Multichannel SPDIF & Vanity - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 08-21-2013, 11:42 AM - Thread Starter
Glimmie's Avatar
Quoted: 725 Post(s)
Liked: 591
I know the new trend is for mod shops to install 5.1 or 7.1 SPDIF outputs on BluRay players.
But what consumer gear actually inputs multichannel SPDIF? Let me be specific here, the Trinnov for example does not. It asks for AES, not SPDIF.
In the pro world, at least on the video side, I have never seen a device with multi SPDIF inputs. It's always AES.
My point is why don't these mod kits output true AES-3 which is still 75ohms unbalanced. Or if the majority of gear is 110ohms balanced, then supply that. The design of the interface circuits is the same, just a few component value changes, that of course assumes the SPDIF mods are transformer coupled. If not, then they are off to a bad start anyway.
I realize AES-3 and SPDIF are usually interchangeable, but there are voltage differences and sometimes that will bite you. SPDIF was intended for consumer single channel interconnection (2 analog channels). If these mod kits are touting superior performance, shouldn't they at least conform to proper electrical engineering standards in the interface? It's kind of silly how a lot of folks ooh and ahh over the Vanity to Trinnov combination yet the interface is kludged.
For what the Vanity costs, it wouldn't be that much more to add a compliant 25pin AES port as well.
And while your at it how about a dip switch or jumper to set the channel status bit between pro and consumer. This is easily implemented inside an FPGA architecture. My DIY AES BluRay mode has this.
ceenhad likes this.
Glimmie is offline
post #2 of 19 Old 08-21-2013, 11:49 AM
thebland's Avatar
Quoted: 1490 Post(s)
Liked: 841
Could you simply add a 25pin AES port to an Oppo, for example, and forget the SPDIF mod all together?
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is offline
post #3 of 19 Old 08-21-2013, 01:00 PM
edorr's Avatar
Quoted: 41 Post(s)
Liked: 26
I think it is a form factor issue. The Vanity93 board fits nicely into the player, and actually uses the RCAs of the existing analog outputs on the back panel for the digital S/PDIF outputs. Not very practical considering all processors have AES/EBU I agree.
The only processor I'm aware of that could be connected S/PDIF to S/PDIF is the Meridian. These are now supposed to be fed an encrypted signal from the HD621, but an Oppo with Vanity or JVB board would work also.
edorr is offline
post #4 of 19 Old 08-21-2013, 01:43 PM - Thread Starter
Glimmie's Avatar
Quoted: 725 Post(s)
Liked: 591
Well here's what I would do:
There is room on the back of most BluRay players for a 25pin D connector. They make 25d punches, I have one.
Put a 26p header connection on the Vanity board with the balanced AES.
Use a ribbon cable to go from the Vanity board to the chassis mounted connector.
Make addition of the 25p D connector optional but at least the board has the connector and the hardware to support it. You can keep the SPDIF jacks too. Both outputs can be active at the same time.
Note that I use a high density 15p connector (analog VGA connector) for this application. But as there is a 25p Tascam standard 25p does make more sense if there is room.
P.S. In case anybody chokes on the idea of ribbon cable, it's approx 100 ohms between adjacent wires. Not that it matters for 12 inches at these frequencies, but the cheap old computer ribbon cable is actually well matched to AES cable impedance wise.
Glimmie is offline
post #5 of 19 Old 08-21-2013, 01:57 PM
noah katz's Avatar
Quoted: 880 Post(s)
Liked: 304
How much do they cost?
Noah
noah katz is offline
post #6 of 19 Old 08-21-2013, 02:16 PM
edorr's Avatar
Quoted: 41 Post(s)
Liked: 26
Full feauture (reclocking and custom DSD conversion) = $1000. LITE (just pass through) = few hundred.
edorr is offline
post #7 of 19 Old 08-21-2013, 06:53 PM
Larry Ng's Avatar
We can install the Vanity board by ourselves , that is not difficult with clear instruction , if you add 25 pins D connector , you need to drill a hole on the back and that is one thing not everyone could do . We probably do not want to send the Oppo to Audiopraise as that is way too costly ! .
Larry Ng is offline
post #8 of 19 Old 08-21-2013, 08:30 PM
Kal Rubinson's Avatar
Quoted: 673 Post(s)
Liked: 460
It does.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #9 of 19 Old 08-23-2013, 03:53 PM
Nyal Mellor's Avatar
Quoted: 435 Post(s)
Liked: 312
It's a very good point and I have wondered the same thing myself.
I wonder if the designers were thinking Oppo to multiple 2 channel DACs mainly for surround music?
As an alternative you could just build a small quiet HTPC and use that to play blu-rays. Stick a Lynx card in and you have 16 channels digital out on a DB26.
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is offline
post #10 of 19 Old 08-23-2013, 04:03 PM - Thread Starter
Glimmie's Avatar
Quoted: 725 Post(s)
Liked: 591
You know I am considering that since I have all my DVHS movies already in a server.
Questions:
1) Does the JRiver software decode all the standard multichannel CODECS?
2) Legality issues aside, can a BluRay be ripped into a server with playback software that still "feels" like a hardware player? I need to interface it to Irule and some playback softare like VLC which I use for my DVHS dumps is not very remote friendly.
3) I need HDSDI output so I would like to use a Nividia FX5500-DI card i have. HDMI with HDCP is no good for me. Again I am not pirating stuff.
Barring questions 2 & 3, is there good HDMI/HDCP raw disk (original BluRay disk, not ripped) player software that works with JRiver?
TIA
Glimmie is offline
post #11 of 19 Old 08-23-2013, 04:23 PM
edorr's Avatar
Quoted: 41 Post(s)
Liked: 26
Questions:
TIA
Nyal has spec'ed out this configuration here:
http://www.acousticfrontiers.com/home-theater-blog/2013/6/6/how-to-replace-your-home-theater-pre-pro-with-a-htpc
I have only ripped one blu ray as a proof of concept and played it in Jriver, which worked fine. However, Nyal can probably tell you much more.
edorr is offline
post #12 of 19 Old 08-23-2013, 04:31 PM
edorr's Avatar
Quoted: 41 Post(s)
Liked: 26
I doubt it, since volume control would be a problem in this setup (I guess you could use the Oppo digital VC).
edorr is offline
post #13 of 19 Old 08-24-2013, 10:35 AM
edorr's Avatar
Quoted: 41 Post(s)
Liked: 26
Originally Posted by Kal Rubinson View Post
It does.
Kal, I presume you will be using the Meridian 861 to assess the difference between an HDMI based signal path (using HD621), a 4 x S/PDIF direct from player signal path (using Vanity103 and/or MSB UMT - once you get your hands on these units), and possibly switching everything into your ARC MCH preamp to allow comparison with analog output from player (Oppo 105?) signal path?
edorr is offline
post #14 of 19 Old 08-24-2013, 05:05 PM
Quoted: 673 Post(s)
Liked: 460
Umm. Yeah.
Kal Rubinson
post #15 of 19 Old 08-24-2013, 09:51 PM
noah katz's Avatar
Quoted: 880 Post(s)
Liked: 304
That's quite reasonable, thanks
Noah
post #16 of 19 Old 08-25-2013, 12:47 PM
Peter Nielsen's Avatar
Tact TCS MK3 does this for sure. When I had my TCS I was feeding it with quad S/PDIF. I believe the Datasat RS20 also allows for this, and so does some Goldmund gear...
Oh, and the BSS Soundweb London Architect BLU-160 with digital input cards will do it, which means the JBL Synthesis SDEC-4500P should be capable of it if you swap out the analog input cards for digital ones...
Peter Nielsen is offline
post #17 of 19 Old 08-25-2013, 01:58 PM
djnickuk's Avatar
Quoted: 248 Post(s)
Liked: 62
The RS20i has the same multi channel digi inputs as the Trinnov units. AES/EBU. But you can run spdif into these inputs so long as the cables used are not too long or you go thru a converter.
djnickuk is offline
post #18 of 19 Old 06-17-2015, 07:44 PM
noah katz's Avatar
Quoted: 880 Post(s)
Liked: 304
I've got a Vanity Lite 103/103D board for sale in the classifieds.
I got it from Lon to use with my Optimizer, but never got around to installing it and since then I got an Atmos pre/pro.
Noah
post #19 of 19 Old 06-28-2015, 10:50 PM
rabident's Avatar
Quoted: 333 Post(s)
Liked: 107
Does the 103D's built in volume control work over the AES outputs?
Does the SDEC-4500 have volume control for its analog outputs?
rabident is offline
