system protection - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-29-2013, 05:44 AM - Thread Starter
kenh's Avatar
What type of surge/brown out protection do you use for your audio/video system? My system consists of a Lex MC12, Martin Logan speakers and subs and Jvc Projector, VPI turntable, Oppo DVD/cd player. tuner and phono stage. My amps are Brystons which i am going to plug into a 20amp dedicated circuit. if you can me some ideas i would really appericate it. thanks
kenh is offline
post #2 of 7 Old 10-29-2013, 11:05 AM
Brucemck2's Avatar
Quoted: 70 Post(s)
Liked: 36
Nail all the inbound points and "layer" up your protection; multiple companies offer well engineered protection:
I use these pretty extensively, at the panels and for multiple entry points:
http://www.surgepack.com/
These too work fine:
http://mcgsurge.com/applications/house.htm#Main_AC_Panel_%281%29
I also use these:
http://www.richardgrayspowercompany.com/connect.html
http://www.richardgrayspowercompany.com/surge.html
I also use various devices in/near my racks, but those don't replace any of the above
Brucemck2 is offline
post #3 of 7 Old 11-11-2013, 09:43 AM
scanido's Avatar
Quoted: 99 Post(s)
Liked: 35
I use the following power distribution/protection system:
Each JL Fathom F113 on dedicated 20amp line protected by SurgeX SA20.
Each Monoblock MC601 share dedicated 20amp line protected by RGPC 1200c
MultiCh MC205 amp on dedicated 20amp line protected by RGPC 600s
Sources/Processsor/Projector protected by second RGPC600s (soon to include Shunyata Talos).
Whole system protected by front line APC Whole house surge protector at Service Panel.
See Profile
scanido is offline
post #4 of 7 Old 11-12-2013, 12:56 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 4147 Post(s)
Liked: 4233
I use a Panamax PFP M1500 unit.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
post #5 of 7 Old 11-12-2013, 01:52 PM
drummermitchell's Avatar
Quoted: 13 Post(s)
I have been using Torus Piu's for 4+years.
Torus 20a for rear components,4bsst,Jvc rs-60,Vac pre,Oppo bp,bcd-1,bdp-2,bda-2.
Torus 60a for front amps(2X28Bssts+7Bsst)+one 1812 sub.
Have blown a couple jl subs that were not connected to the Torus a few years back.
These I wouldn't be without and besides the superb protection,I mainly bought them for what a huge difference they made musically and especially dynamically.
Should add the other two Jl,s that were connect to the Torus were fine.
Have replaced a preamp,bluray player,the Torus(s)stay as they are that good.
drummermitchell is offline
post #6 of 7 Old 11-13-2013, 09:21 AM
JlgLaw's Avatar
Quoted: 83 Post(s)
Liked: 140
+1 on the Torus gear!
Jim
JlgLaw is offline
post #7 of 7 Old 11-13-2013, 07:14 PM
PeterS's Avatar
Quoted: 124 Post(s)
Liked: 41
+2 on Torus!
"Read Less, More TV." - Dr. Gregory House
"That which can not be questioned, can not be trusted." - Me
The Metropolis Home Theater
Blue Smoke Entertainment Systems - Affiliated
PeterS is offline
