Direct Digital out From Lexicon - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 11-19-2013, 12:36 PM - Thread Starter
Glimmie's Avatar
Quoted: 730 Post(s)
Liked: 592
I am working on a project to convert my HT system to 100% digital audio up to the power amps. I am building a DSP engine (a DIY Trinnov) based on MiniDSP boards - four MiniSharcs total!
My Bluray player has a similar modification to the Lexicon MC8 shown here. This is basically what the SPDIF Oppo mod is doing. That is to bring out the digital audio streams in a standard format. I choose balanced 110ohm AES versus SPDIF or 75ohm AES-3.
The Lexicon runs 96khz internally so this mod brings out the 7.1 as four digital streams. This also bypasses the MC8 volume control but more importantly I have found Lexicon tweaks the analog VCAs to produce some of the mock surround modes. So I'll have to duplicate that function elsewhere. More on that later, I do have it nailed.
This is the AES output board. There is a large surface mount chip on the backside of that board.
Here is the modified rear panel. I have standardized on 15pin VGA connectors for 8 channel digital audio. I need 4 pairs plus grounds so that's 12 pins. This is especially helpful on the DPS engine which is in a PC chassis. You can't put an XLR connector on a PC card slot let alone four of them.
In my new setup the MC8 is no longer the audio centerpiece but just an AC3 / DTS decoder that provides additional surround modes like the famous Logic 7. The BluRay player completely goes around the MC8. The DSP engine has four 8 channel inputs of which now two will be used, the MC8 and the BluRay. The third input will someday be a 4K player.
*Note that when I say 8 channels it's really only four physical digital channels or streams because AES and SPDIF carry two channels per stream or cable.
*For you engineering types, the interface chip is an AKM4101. That is a neat 4 channel AES / SPDIF digital output formatter chip. I obviously use the hardware configuration mode hence the jumper strips on the board. Also note the transformer coupling. We're doing this right!
More images on the way.
Glimmie is online now
post #2 of 12 Old 11-19-2013, 01:57 PM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 372 Post(s)
Liked: 243
You're using "true" digital amps e.g. TacT or NAD?
RUR is offline
post #3 of 12 Old 11-19-2013, 02:09 PM - Thread Starter
Glimmie's Avatar
Quoted: 730 Post(s)
Liked: 592
LOL! No the LCR power amps are in fact biampped and use TUBES! It's digital up to the power amps. The surround amps are good old SS class B as well.
Actually the volume control is also analog. The DACS are Lucid 88192's x2. I will have 16 discrete channels of DACs and the DIY level controller is also 16 channels but fully balanced I/O. In fact I will have absolutely no unbalanced analog audio in the entire system.
The MiniDSP products do not have a good digital volume control feature wise and as I said above, I need to re-apply the gain changes the Lexicon did in their analog section. My "volume master" box is also where I tweak the speaker gains based on room setup via REW. Good digital volume control is difficult to do. The MiniDSP may in fact be very good signal quality as it's 40bit resolution but the adjustment and remote control features I need are not possible in that product. So I went with a VCA based volume control based on Burr Brown VCA chips which are very good.
I'll post some picture of that sub project.
BTW, there is technically no such thing as a "digital audio amplifier". The class D topology has been around since the 1970s and still is an analog process. There have been attempts to make true digital RF amplifiers, a power DAC, but these have yet to become feasible. You just can't tame the switching noise enough at high power levels. Same issue with a power DAC even at audio frequencies and class D is an ANALOG PWM technology.
post #4 of 12 Old 11-19-2013, 06:39 PM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 372 Post(s)
Liked: 243
Yup, I was referring to "power DAC's", sometimes referred to as "true digital" amps - not to class D. Developed by Toccatta and used by TacT/Lyngdorf. Toccatta sold the technology to TI who named it Equibit. IIRC, NAD developed their own, similar technology, used in the M2 integrated and a couple of other devices, Only "amps" which will accept a digital signal and AFAIK 150W is max achieved in product so far.
RUR is offline
post #5 of 12 Old 11-20-2013, 04:46 PM
sfogg's Avatar
" This also bypasses the MC8 volume control but more importantly I have found Lexicon tweaks the analog VCAs to produce some of the mock surround modes. "
They also adjust the VCAs based on the Mode Adjust settings you choose within the modes. For example the various settings within Vocal Enhance will cause the Lexicon to adjust the VCAs to account for the --3dB or -6dB that is applied to the Center channel (when using vocal enhance) to give headroom for the processing to avoid clipping at 0dBfs. Same thing with some of the settings that adjust the surround channels.
Due to all those level changes it would be easiest to tap into the control signals to the Lexicon VCAs and feed that volume control data for your own VCAs. That way the Lexicon volume control (and speaker balancing and all the other tweaks) would happen in your volume controls.
Shawn
sfogg is offline
post #6 of 12 Old 12-01-2013, 12:33 PM - Thread Starter
Glimmie's Avatar
Quoted: 730 Post(s)
Liked: 592
Shawn
That's a great idea. And I have already been there in a sense. My old rear center was done at line level with an old Lexicon CP1. So I built a small VCA box that tapped into the MC8 VCA SPI control buss. I brought out the four VCA enables and the SPI clocks and data through a TTL buffer to a connector. I'll just put that mod back in.
I was going to get the offsets just by measuring the audio levels with sinewaves as I really only use a few of the MC8 modes. But your approach would be exact, automatic, and work with the enitre MC8 effect profile.
But I'm going to need a bigger boat! The 8K embedded porocessor in my new VCA box is about 85% full. I'll need a lot more code space for this update!
P.S. You must have worked at Lexicon. You know deep details of the MC8 design .
post #7 of 12 Old 12-03-2013, 09:57 AM
Peter Nielsen's Avatar
FWIW, the correct max figure is 200W in 8 ohms. The TacT Boz 2200 is 200W @ 8 ohms and 400W @ 4 ohms
Peter Nielsen is offline
post #8 of 12 Old 12-03-2013, 12:11 PM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 372 Post(s)
Liked: 243
Turns out the NAD M2 is 250W into 8 ohms, but is, curiously, 250W into 4 ohms, as well.
Peter, do you know if volume for the Boz amps be controlled using anything other than the Boz preamp? I'm familiar only with the S2150.
RUR is offline
post #9 of 12 Old 12-04-2013, 10:15 AM
The 216/2200 lets you adjust the volume with the supplied remote control. Volume can also be adjusted via RS-232. (When combined with a TacT preamp, for example the TCS, the preamp will control the volume over RS-232).
To clarify a common misunderstanding: Boz 216 is the power supply for the 2200 amplifiers. Boz 216 contains two toridal transformers and a computer that is used for programming the 2200 amplifier modules. The 216 does no audio processing whatsoever and only serves as a big step-down transformer during normal use. (If you use the remote to adjust the volume, or turn the volume control wheel, all it does is send RS-232 command codes to the 2200 amplifier modules).
post #10 of 12 Old 04-03-2016, 09:49 AM
Liked: 0
@Glimmie , I've come across your thread after planning to do the exact same thing (also an EE working in digital audio design for pro audio and cinema), and as luck would have it looking into getting an MC8 for the exact same purpose as you did, except with AVB as medium instead of multiple AES. Until now I've been using a Meridian 568 with an external unit with multiple DIR's to the AVB talker since it already has native S/PDIF outputs, but the itch to upgrade has struck.
I noticed you never followed up your thread, so some comments on these questions would be greatly appreciated:
- What is the purpose of the additional BNC plug you installed in the place of the composite video socket? Is it just a superior S/PDIF input from the source without an input mux?
- You mention internal fs of 96kHz, so to confirm it means the inputs are forced to 96kHz for a unified processing rate and thus the DAC's also always run at 96kHz?
- What is the frequency multiplier of the MCK to the DAC/DIT? I would presume it's 24.576MHz as the commonly used 256xfs?
- How does the MC8 volume control work? If you say the control is disabled does I guess volume control is not done in the DSP. Does it therefore mean they use a) programmable gain amplifiers like PGA2310 as used in e.g. Proceed or b) digital attenuation in the DAC?
- How are other volume offsets like speaker level calibration of the various channels treated? Is this therefore also done in your outboard unit and not used in the MC8?
- Could you please elaborate on how Lexicon uses the VCA's to produce the "mock surround modes"?
- Are the AK4395 DAC's used in hardware ("parallel") or software control modes, and if in software, is any dynamic/run-time control done or is it just an initial config?
- Likewise, I presume your DIT is just run in hardware mode without a MCU or hacking the MC8 to configure its SPI port?
Best Regards,
Pierre Watts
phwatts is offline
post #11 of 12 Old 04-04-2016, 10:13 AM - Thread Starter
Glimmie's Avatar
Quoted: 730 Post(s)
Liked: 592
In addition to the AES output, I also have a buffered output of the VCA SPI buss on an 8pin mini DIN connector. I put that in place of the second video output RCA and since the OEM jack was a dual RCA, I just stuck a BNC in the hole for the video out which I just use for the menu. The SPI jack was for a previous application.
Yes the MC4/8/12 runs 96khz as its native rate.
Yes IIRC, it's 24.576
The MC 4/8/12 uses analog gain control via BB PGA2310 VCA chips. (Actually they are switched resistance ladders and not true VCA's). So the volume control on the MC8 does not work on the AES output.
I have a 24 channel analog volume contol box after my DSP farm and Lucid DACs. This has 24 channels of PGA2310's and it is here where I do the speaker trims.
This is speculation as surround modes are Lexicon's secret sauce but it is believed that some channel gain tweaking is used in the synthesized surround mode. I even built an interface from that SPI buss connector to a PC parallel; port so I could analyze what they are doing, if anything, to the gains for various surround modes. But I since determined it's not worth the effort to try and implement this function. I am happy with the surround modes as is.
IIRC, they run in software config mode. I don't alter the MC8 SPI. I just tap the I2S at the DACs, run through an FPGA which in retrospect is not needed (I put it there just in case but have it "wired through") then onto to an AKM4104 quad AES transmitter chip.
post #12 of 12 Old 04-08-2016, 05:46 PM
PRETERNATURAL IMMERSOPHIL
CINERAMAX's Avatar
Quoted: 1674 Post(s)
Liked: 918
Send a message via Skype™ to CINERAMAX
Glimmie it sounds like you have started a movement. If anyone on this planet can pull this off , none is better qualifed than you. Look forward to the resulting FankenLexicon.
Sincerely, GC*
rAVe Best ATMOS DEMO CEDIA 2016. HOARDS AWARDS, ACCOLADES, 1ST ART CREDS.,WLD. RECORDS, & HI PERFORMANCE 16-24-32-48 CH. MIDI-PLF CINEMAS WW. - CUSTODIAN HIGH END IMMERSIVE CINEMAS TO SMPTE & ADV. IMAGING SOC. HELP Combat Channel Insufficiency with Altitude 48!*GC = GANGSTA C. genus: cineramus maximus. GC Twitter (Now staging Humanitarian Relief Aide to Great Bel-Air Circuit B-chain & 6P/HDR Projection Famine of 2017)
CINERAMAX is offline
