Lexicon MC12B > Marantz 8801 > what ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 30 Old 12-28-2013, 10:38 AM - Thread Starter
jdlynch's Avatar
Quoted: 160 Post(s)
Liked: 66
Earlier in the year I sold my MC12B and purchased a Marantz 8801. The main reason, besides the hype over the 8801, was HDMI hook-up and how well XT32 integrated my sub into my HT system.
Even though the Marantz is very good it still lacks enough sound quality compared to my Lexicon that I can tell a difference. Even though my sub sounds better the "airiness" , clarity, and top-end I was used to is gone. I am not sure if that is because of the pre-amp section being better or the fact that I was using analog inputs on my Lex.
What should I consider, in the pre-owned market, that wll get me performance equal to the lexicon, and, have a sub EQ? I don't need EQ for the upper ranges just the sub. Maybe a legacy processor plus an out-board EQ device?
My Oppo has HD decoding and analog outputs.
I don't have the time or patience to learn REW or similar software.
Current Equipment: Datasat LS10 w/ Atmos and DIRAC. Datasat RA7300, Aerial Acoustics LR5's (LCR), Aerial Acoustics LR3's (sides), RBH in-walls (rears), Seaton Submersive, Marantz VP15s1, 106" Carada BW screen, Oppo BDP-103.
knobstoneaudio.com
jdlynch is online now
post #2 of 30 Old 12-28-2013, 11:03 PM
mrevo2u's Avatar
Quoted: 54 Post(s)
I was in a similar situation. The 8801 is good, but a downgrade from the mc12b. For room coorection/EQ there are not that many good options. If you want to go HTPC route, DIRAC is nice. I ended up going Anthem D2 as the sound is better than mc12b and the ARC room correction is better than audyssey. It's the best you can get IMO without going to something like Theta or Trinnov.
mrevo2u is offline
post #3 of 30 Old 12-29-2013, 07:24 AM - Thread Starter
jdlynch's Avatar
Quoted: 160 Post(s)
Liked: 66
Thanks for the suggestion.
Does the anthem D2 output discrete 7.1 audio or is it matrixed?
Also, how well does ARC handle frequencies less than 80hz?
I was thinking about going back to an MC12, but, I would lose discrete 7.1 HD audio, and, would have to use something like an anti mode to handle the bass frequencies. I had no problem using the analog inputs as opposed to HDMI.
knobstoneaudio.com
post #4 of 30 Old 12-29-2013, 07:51 AM
mrevo2u's Avatar
Quoted: 54 Post(s)
The anthem is not fully set up so I cannot comment on ARC less than 80 hz. Most of the guys in the DIY thread are using a MiniDSP to eq the subs
mrevo2u is offline
post #5 of 30 Old 01-20-2014, 09:09 PM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
Everything on the market today is a compromise. There is very little out there that will satisfy everyone.
There is literally nothing on the market except maybe the datasat which satisfies all my wishes at the moment and I haven't actually heard it.
Blazar!
blazar is offline
post #6 of 30 Old 01-22-2014, 12:08 AM
ChadhaT's Avatar
JD
Considered a Lexicon MC12HD used ?
Most would say why go to something that old - but if one likes the sound, the room correction, Logic 7 processing then why mess with it. The HD has the HDMI. I have a Lex MC12 and if it dropped dead would go and probably get a 12HD until something more satisfying comes out.
Tarun
ChadhaT is offline
post #7 of 30 Old 01-22-2014, 12:58 PM - Thread Starter
jdlynch's Avatar
Quoted: 160 Post(s)
Liked: 66
Originally Posted by ChadhaT View Post
JD
I actually have been looking at the used MC12HD units that occasionally show up. Something else I am considering is a used Theta Casablanca. I don't actually need the HD version since I can simply let my Oppo do the hi-Rez decoding and feed the CB through analog. The only issue that would leave me with is dealing with Bass EQ.
knobstoneaudio.com
post #8 of 30 Old 01-22-2014, 09:08 PM
tyree91's Avatar
You would need to add a Theta Six Shooter to get 5.1 Analogue with the CB. A lot of cables, no 7.1 without 2 EA. Six Shooters. I love Theta, but I would not go without the HD version. Norm
tyree91 is offline
post #9 of 30 Old 01-23-2014, 12:23 AM
Steve Bruzonsky's Avatar
Quoted: 439 Post(s)
Liked: 100
WOOPS! Just recently sold my Six Shooter.
If you go that route using analog interconnects, I've got some good ones for a more than fair price. HA!
Though I echo Norm and recommend at minimum going the CB3 HD route.!
You mean you don't remember me? Back 1999 - 2003, I started and moderated the AVS Tweaks forum and also the AVS Special Guests forum.
My home theater at:
http://www.avsforum.com/avs-vb/showthread.php?t=1158431
Steve Bruzonsky is offline
post #10 of 30 Old 01-23-2014, 04:32 AM - Thread Starter
jdlynch's Avatar
Quoted: 160 Post(s)
Liked: 66
Thanks Tyree-
I admit I have some research to do regarding the Casablanca and which of its configurations would best fit my needs.
knobstoneaudio.com
post #11 of 30 Old 01-23-2014, 08:58 PM
joeycalda's Avatar
Quoted: 49 Post(s)
If its just for the subs I have had fantastic results with the Marchand Electronics Bassis Parametric EQ.
I was using the Levinson No. 40 SSP and the Bassis made a BIG DIFFERENCE, and if I remember correctly it's not that expensive.
Joey
joeycalda is offline
post #12 of 30 Old 01-24-2014, 03:44 PM
sfogg's Avatar
"I was thinking about going back to an MC12, but, I would lose discrete 7.1 HD audio,"
I can fix that. wink.gif (in analog bypass mode)
Shawn
sfogg is offline
post #13 of 30 Old 02-02-2014, 10:17 AM
spentmuch's Avatar
jdlynch: I am in the same boat. I sold my Lex and am using the 8801 for several months. I can live with it but it is not as good sounding as the Lexicon. Not for music anyway. I've always been curious about the Casablanca. lf you end up getting one, please post your opinion. Call me overly optimistic, but I am waiting for the release and subsequent user reviews of the Emotiva piece. It reads good on paper, but I guess the company has a legacy to improve upon. We'll see.
Mike
spentmuch is offline
post #14 of 30 Old 02-02-2014, 10:36 AM - Thread Starter
jdlynch's Avatar
Quoted: 160 Post(s)
Liked: 66
Mike
I will soon start looking for a few different units to try in my system. At the moment my contenders are the Theta CB, Mac MX151, Classe SSP800, and the Brston SP3.
knobstoneaudio.com
post #15 of 30 Old 02-02-2014, 11:06 AM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
What should I consider, in the pre-owned market, for $4,000 or less that wll get me performance equal to the lexicon, and, have a sub EQ? I don't need EQ for the upper ranges just the sub. Maybe a legacy processor plus an out-board EQ device?
Read the "secrets of hi fi and home theater" website article on pre-pro's in the technical section of their website. Very enlightening.
I like the theta casablanca IV idea except that I really like dts neo X 11.2.
Even better is probabaly the Datasat which I am increasingly tempted by if I could get some S/N and distortion measurements on, no way I am spending upwards of $15000 on a preamp unless the sound quality will beat EVERY other pre-pro for at least a decade.
The depreciation on processors is a serious concern for me and would much prefer something really great on the used market.
None of the mainstream (denon, yamaha, onkyo, integra, marantz) pre-pros deliver truly "state-of-the-art" 2 channel music nor the supposedly technically superior room correction such as Dirac.
The main lesson from the big article on pre-pros on secrets of high fidelity website: 2 channel dac/output is compromised (not state of the art) by the multichannel shenanigans and other "features" in the name of cost containment.
My wish list:
-Great movie sound with room correction
-EXCEPTIONAL 2 channel sound with digital domain bass management and room correction if i need it.
-ESS sabre dacs
A great 2 channel preamp example as a referenece point is the pass labs Xs unit. VERY expensive but "secrets" had an impressive test benc review of it.
Blazar!
blazar is offline
post #16 of 30 Old 02-02-2014, 11:43 AM
Frank D's Avatar
Quoted: 273 Post(s)
Liked: 75
I am somewhat in a similar circumstance. My current preamp is the MC12 B. I am also currently trying a Denon x4000 with XT32 using the preamp outs (have 30 days to return it and I am leaning towards returning it). To me the sound on my MC12B with Logic 7 was just better overall (except for it's poor EQ which was important for me and my room is treated). However the improvement made from using XT32 to correct the frequency part of the sound was significant in that area of the sound. The EQ in the MC12B did not fix the frequency very well in my opinion and if it had I would not be looking for another solution.
So if I do return the Denon x4000 I will be considering a few alternatives:
1. Get the MiniDSP 10x10 to adjust the full frequency domain. Cost is $599 plus $75 for mic and REW software is free. I still have my SVS AS-EQ1 SUB EQ to do the lower end as it appeared to do be doing a great job since I purchased it a few years ago. I had been using the AS-EQ1 with my Lex 12B. (So my problem frequency where above the 80 hz range). Note that you could use the 10x10 to adjust the frequency of the sub and not use something like the SVS AS-EQ1. I would only use the AS-EQ1 as I already own it.
http://www.minidsp.com/products/minidsp-in-a-box/minidsp-10x10-hd
2. Get the MiniDSP nanoAVR. Cost is only $299. Same idea as the MiniDSP10x10 but this is an hdmi in and out solution. Note that due to the fact that the nanoAVR only inputs and outpus LPCM via its hdmi in and out than I cannot use with my Lex MC12 B as it has no hdmi inputs but would work with the Denon X4000 or Anthem MRX510.
http://www.minidsp.com/products/minidsp-in-a-box/nanoavr-8x8
3. Try the Anthem ARC MRX510 using its pre outs. Not sure how this will compares to the Denon X4000 with Audyessy XT32 but from the various sources (spoken to sales people that sell both Denon and Anthem etc.) they say it should be better to much better. However vendors of this unit, higher end single owner audio shops, tend not to offer returns (ie vs Denon that is sold by larger stores like Best Buy)
4. Waiting for the Emotiva XMC-1. But it may be a while and I do not want to be the ginny pig as I suspect there could be issues.
Currently my feeling is that no matter which software (ie ARC, Audyessy etc.) you get (unless maybe the real high end like Trinnov or others) you will need to some small extra EQ adjustments and in some cases that can be significant improvement to the sound. Every room and individual's perceptions will be different.
If you want a very "easy" way start to measure your frequency response before buying or learning about the above noted items I suggest you try using your ipad, assuming you have one, and buy the Studio Six Digital app (about $20 dollars or so). If you keep your ipad in good shape and you have not damaged its mic or there is no dirt blocking the mic etc. than you should get some decent measurement results. This will give you an idea. I have the ipad 3 and have taken many repeatable measurements to my pleasant surprise. I have also compared the spl number to a radio shack meter using pink noise and again the amounts match. You have to understand that you are not using a calibrated mic so you may not want to soley depend on it for EQ adjustment purposes but if you like the software than Studio Six does sell a calibrated mic.
http://studiosixdigital.com/audiotools/
Frank D is offline
post #17 of 30 Old 02-02-2014, 12:17 PM - Thread Starter
jdlynch's Avatar
Quoted: 160 Post(s)
Liked: 66
I have revised my original post by removing a price constraint. The more I have researched the more I have realized that many of the units that will meet my requirements cost considerably more than I was originally budgeting. Thanks for all the comments.
knobstoneaudio.com
post #18 of 30 Old 02-02-2014, 12:53 PM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
Lol yeah same conclusion for me
Blazar!
blazar is offline
post #19 of 30 Old 02-02-2014, 02:52 PM
matthewa's Avatar
Quoted: 17 Post(s)
Frank D couldn't you run your pre out on the Lex into Denon? Then you could run your source into the Lex apply logic7, I suppose you don't get all the adjustments on the Denon via multi inputs... But at least you may get similar music capability as today, but improved movie HD soundtrack capabilities
matthewa is offline
post #20 of 30 Old 02-02-2014, 08:51 PM
Frank D's Avatar
Quoted: 273 Post(s)
Liked: 75
The Denon has no 5.1 multi channel analog inputs just pre outs. However I may be able to use the Denon pre outs to my Lex analog inputs and apply Logic 7. Never tried that. That may actually work. Basically use the Denon for it EQ and hdmi abilities and the Lex for it Logic 7. However the Deon's EQ although very good was not good enough for me. I was hoping to get a flatter EQ curve. With Denon the EQ curve was much better than before but still not flat. I may just end up trying to use the 10x10 miniDSP with the Lex once I return the Denon X4000.
Frank D is offline
post #21 of 30 Old 02-03-2014, 04:33 AM
spentmuch's Avatar
Frank D: I could be wrong about this, but I thought if you use Lexicon's 7.1 analogue inputs, you will bypass most/all processing. No Logic 7. It's been a while since I've read over the manual, but check it out.
Michael
post #22 of 30 Old 02-03-2014, 05:04 AM - Thread Starter
jdlynch's Avatar
Quoted: 160 Post(s)
Liked: 66
Michael
The MC12 does allow you to apply digital processing to the 5.1 analog inputs.
knobstoneaudio.com
post #23 of 30 Old 10-26-2015, 09:49 AM
Liked: 0
Did a similar test this weekend and the clarity of the Lexicon MC 12 was gone with the 8801, turining into a muffled sound.
But my question: Anyone who can help me with the abovementioned issue (for which sfogg has a solution) of connecting all 8 analog channels from my Oppo to the Lex 12 and how to process these in order to 'remain discrete' ? Am currently using only 6 channels analog from the Oppo, though I have a 7.1 set up (i.e. using L7 ..) Would prefer 8 discrete channels. How should I hook up the rears/additional 2?
Buzzer66 is offline
post #24 of 30 Old 11-08-2015, 02:55 PM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
The MC12 is essentially obsolete from a codec standpoint if I am not mistaken. Various uses of analog inputs are unlikely to solve that I would think...
Unfortunately, these devices are very codec dependent and are not software upgradeable.
I have harmon kardon logic 7 in my Jeep Grand Cherokee and it sounds great... Harmon companies generally do a great job in overall sound. It doesn't surprise me that you want to salvage the MC12 which is a fairly expensive device.
Even JBL (a division of harmon) has now joined with Trinnov for its JBL/Synthesis system in order to do re-mapping and decoding of atmos and DTS:X signals. The JBL/Synthesis + Trinnov combo sounded excellent at CES (there is another thread on this).
The 8801, I also own, and its sound is definitely more dull than I realized (I agree with you now that I have much better in my room). Audyssey should basically be bypassed except for bass management... It is totally average IMO and made my room sound dull compared to Trinnov's optimizer which sounds dramatically better. You would have to be deaf not to notice the difference.
I really did NOT want to be a "high end snob" but dammit I got so sick of waiting for a proper product to be built that I pulled the trigger at a price range that I would have never considered before outside of winning the lottery.
The MC12 likely has a better output stage which accounts for most of the difference between the 8801 besides differences in room correction algorithms. Harmon's products like I said, generally sound very good. Revel, Lexicon, etc have been consistently great products while Mark Levinson (while decent) is their audio jewelry brand IMO.
Blazar!
blazar is offline
post #25 of 30 Old 11-08-2015, 06:32 PM
tbhugh's Avatar
Essentially what Buzzer66 is doing I think is what I'm doing. I'm having newer formats decoded by my Oppo 105D and passed to my MC12 through analog inputs. I'm then digitizing the inputs to let my lexicon handle bass management and EQ. Yes it's old but it still sounds amazing. The problem is that the Lexicon only has 6 analog inputs where the new formats would require 8. Shaun Fogg can modify the Lexicon to have 8 inputs but I don't believe the signal can be digitized for processing by the Lexicon so it's straight analog bypass. Unfortunately for me the digitized signal sounds better that straight analog, so I have my Oppo 105D down mixing to 5.1 and then using the Logic 7 on the Lexicon to then output to 7.3. This works really well for me but won't work for ATMOS or DTSX, so it looks like I will be retiring the Lexicon in the next year or two when formats mature a bit more.
Tom
tbhugh is offline
post #26 of 30 Old 11-11-2015, 08:05 AM
ceenhad's Avatar
Quoted: 72 Post(s)
Liked: 62
Look at the Acurus ACT4 for SQ without the mind blowing price tag.
Neil Davidson - DT Screens
ceenhad is offline
post #27 of 30 Old 11-12-2015, 08:24 AM
tbhugh's Avatar
Bet the Act 4 sounds good, but I didn't see anything about onboard Room Correction in the spec sheet. Without that it is no bueno for me.
Tom
tbhugh is offline
post #28 of 30 Old 11-12-2015, 12:39 PM
Will Binegar's Avatar
Quoted: 12 Post(s)
Liked: 25
You could go with a Meridian G68, which I thought sounded better than the Anthem in my room. If you want to feed it HDMI (rather than use the Oppo's analog outs), you'd need the HD-621 companion piece as well. Meridian's room correction is only geared to frequencies below something like 500Hz (or maybe it's 250). Not the way to go, if you're contemplating Atmos or the like, as who knows when Meridian will get on that boat. But it's the best sounding pre-pro I've used. I've got the Marantz 8802A now, and even with the Atmos ceiling speakers, I think overall the sound might be better with the G68 and just my 5.1 setup.
Will Binegar is offline
post #29 of 30 Old 11-14-2015, 07:17 AM
rblnr's Avatar
Quoted: 66 Post(s)
Liked: 38
The 8802 is significantly more transparent than the 8801 and based on sonic memory, better than the G68 and MC12, both of which I owned quite awhile ago. I did not like the M12 for music at all.
I have a full Atmos setup so my processor choices are very limited now. I like the 8802 but am waiting for better options, may revisit Theta (owned a CBIII for quite awhile but got tired of waiting for hdmi) et al when they get around to adding the channels.
rblnr is offline
post #30 of 30 Old 11-17-2015, 04:10 AM
jannord's Avatar
I owned the AV8801 for two years and used Audyssey pro kit to get the best from it. Used it 80% for movies due to the more dull experience when listening to music. This summer i did the big leap to Casablanca IV with two extreme D-2 Dacs. It is a really big step in SQ compared to the AV8801. Today I use the casablanca 50/50% between music and movies. Use TIDAL frequently through my Oppo bdp-103.
Focal Electra 1027Be signature, Focal Electra 1000CC Be signature, Jlaudio Fathom F113, B&W 705, Oppo bdp-103, Casablanca IV w/xtreme D-2 DAC's, Cary Cinema 5, transparent audio cables. 120" motorized dreamscreen tab tension, sony wpl hw55ES projector, sony 46HX900 TV.
jannord is offline
Marantz Av8801
