Screen Inovations zero edge gray screen compatibility question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-14-2013, 08:14 PM - Thread Starter
08-450dually's Avatar
Greetings, haven't been lurking for a while but thought I'd pose this question here.
I have a Sim2 C3X "e", T2 lense (like the one Alan Gouger has/use to have), its the 720p and was wondering if it would be a mistake to purchase the Screen Inovations Pure Gray screen (0.85 gain I believe) with this projector or would I be better off with the pure white? It is a light controlled room and 1.8 screen width viewing distance.
thank you in advance
08-450dually is offline
post #2 of 6 Old 09-16-2013, 12:27 AM - Thread Starter
Hmmm........
post #3 of 6 Old 09-16-2013, 12:48 PM
Pete's Avatar
Quoted: 219 Post(s)
Liked: 79
How big is the screen?
Pete is offline
post #4 of 6 Old 09-17-2013, 12:00 AM - Thread Starter
16:9 120inch diagonal
post #5 of 6 Old 09-17-2013, 02:04 PM
Pete's Avatar
Quoted: 219 Post(s)
Liked: 79
.85 might be pushing it on that size and with that projector. You'd be better off with a bit of positive gain rather than negative gain....1.1 to 1.3.
Pete is offline
post #6 of 6 Old 09-18-2013, 02:29 AM - Thread Starter
Thank you so much! I will stay away from gray screen. Hope you have a great day!
Jaime
