Questions for Surround/Trinnov experts pls: when you add speakers, do you reduce volume? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 55 Old 11-25-2013, 08:16 AM - Thread Starter
cannga's Avatar
Quoted: 1506 Post(s)
Liked: 1384
I was testing Hyde Park on Hudson post processing from Dolby 5.1 to 7.1 PLIIx with Theta CBIII by turning off all channels except the 2 surround sides and surround rears and listen to them. I used chapter 14, when Missy discovered the President messing with Daisy in the little house in the forrest, at time 1:01:00.
I noticed that when processing from 5.1 to 7.1, the "overall" rear field sound level increases in loudness. What used to be produced by 2 speakers in 5.1, becomes 4 speakers in 7.1, and the volume level, SEEMINGLY, has increased as a result. Rear field sound, in this case at 1:01:00 into film, from bird call (left rear/side) and dog barking (right rear/side), has become louder and more distinct.
1. Is my observation correct? Other processors do the same - this methodology is inherent to Dolby PLIIx and not Theta CBIII right?
2. If 1 is true, that should not be the case, should it? You've altered the "intention" of sound engineer by altering relative level of surround to main sound?
3. If 2 is true, when you add speakers, say from 5.1 to 7.1, shouldn't the volume of the new rear group (side + rear) be reduced so that it matches original rear group (side)?
Regards, Can
My System & Theta Casablanca Mini-Review Uncontrolled passion for music, and sound. (For CB IVa setup help, click HERE.)
Interesting Audio Diagrams :-) & High-End Speaker Reviews
JTR Subwoofer Thread I don't always listen to subwoofers, but when I do, it's JTR :-).
cannga is offline
post #2 of 55 Old 11-25-2013, 11:58 AM
LJG
LJG's Avatar
Quoted: 461 Post(s)
Liked: 231
This is a great discussion. I would love to know what actually is is done in the Dolby DDPL2X expansion from 5.1 to 7.1. For instance are they just adding delays to rear speakers, volume plus delays, where are the signals coming from ? are they from sides alone, or sides and front?
In my emulation with Curt we added DB and delays to back speakers.
LJG is online now
post #3 of 55 Old 11-26-2013, 02:18 PM - Thread Starter
cannga's Avatar
Liked: 1384
Curt made the added speakers louder? Wouldn't that make the rear sound field now too loud? I would have thought the opposite should be done: when you add speakers to the rear field, you would want to reduce the volume of each speaker so that overall volume level stays the same, to maintain front/rear or main/surround balance? I don't know the answer, just thinking out loud.
For PLIIx 5.1 to 7.1, maybe the pro's could chime in here, but from listening, here is my guess:
1. NO delay is added.
2. The additional 2 surround rear speakers of 7.1 are generated primarily from the 5.1 surround sides. For example, if there is a signal that is seen in both surround sides of 5.1, meaning it's a center signal, that signal is brought to the surround rear. OTOH, if the signal is in right surround side only, it stays there, as a hard right surround side's sound.
3. Volume stays same. In other words, 7.1 rear+side surround is louder than 5.1 side surround as a direct result of the additional 2 speakers.
Regards, Can
cannga is offline
post #4 of 55 Old 11-27-2013, 06:54 AM
LJG
LJG's Avatar
Quoted: 461 Post(s)
Liked: 231
I really would love to find out what the actual PL2X expansion algorithms do, and how they do it.
LJG is online now
post #5 of 55 Old 11-27-2013, 07:16 AM
thebland's Avatar
Quoted: 1664 Post(s)
Liked: 1003
+1!
Goodbye to a great audio and video genius and writer... JOHN GANNON. I enjoyed your friendship, wit and a nice long run we took around Indianapolis at CEDIA years back... and for buying my Runco 980 Ultra years back... you saved my ass! Rest in peace.
thebland is offline
post #6 of 55 Old 11-27-2013, 12:50 PM
sdurani's Avatar
Quoted: 5069 Post(s)
Liked: 3546
With 2-channel sources PLIIx sends correlated (in-phase) mono information to the centre output and sends decorrelated (out of phase) information to the surrounds. Same as any other surround processing (Neo:6, Circle Surround, Logic7, etc). With 5.1 material, PLIIx sends more mono-ish surround content to the back speakers with the more stereo surround content is sent to the side speakers. Like most surround processing, it steers content based on phase and intensity. Been discussed a decade ago on this forum when PLIIx came out.
Sanjay
sdurani is online now
post #7 of 55 Old 11-27-2013, 02:24 PM - Thread Starter
cannga's Avatar
Liked: 1384
Sanjay, are you aware of any discussion on relative loudness level of main to surround, voice to sound effect, etc., as you add additional speakers from 5.1 to 7.1? That is my main question for this thread: shouldn't the volume be reduced as you add speakers?
The difference is minor and doesn't bother me in my system, but I found it to be an important consideration, not just for PLIIx 7.1, but also for other soundfield manipulations like Trinnov (?) that may add speakers as part of the manipulation. As you add speakers to the front, to the side, to the height, etc., in all different directions, how do you keep track of these relative loudness levels? How do you keep it close to the original loudness levels of not just the different fields (front, side, rear), but also the different sound (voice, music, sound effect)? Thanks.
Regards, Can
cannga is offline
post #8 of 55 Old 11-27-2013, 03:38 PM
sdurani's Avatar
Liked: 3546
I think most receivers and pre-pros "normalize" the overall sound level; i.e., when you switch from 2 speakers to 7 speakers the sound shouldn't suddenly be 3.5 times as loud just because you're using 3.5 times the number of speakers. There might still be differences, but there shouldn't be big jumps in volume level when you turn on surround processing or room correction.
Sanjay
post #9 of 55 Old 11-28-2013, 07:06 AM - Thread Starter
cannga's Avatar
Liked: 1384
Thanks Sanjay, but no, I am not talking about a jump in loudness. What I am asking about is a subtle but identifiable increase in *relative* loudness of surround sound to main sound with post processing. For example the dog barking in the rear channel is louder and more distinct in 7.1, versus 5.1, where theoretically, it should not be, no?
BTW, this is related to what I've done per your recommendation (?) in past of trying 7.1. I do seem to like 7.1 better than 5.1, and my next step was to figure out *why* I like 7.1 better, by listening to the surround channels only. With this surround-sound-only test, I noticed two things, one, was the increase in "directional" of sound (certain sound becomes very distinctly rear as opposed to ambiguous side/rear), but two, there is an increased in surround loudness, specifically the rear sound field, where those speakers are located. It is this relative increased in loudness of surround sound to main sound that "bothers" (for lack of better word) me a little bit; is 7.1 "better" simply because the surround is louder relative to main?
My curiosity is not just about PLIIx, but also other processing as well. For example if you are to add height information by adding 2 height speakers to the front left/right channels, in this case going to 9.1 from 7.1, you've made the overall loudness of front l/r channels relatively louder than both center and surround, merely by the presence of the additional 2 speakers. If you don't compensate by reducing volume, you've altered the balance as presented by the bluray disc?
Regards, Can
cannga is offline
post #10 of 55 Old 11-28-2013, 07:27 AM
thebland's Avatar
Liked: 1003
I don't know... but more is better and more precision.
In my Conversions with Curt regarding my Trinnov adventure, the more speakers added, the more precise the sound field can be giving it more resolution (I am sure I am simplifying). Then again, that seems to be the idea in Atmos with all the layers of speakers working together to make a more precise sound field. Certainly you can better flesh out anything in a sound field if you have more speakers (and software) to help create the image. This is my biggest potential gain in adding Trinnov to my system.
thebland is offline
post #11 of 55 Old 11-28-2013, 11:26 AM
sdurani's Avatar
Liked: 3546
You're right, it should not be. Just because that sound effect is being reproduced by two speakers doesn't mean it should be louder, it should just phantom image between the speakers, not increase in level. But as with many things in audio, theoretical doesn't always become practical. The system should compensate for reproducing a sound through two speakers instead of one, but sometimes it's only partially successful (it's not twice as loud when switching to twice the speakers, but it is subtly louder).
...is 7.1 "better" simply because the surround is louder relative to main?
No. There are qualities that cannot be attributed to level differences, like wrap-around envelopment, more precise directionality, and greater imaging stability. 4 speakers can do things that 2 speakers cannot (e.g., be directly at your sides AND behind you simultaneously).
Happy Turkey!
Sanjay
post #12 of 55 Old 11-28-2013, 01:17 PM - Thread Starter
cannga's Avatar
Liked: 1384
^^^Gobble gobble! tongue.gif Same to you.
Regards, Can
cannga is offline
post #13 of 55 Old 11-29-2013, 10:39 AM - Thread Starter
cannga's Avatar
Liked: 1384
Are you experimenting with Trinnov to be "like Atmos"? Trinnov and Atmos may seem similar because they both add speakers, but Atmos is an entirely different process, much more sophisticated with respect to surround sound effect, no?
I am (of course) still trying to understand, but it seems Atmos uses object-oriented mixing that layers sound effect in precise location - the info is in the software, and reproduces the sound with speakers in location as specified by software, whereas Trinnov, not sure, but there is no surround sound processing per se involved with Trinnov, no? It's re-mapping, not surround processing, or creation. Placement of sound effect is not nearly as precise with Trinnov as it is with Atmos, I don't think.
Besides location of sound, Trinnov vs. Atmos is also different in a second aspect, and that is the relative volume of sound, main vs. surround, front vs. rear, that I have been asking about. With Atmos, each channel's loudness is of course specified, with Trinnov, when you add speakers to your system, is there a rule to make sure that you have not altered the loudness balance of the different channels, so that for example you have not made the front channel overly loud relative to surround, and vice versa? When you add ceiling speakers to front l/r main speakers, how do you make sure the additional speakers have not made the front channel too loud, etc.?
Very interesting topic and I am actually being deliberately "provocative" cool.gif so I would be corrected and learn from it.
Regards, Can
cannga is offline
post #14 of 55 Old 11-29-2013, 11:38 AM
thebland's Avatar
Liked: 1003
Hi,
I'm aware they are completely different things... my point was that the Trinnov will get a more life-like and accurate sound field, like Atmos does, but in a different manner. Atmos does it with its own encoding an decoding. My understanding is Trinnov does it with its own algorithms. Both make the sound field better than the typical SSP and typical room correction. The ability to add channels is a great bonus and I plan on adding some.
thebland is offline
post #15 of 55 Old 11-29-2013, 01:01 PM
sdurani's Avatar
Liked: 3546
Object oriented audio isn't hard to understand, since video games have been using it for almost a decade. If you hear the enemy coming up behind you and you rotate your first-person player to get a clear shot, the sound of the enemy will have panned from your back speakers to your side speaker to your front speakers.
When creating the soundtrack for the game, which channel did they mix that sound effect to? It wasn't mixed to any channel, it was encoded as an object. During playback, that object (sound effect) was rendered to your speaker layout, with you deciding its location (in real time, no less) using your game controller.
Movies encoded with objects will likewise have sound effects rendered to their intended location, not necessarily where your speakers are. But for anyone who has played video games over the last ten years, that's nothing new.
Sanjay
post #16 of 55 Old 11-29-2013, 02:10 PM
3D Audio Consultant
Curt_Trinnov's Avatar
Quoted: 72 Post(s)
Liked: 120
As Trinnov encompasses more loudspeakers, overall level balance is maintained.  In LJG's case, the rears were increased only a couple of dB. His layout is not particularly conducive to a strong back image, as the chairs are all along the back wall.
Re PL2X, Trinnov will not replicate PL2X steering in the front with movie mode that gives a locked dialog channel.  For PL2X, I prefer the better decoders, as they do a better job of tracking minor phase errors. Most Trinnov users keep a processor around specifically for PL2 decoding.
Cheers,
___________
Curt Hoyt
3D Audio Consultant
Trinnov Audio
USA
Curt_Trinnov is offline
post #17 of 55 Old 11-29-2013, 11:45 PM
LICENSED TO THRILL
CINERAMAX's Avatar
Quoted: 2224 Post(s)
Liked: 1265
Send a message via Skype™ to CINERAMAX
Trinnov with height channels to my ears is the equivalent of the Atmos base. It is a solid 3d holosonic soundfield, very similar to what HK/lexicon demoed but did not delivered a couple of years back.
Then atmos deploys on top of that the flying Foley pirouettes which cannot be achieved with anything but atmos.
CINERAMAX is offline
post #18 of 55 Old 11-30-2013, 06:21 AM
LJG
LJG's Avatar
Quoted: 461 Post(s)
Liked: 231
Cheers,
Just to clarify Curt's post, when he states most Trinnov users keep a processor around specifically for PL2 decoding, he is referring to 2 Channel PL2, not PL2X.
LJG is online now
post #19 of 55 Old 11-30-2013, 07:53 AM - Thread Starter
cannga's Avatar
Liked: 1384
Thanks. Is object-oriented audio the inevitable future of movie sound? Is it considered to be more "efficient" (easier to produce), more precise? Yes, it is mind boggling for me, so used to the concept of stereo imaging, but after 5+ readings :-) I am beginning to get it now.
So strange to think how it's done: each sentence a character speaks is an "object," each foley another object? How complicated it must be. In a game, the sound of, for example, gun popping is repeated over and over, not so in a movie where dialogue (obviously) is not repetitive, there must be millions of "object" for any standard movie?
Regards, Can
cannga is offline
post #20 of 55 Old 11-30-2013, 09:22 AM - Thread Starter
cannga's Avatar
Liked: 1384
Hi,
Sure, very different I think; it seems Trinnov remapping is intended for non-ideal or compromised speaker system, where space or physical constraint limits where you could put your speakers. In a room where users could simply put speakers where they are intended to be per Dolby or DTS specs, which I assume yours is, I don't think this aspect of Trinnov is as important. One example is LGJ's system, where as best I could tell (pls correct as needed), there is no space to make rear speakers truly behind listener (because of the rear wall), and here Trinnov is important for that correction.
I was at Trinnov's demo at the Southern Cal High End show a while ago, where a sound is demo'ed to be "place-able"at different places in the room. I had no idea why this was important or necessary, until I realized the application is primarily for system with compromised speaker placement.
As for creating height using Trinnov, which I seem to see as one application, I am continuing to probe by guessing publicly tongue.gif the methodology of how this is created. Is it by Trinnov remapping? With Atmos's height-specific system for example, I would assume airplane sound would come from the ceiling speakers and voice stays on the ground level speakers. With Trinnov's height "creation," sssume it's done by remapping, wouldn't this cause every sound to be elevated, not just the airplane sound?
Regards, Can
cannga is offline
post #21 of 55 Old 11-30-2013, 09:38 AM
thebland's Avatar
Liked: 1003
Poor set up compensation is a great benefit of the Trinnov. But one of man y excellent abilities. It's really, in my opinion and why I am going that way, is to achieve the best possible sonics in your own room. My set up and room are pretty good as it was designed form the ground up. But I am expecting a benefit of great magnitude once I install my new speakers and subs. I hope to minimize the room's impact on the system's sound.
Read this and you'll see some features:
http://www.trinnov.com/tri_news/award-winning-sound-re-recording-mixer-opts-for-trinnov/
Kal's review of the 2 ch version in Stereophile. THe last paragraph is a good summation.
http://www.stereophile.com/content/music-round-62
thebland is offline
post #22 of 55 Old 11-30-2013, 11:24 AM
LJG
LJG's Avatar
Quoted: 461 Post(s)
Liked: 231
This is not correct as there is not a correct speaker placement for all surround modes and 2 channel stereo, you have 5.1 Itu recommended speaker locations vs 5.1 Smpte, speaker locations vs 2 channel, how do you accomplish this in a perfect setup? Impossible.
The Trinnov can
LJG is online now
post #23 of 55 Old 11-30-2013, 12:33 PM
sdurani's Avatar
Liked: 3546
The industry will go through a hybrid (channels + objects) approach, like Dolby Atmos, but eventually mixers will probably stop thinking in terms of discrete channels and it will just become habit to place sounds where they want.
Less efficient (since a computer has to constantly calculate how to render the sounds at their intended location using a limited number of speakers) but more precise (since the system is always trying to place sounds at their intended location instead of where your speakers happen to be).
Stereo imaging still comes into play during playback. If a sound effect or dialogue is supposed to image at a location where there is no speaker, then the rendering engine will grab 2 or 3 nearby speakers to phantom image the sound at the intended location. But that already happens nowadays when rendering dialogue on a set-up that doesn't have a centre speaker: the left & right speakers are used to phantom image the dialogue at its intended location (centre of the soundstage).
Probably thousands, not millions. Atmos can juggle over a hundred objects at any given time, but I don't think movie mixes come anywhere close to needing that.
Sanjay
post #24 of 55 Old 11-30-2013, 01:19 PM
sdurani's Avatar
Liked: 3546
...it seems Trinnov remapping is intended for non-ideal or compromised speaker system, where space or physical constraint limits where you could put your speakers.
Yup, though there is another thing that Trinnov re-mapping is doing.
Forget channels for a moment and think in terms of rendering a soundstage, with width, height and depth. Even on stereo recordings, there are sounds that will image near the edges of the soundstage and other sounds that will image at the middle of the soundstage. On better recordings, there are sounds that will image slightly above the soundstage as well as deep behind the soundstage.
Next step, think of speakers as the pixels you use to create the image of a soundstage. The more pixels you have, the greater the resolution (in the case of audio, it is greater spatial resoultion). This means more precise and stable imaging as you add more speakers. But how to map the energy (not the channels!) in the recording to the number of speakers in your layout?
That's where a re-mapping algorithm comes in. It will figure out where sounds in the recording are intended to appear and use your speakers to create images at those locations. In some cases it might take several speakers to image a sound in three-dimensional space. So the more speakers the re-mapping engine has access to, the better it can do its job. Just like with pixels.
Sanjay
post #25 of 55 Old 11-30-2013, 01:54 PM
djnickuk's Avatar
Quoted: 271 Post(s)
Liked: 72
I highly recommend people unsure about object based sound formats check out the latest home theatre geeks.
http://twit.tv/show/home-theater-geeks/184
djnickuk is offline
post #26 of 55 Old 11-30-2013, 04:13 PM
Kal Rubinson's Avatar
Quoted: 771 Post(s)
Liked: 542
It was a 16channel unit but I used only 7 channels.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #27 of 55 Old 11-30-2013, 05:09 PM
thebland's Avatar
Liked: 1003
I have to go back and look.. I don't know why I recall two channel listening sessions most clearly - (though the unit was multi-channel)??
thebland is offline
post #28 of 55 Old 12-01-2013, 09:05 AM
Quoted: 771 Post(s)
Liked: 542
That's OK.  This is one of the few times that my recollection is better than that of a reader (although I did go back and check my docs before posting).  Of course, I did do some listening in 2channel as well.
Kal Rubinson
post #29 of 55 Old 12-01-2013, 09:06 AM - Thread Starter
cannga's Avatar
Liked: 1384
The Trinnov can
Smpte speaker placement rec. is for professional engineers during mixing, it is not home movie playback application, did I understand this correctly? In what situation (which movie or music) would I want smpte's rec.? And if you are using 7.1 system, what is smpte's recommendation - is there one? Not being rhetoric/sarcastic at all, real questions, which would lead me to the second set of questions below:
When I watch a a 7.1 Dolby disc, I follow Dolby's recommendation for seat placement in my 7.1 system, why is it impossible to be perfect? Or, rather, as perfect as could be to the point that remapping is un-necessary?
Unrelated question for anyone please: What's intriguing to me is if you look at Trinnov's paper, in my case that means by bypassing the 25 pages of mathematical equations and go straight for the one paragraph abstract tongue.gif, the re-mapping seems to be presented as a method to correct for speaker's "misconfiguration" only. Is the "height generation" that I seem to see a byproduct of this very same remapping process?
http://www.trinnov.com/wp-content/uploads/downloads/AES6375_Reproducing_Multichannel_Sound_on_any_Speaker_Layout.pdf
Consumers are more and more interested in multichannel sound. However, installing a surround system is still a headache for most users. The ITU recommendations are generally incompatible with homes arrangement and people install their system how they can, which generally results in large spatial sound distortions. This paper presents a system allowing to overcome this problem by adapting multichannel sound to the actual user loudspeaker layout. This system consists of a small calibration microphone measuring loudspeaker characteristics (3D position, frequency response) and a calculation process which remaps multichannel sound over the calibrated layout so as to compensate the measured loudspeakers misconfiguration, including full 3D position.
Regards, Can
cannga is offline
post #30 of 55 Old 12-01-2013, 09:18 AM
Quoted: 771 Post(s)
Liked: 542
What's intriguing to me is if you look at Trinnov's paper, in my case that means by bypassing the 25 pages of mathematical equations and go straight for the abstract, the re-mapping is initially presented as a method of speaker's "misconfiguration." Is the "height generation" that I seem to see a byproduct of this very same process?
That is how I see it.  The 2D correction is for speaker layout in the horizontal plane and the 3D is a correction (not so much a generation) in the vertical dimension.
Kal Rubinson
