give this a try. I have about 15 concert BRs that are non DTS HD that I need to create particles for.
edorr is offline
Old 06-29-2014, 04:58 PM - Thread Starter
Steve Bruzonsky's Avatar
Quoted: 439 Post(s)
Liked: 101
Thanks to Bulldogger for telling me how a friend of his is finding the Linksys WRT1900AC fantastic for streaming, etc.
I have a gigantic home, very extended main floor west to east (theatre at very east), home office upstairs just north and up from living room (at center of home), and basement below the west part of the main floor.
I had been using Monster Cable powerline and Apple Airport Express stuff, all wireless N, not the newer Gigabit. Had issues streaming 1080p video in my theater.
For my Media Server I have both USB drives (2) and also Western Digital network server (WDMyCloudEX4 16TB).
So long as I install the Western Digital software onto the media server in my theatre room, JRiver Media Center 19 works fine, even on multi-channel SACD ISO files. The WD software does a better job of recognizing and utilizing the WDMyCloudEX4 network drive than does the standard Windows 8.1 Pro software in my Media Server, apparently. But even so, stuff can load a bit slowly at times.
Just got done installing a Linksys1900AC system. Due to size of home, using one Linksys1900AC router as the router in upstairs home office. An ethernet cable thru walls and attic to west main floor hooks up to another 1900AC on a closet at the very west main floor, with that 1900AC programmed as an access point. And I have a Linksys PLEK500 Homelink AV,
which uses home wiring, one in upstairs office, one in theatre, because the wireless signal from my office upstairs router
is very weak at 2.4GHz and no signal at all for 5.0 GHz, but using the PLEK500 the signal is very strong. And then in my theater a 3rd 1900AC used as an access point as well.
Throughout my home, we are getting 35 - almost 50 mbps.
So EDORR, now no excuse for you not to go wireless to your media server.
And after spending more time recently listening to USB connected, vs wireless over my new speedy Linksys wireless, I think that the wireless is more "open", dynamic, better clear voices, etc - though the wired USB is darn good.
You mean you don't remember me? Back 1999 - 2003, I started and moderated the AVS Tweaks forum and also the AVS Special Guests forum.
My home theater at:
http://www.avsforum.com/avs-vb/showthread.php?t=1158431
Steve Bruzonsky is offline
Old 06-29-2014, 05:49 PM
edorr's Avatar
Quoted: 41 Post(s)
Liked: 26
why would I? I have cat 5 from my router into my basement, which works fine. Don't fix it if it aint broken.
edorr is offline
Old 06-30-2014, 08:37 AM
PeterS's Avatar
Quoted: 124 Post(s)
Liked: 41
Sound quality-wise:
Wired Gigabit (Best)
Wireless AC (OK)
USB (Worst)
Ok, the differences are not major, but if you have a really high-end system, they are noticeable. We have done a lot of testing of this at Blue Smoke. Just as we have tested playback from the various lossless codecs.
WMA Lossless (Best)
FLAC (OK)
Apple Lossless (Worst)
Done double-blind on several occasions, with the same results. Differences are again small, unless you have a really good system, but they are there.
"Read Less, More TV." - Dr. Gregory House
"That which can not be questioned, can not be trusted." - Me
The Metropolis Home Theater
Blue Smoke Entertainment Systems - Affiliated
PeterS is offline
Old 06-30-2014, 09:29 AM
justin42's Avatar
Quoted: 24 Post(s)
Originally Posted by PeterS View Post
Sound quality-wise:
WMA Lossless (Best)
FLAC (OK)
I can understand why there are differences in how the data get to the DAC based on bandwidth etc. (I would expect a gigabit wired connection to fair better than wi-fi in almost all cases). But can you explain how WMA and FLAC could possibly differ in sound quality? Assuming that a well-spec'd PD (like the CAPS 3.0 rig discussed in this thread) is being used?
justin42 is offline
Old 06-30-2014, 10:20 AM
PeterS's Avatar
Quoted: 124 Post(s)
Liked: 41
You have to first understand that LOSSLESS does not equal LOSSLESS when it comes to audio playback. When you are looking at static file contents, they all decode to the same exact, lossless data. Thus you can easily move the data back and forth between these formats without loosing any information. However, when playing back audio you have to remember that there are other factors involved. These are primarily TIME and CPU LOAD.
CPU LOAD is the easiest to understand. The more the CPU works the greater the thermal noise of the CPU. This thermal noise permeates the system and affects the noise-floor of the audio output. Removing it can be difficult. However, it will only be noticeable as a collapse of space, sustain, etc. You do not experience this the same as you do noise as in the SN ratio.
The other factor it TIME. How long does the codec take to decode? Is it symmetrical or asymmetrical in its encode/decode? Does it introduce "jitter" into the stream? Etc. You can reduce jitter through a variety of means, such as buffering and re-clocking (though you can not truly eliminate it). The problem is that the clock in the PC is generally a division of the Master Clock used by the CPU, and not nearly available or accurate enough for our use. WMA Lossless uses less CPU and we have found is much better. FLAC lets you determine the amount of compression at the encode - more requires more CPU to decode and thus worse sound. Apple Lossless is a mess in this area.
We have done a lot of experimenting and work on many $100k systems and have worked with MSB to develop the 384/32 digital output device for the PC, MAC and Linux to get around many of these issues. It is a completely external sound-device with a high-precision clock of its own. However, even then, these issues will and do affect the sound-quality in an audible fashion. You just have to have a system capable of resolving such fine detail.
PeterS is offline
Old 06-30-2014, 10:25 AM
justin42's Avatar
Quoted: 24 Post(s)
I am curious to hear others' thoughts on this. With as inexpensive as storage is, I have still yet to see a high-end server (Meridian, Bryston, etc.) that advocates .wav over .FLAC.
I buy noisy power supplies affecting sound quality, and of course an under-powered computer with present problems. Again, just my thoughts.
justin42 is offline
Old 06-30-2014, 12:33 PM
Glimmie's Avatar
Quoted: 732 Post(s)
Liked: 596
How exactly does "thermal noise* permeates the system?" Yes the thermal noise increases as the CPU gets hotter but do you realize how small that is in relation to all the other RFI inside of a PC? What would concern me more is the spectrum content of RFI changing as the CPU runs through the code instructions. This will be clearly more measurable and possibly detrimental to the recovered audio signal. That is of course only possible if it has an influence on the analog section of the DAC. A DAC inside the computer case is surely a good candidate for this degradation. But an externally wired DAC is not so likely. Especially with an Ethernet network connection that is transformer coupled.
This has been discussed before. It doesn't matter how accurate the clock in a DAC is made. You still have to lock to the incomming audio stream. Now you can buffer the data and put a low pass filter in the DAC clock PLL which many devices do. But there will still be drift.
Noise is easily measured these days. Rather than get this $100K audio system why can't we see some quantified measurements before and after these suggested upgrades? Surely such data would be much more valuable to sell a product versus these faith based performance reports.
* P.S. I know thermal noise well working for a time with microwave RF. Why are commercial satellite dishes always painted white? Why are sensitive antenna preamps measured in degrees kelvin for S/N versus a db ratio? It seems that once again the audiophile accessories market has read some engineering paper mentioning thermal noise in a system and blindly applied the theory and practice to high priced consumer audio.
Glimmie is offline
Old 06-30-2014, 01:01 PM
Glimmie's Avatar
Quoted: 732 Post(s)
Liked: 596
But consider how low in terms of modern bandwidth numbers even 192k audio is. It's a walk in the park getting that into a DAC even over a commodity WiFi system. People stream HD video at 10-20mbs over home WiFi networks these days without incident. Streaming compressed audio is even less of an issue.
Now I too like hard wired networks for reliability reasons. But other than data loss (dropout) due to outside traffic or RFI, I don't see why there would be any difference in audio quality, especially with compressed data. But I do understand there are marketing interests that want you to think there is.
Glimmie is offline
Old 06-30-2014, 01:08 PM
justin42's Avatar
Quoted: 24 Post(s)
Originally Posted by Glimmie View Post
But consider how low in terms of modern bandwidth numbers even 192k audio is. It's a walk in the park getting that into a DAC even over a commodity WiFi system. People stream HD video at 10-20mbs over home WiFi networks these days without incident. Streaming audio is no big deal.
But I do understand there are marketing interests that want you to think it is.
I was being a bit diplomatic. What I meant to convey was that, at least in theory, I see how there could be bandwidth issues that would make a wired connection sound better than a lousy wi-fi connection. But I can't for the life of me fathom how a .wav, .wma, and .flac could sound any different (assuming there we no read errors and the lossless files were generated from the .wav).
I guess we all have different tolerances for this kind of stuff; I for one have spent a fair chunk of change on cables and know some folks think I'm an idiot for it. But when I hear arguments about one file format being worse than another, my eyes glaze over. I was going to drop a few grand on a new amp at a local dealer, but in the course of describing my system to him I mentioned that my collection was all in lossless .flac. He then proceeded to lecture me about how it wasn't really "lossless," but was "loss" "less" as in, less loss-y. I don't mind being lectured, but he lost all credibility in my mind and I took my $$ elsewhere.
Again, this is not intended as a criticism on those who hear a difference in the file formats; just doesn't make any sense to me.
justin42 is offline
Old 06-30-2014, 01:15 PM
Glimmie's Avatar
Quoted: 732 Post(s)
Liked: 596
.....What I meant to convey was that, at least in theory, I see how there could be bandwidth issues that would make a wired connection sound better than a lousy wi-fi connection......
Why? Yes the WiFi connection may drop out or limit bandwidth based on traffic but how would that change the sound quality? If the buffer in the receiving device runs out, the audio stops, you get at a minimum a hit or gap.
Any idea that a wired network has a "better sound stage", "deeper inner spacing", "darker noise floor", or other popular audiophile lingo is bunk! And even more so with compressed data. If there is any corruption the the FEC can't undo, you get completly invalid data. Compressed data is either right or it;'s not. Toggeling a LSB in PCM can certainly cause some audible distortion. But in a compressed file, it's disastrous if beyond the error correction system.
Glimmie is offline
Old 06-30-2014, 01:17 PM
justin42's Avatar
Quoted: 24 Post(s)
Why? Yes the WiFi connection may drop out or limit bandwidth based on traffic but why does that change the sound quality? If the buffer in the receiving device runs out, the audio stops, you get at a minimum a hit or gap.
That's what I was referring to; drop-outs, stutters, etc.
justin42 is offline
Old 06-30-2014, 01:22 PM
Glimmie's Avatar
Quoted: 732 Post(s)
Liked: 596
OK I agree, that is poor "sound quality". But in reading above there are others that don't believe in such a simple explanation.
Glimmie is offline
Old 06-30-2014, 03:11 PM
PeterS's Avatar
Quoted: 124 Post(s)
Liked: 41
The interesting part is that this debate will rage on forever. I come from a "logical" computer engineering background and would agree with almost everything here, except that I haves indeed heard the differences on high-end equipment.
Now if you like what you have and it sounds good to you, that should be enough. The reason WAV is not promoted by these companies is that they want to promote that number of songs they can store, and WAV would limit that entirely - oh, and the mass bulk of their audience does not have the equipment or ears to notice the difference anyway.
In the end, it is about music, not technology. Whatever makes you happy - wether you believe or not it not important.
PeterS is offline
Old 06-30-2014, 03:23 PM
Glimmie's Avatar
Quoted: 732 Post(s)
Liked: 596
I don't have an issue with the idea that *.wav sounds different or better than *.flac. It's all the other noise and jitter FUD. Now if someone can show us a proper test outcome where the noise induced by fans, heat, mediocre digital side power supplies, makes a difference then it does deserves further consideration. The next step is if this measured noise/distortion is in fact audible in the listening environment.
If the products one promotes or reviews here are indeed worthy of the claims, then the manufacture should be proud to show the measured performance increase. And let's not get into the old "proprietary information" rag. I am simply asking to see the results of competent testing, I am not asking anyone to disclose how they achieved the results - which is the proprietary part.
So far I have not seen such evidence presented in this thread, and to be clear I mean quantified measurements. Not artist illustrations or scope captures with the time and voltage scales missing. That generally rules out most audiophile magazines.
Glimmie is offline
Old 06-30-2014, 03:47 PM
justin42's Avatar
Quoted: 24 Post(s)
We obviously come from very different technical backgrounds (as in, you have expertise and I have none!), but to me this is the hardest part to grasp. Power supplies, etc. sound at least plausible in terms of affecting sound quality. But the idea that you can rip a track to .wav and then compress that same file to a .flac and a .wma and have all three sound different? Do not get that at all. Obviously some bias of mine is creeping in because I spent a long time ripping 600 CDs to lossless .flac because every single person I talked to told me SQ was identical to .wav.
Then again, I have a $25k system, so it's probably not resolving enough to matter
justin42 is offline
Old 06-30-2014, 04:10 PM
Glimmie's Avatar
Quoted: 732 Post(s)
Liked: 596
Don't kid yourself, a $25K system is more than good enough to resolve the differences being discussed here.
That's just what gets thrown in your face when some expensive accessory you buy doesn't deliver what was claimed. "It's not burned in yet", which translates to owning it longer than the return period, is another.
Glimmie is offline
Old 06-30-2014, 04:12 PM
justin42's Avatar
Quoted: 24 Post(s)
I guess that brings me back to my original question: putting aside all of the talk about jitter, power supplies, thermal heat, etc... Did I (and many many others) made an unnecessary compromise on sound quality by opting for .FLAC instead of .WAV when converting our collections to digital?
justin42 is offline
Old 06-30-2014, 04:19 PM
Glimmie's Avatar
Quoted: 732 Post(s)
Liked: 596
I don't have any experience comparing the two but as .flac is still compressed, there's a chance something is lost.
It's easy though to prove this. Just make a .flac copy then decompress it back to .wav. Do a file compare. If there is any difference whatsoever, even 1 single bit, it will be found. But that still says nothing as to the change being audible or not.
I'm sure this has been done by now. Google it.
P.S. Note too that there is a difference in the marketing terms "lossless" and "mathematically lossless". The file compare above will prove if the compression process is mathematically lossless. But even if it fails, the compression still could be lossless audio wise as human hearing is, well rather poor from what I have read.
Glimmie is offline
Old 06-30-2014, 06:01 PM
edorr's Avatar
Quoted: 41 Post(s)
Liked: 26
I compared flac and wav on a six figure system and could not hear a difference.
edorr is offline
Old 06-30-2014, 06:09 PM
PeterS's Avatar
Quoted: 124 Post(s)
Liked: 41
For all of those who do not hear a difference. I would invite you to our listening room in Chicago to hear the variance between the different codecs (all used in J. River) and in a blind listen tell me what you think you hear.
I don't wish to belabor the point, but I was once where you are now, and was very much of the mind that any difference was impossible. But, I've heard it.
PeterS is offline
Old 06-30-2014, 06:36 PM
edorr's Avatar
Quoted: 41 Post(s)
Liked: 26
I did blind comparison on my system between flac and wav of the same track in Jriver. Could not hear a difference.
edorr is offline
Old 06-30-2014, 08:26 PM
justin42's Avatar
Quoted: 24 Post(s)
I may take you up on that next time I'm in the area. I will also do my own test at home.
By the way, I wasn't trying to single you out and I respect your view and experiences. And I am obviously coming from a somewhat biased position because I don't want to feel like I have to re-rip my entire collection AGAIN...
justin42 is offline
Old 06-30-2014, 08:34 PM
edorr's Avatar
Quoted: 41 Post(s)
Liked: 26
You can batch convert your flacs to wav. It is like unzipping data files. If you hypothesize that the real time unzipping degrades the sound, this would be the ticket. You get the exact same bits as reripping.
edorr is offline
Old 06-30-2014, 08:37 PM
justin42's Avatar
Quoted: 24 Post(s)
Good point.
This is worth a read: http://www.computeraudiophile.com/bl...l-results-155/
justin42 is offline
Old 07-06-2014, 03:27 PM
stevekale's Avatar
Quoted: 365 Post(s)
Liked: 43
Man, give me some of that stuff PeterS is smoking! If a file is loaded in memory prior to playback and converted to LPCM in memory prior to playback, how can the container it was in make a difference? CPU load? Give me a break. My audio server barely registers activity playing multichannel SACD iso converted to multichannel LPCM let alone simple 44.1kHz stereo.
On a more interesting note, did anyone notice that JRemote no longer allows playback of DVD ISO? Today I had to remote onto the pc with VNC viewer to play a DVD. one other annoying thing I have with JRiver DVD iOS playback is that often I a small screen within my display ie large borders all round rather than just top and bottom. Ideas?
Demand greater honesty and transparency in high-end audio
With Theta, Egglestonworks and Krell since 1998!
stevekale is offline
Old 07-26-2014, 05:35 PM
Bulldogger's Avatar
Quoted: 204 Post(s)
Liked: 46
While I can not hear it on my own system with Jriver. A friend shocked me when I could clearly hear it on his set-up. I was 110% percent convinced there would be no difference but entertained him anyway. There was a difference. I got home but could not hear it on my system. Not sure what is going on.
Never become so involved with something that it blinds you.
Bulldogger is offline
Old 07-26-2014, 06:17 PM
Bulldogger's Avatar
Quoted: 204 Post(s)
Liked: 46
As I said I'm done troubleshooting and exchanging htpc war stories. I'm counting my losses, writing another check and expect a fully functional MCH and video capable machine. Then I hope installing Dirac won't blow it up. If it does, I'll pick up bridge as my new hobby.
Edorr, I thought about you the entire time I was build my HTPC. I did have some some set-backs. Novice, I damaged the CPU socket pins and had to pay 125.00 for a repair. Also, I bought a 500 watt power supply which was too small to run my GPU. The result was a damaged GPU, about a 250.00 loss after I sell everything for parts.
The good news is that I am thrilled with the performance that I am getting. The picture quality is awesome. I switched to a 1200 watt power supply with a fan to run an Asus R9 290x Directcu II GPU. The fan only comes on if it reaches a certain temperature. I've watched the fan, and even at 100% GPU usage, it has not been on once. Seasonic Platinum 1200.
The Prolimatech MK-26 GPU cooler with Prolimatech ULV14 fans is silent to my ears. I tested it just 2 feet away, with cover off and can not hear the fans. Now, I am not in a sound proofed room like my old set-up so that may change when I reduce ambient noise. I would be surprised as the distance that will be increased. For those without specially built walls, I can not fathom how you will be able to hear the fans. I guess some could hear the fans if their hearing is better than mine and they are able to pick out a less than 9db sound with typical 40db ambient noise present. I absolutely can not hear them. They are spinning at like 375 rpm which is like 9db or less. The fans are rated at 9db at 500 rpm. I am using GPU-Z to monitor the R9 290x.
I will do a shoot out with an Oppo 103 in a week or so but feel it's colossal waste of time. The madVR appears to be superior even with 1080p as it still offers improved chroma upsampling. When I switch back and forth between RO standard and the RO with madVR, nneid, with 1080i material the difference is pronounced. We will see how I feel after a direct shoot out. A buddy wants to see it so I'll go forward.
I think my first foray into 4K my just be a monitor for my desktop. That monitor should give me an idea how good madVr will be at upscaling 1080p to 4k and how powerful a GPU will be required.
Again my build is Asus Hero VII, Intel i7 4790k CPU, 16gb Kingston 2400mhz ram, Plextor M6e m.2 SSD http://www.plextoramericas.com/index...m2/m6e-m2-2280
Seasonic Platinum 1200 watt power supply with hybrid fan, basically fanless at my power levels, Nofan CR-95 fanless CPU cooler and Silverstone CW-02 case.
Old 07-26-2014, 07:10 PM
edorr's Avatar
Quoted: 41 Post(s)
Liked: 26
I'm all sorted out with the new MCH server with Lynx and HDMI card. Still use the CAPS 3.0 for 2 channel. Works beautifully. I run Dirac on both machines. For good measure, I also replaced my MSB + 2 x NAD m51 DACs with 3 x PS Audio Directstream, and my Arc Ref 5SE and class A monos, with all spectral amplification. I literally have 100s of hours of ripped MCH content (SACD, Blu Ray, DVD-A, DVD) to rediscover. I'm done with hardware swapping in in full content enjoyment mode. The MCH Server sits behind the rack.
Name:	system July 2014_05.JPG
edorr is offline
Old 07-28-2014, 07:57 AM
Glimmie's Avatar
Quoted: 732 Post(s)
Liked: 596
I finally made the JRiver plunge about two weeks ago. I was using an older version of VLC linked to CollectorZ for my DVHS rips and a Pioneer Elite for blurays.
Intel i3
Win7/32 pro
Gigabyte MB
1GB RAM
Nvidia FX3800 SDI (using standard Red October)
Lynx AES16
DVHS rips use the motherboard SPDIF to my Lexicon MC8. BluRay rips are direct from the Lynx AES16. I use a zone switch based on the file type.
BluRay rips look very good, as good or better then the Elite player. But when I play a 96khz file, I get dropped frames. Probably that i3 and the 1GB RAM. I am planning to go to an i7 and 4GB RAM.
I'm not so sure of My DVHS rips which are all 1080i. I think VLC was a bit smoother motion wise. The old version of VLC I was running is said to be the best for interlaced material per their forum. But in any case, the library integration and remote control facilities are so good as compared to the VLC/CollectorZ kludge, I am willing to let the DVHS rips quality slide a bit. It may be the same too, I just need to do some more A/B tests. Could also be the change from a Nvidia FX4000 to FX3800 as the old 2006 vintage FX4000 would not run properly on Win7.
No SD DVD yet. I still use my TVedia & Sigma Xcard combo. But I plan to try RO HQ.
Glimmie is offline
