Trinnov Altitude - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 799Likes
post #181 of 3125 Old 09-03-2014, 11:49 AM
erwinfrombelgium's Avatar
Quoted: 438 Post(s)
Liked: 236
Originally Posted by Rod#S View Post
Oh, how do subs fit into that 34 channel arrangment? So you have 24 speakers around you and 10 above, does that assume all or some of the main speakers around you are full range or if you want subs you have to start subtracting from the total for each sub added, so for example say 22 around , 2 subs and 10 overheads to equal 34?
The 34 consumer Atmos is not including subs. So a 32 channel processor used with 2 subs has 30 channels left for satellites.
The 64 commercial Atmos is including sub channels (61.3). One behind the screen and one at each side towards the rear. This is done because the typical surround speaker in a cinema is not capable down to 80 Hz and localization starts to play. They were at the ceiling above the entrance in the cinema I visited.
Marcus Gan likes this.
Building a 9.3.4 HT: DIYSG Titan LX [LCR] • Cinema 10 Max [6 Surrounds] • Beta 10CX custom [TF+TR] • LLT Mal-x 18" subs [2] • XPR-5 • MM8003 [8ch] • XMC-1 [RMC-1 wanted] • PT AT6000E • 130" Seymour Center XD • Oppo 103EU • WTB: 1 extra Mal-x 18" SW
erwinfrombelgium is online now
post #182 of 3125 Old 09-03-2014, 12:44 PM
Rod#S's Avatar
Quoted: 386 Post(s)
Liked: 55
Gotcha, thanks
Rod#S is offline
post #183 of 3125 Old 09-03-2014, 12:56 PM
sdurani's Avatar
Quoted: 4787 Post(s)
Liked: 3204
Subwoofer outputs are created by bass management, not anything to do with Atmos.
Sanjay
sdurani is offline
post #184 of 3125 Old 09-03-2014, 12:57 PM
noah katz's Avatar
Quoted: 1003 Post(s)
Liked: 342
So would the term "wides" be obsolete/irrelevent when talking about Atmos due to it's object oriented processing?
I think Trinnov itself does that; if you have speakers at the Wide positions, Trinnov remapping will create signals for them regardless of the type of encoding.
Originally Posted by chimoult View Post
What about dts neo-x processing ?
Early reports of Atmos upmixing in the Receivers forum indicate that you won't miss it, i.e. Dolby Surround was preferred over Neo-X.
Noah
noah katz is offline
post #185 of 3125 Old 09-03-2014, 01:01 PM
LICENSED TO THRILL
CINERAMAX's Avatar
Quoted: 1959 Post(s)
Liked: 1099
Send a message via Skype™ to CINERAMAX
Sent from my iPad using Tapatalk HD
As per jeff and carl huff that format is killed by auromatic and probably dolby surround
PRETERNATURAL IMMERSOPHILE rAVe Best ATMOS DEMO CEDIA 2016. Most Envied Installation In Europe ( Until July). PREPARING A VERY SPECIAL CEDIA EXPO 2017 DEMO WITH ULTIMATE HDR PROJECTION AND HI-POTENCY ATMOS... OR THREE.WHEN THE LIVING ROOM WALL RIVALS YOUR 100 MILLION DOLLAR VIEW... The path to meaningful change is often walked alone.
CINERAMAX is online now
post #186 of 3125 Old 09-03-2014, 01:59 PM
SoundChex's Avatar
Quoted: 367 Post(s)
Liked: 310
Originally Posted by sdurani View Post
Atmos has the capability to work similarly, but that feature has not been implemented in 1st gen Atmos products. Close. 24 around you and 10 above you = 34 possible locations.
By that logic, terms like sides and rears are equally meaningless. In the diagram above, the speakers directly to the sides happened to be labeled L/R surrounds, but that label could just as easily be moved to the speakers just forward and rearward of those locations.
So if you have a typical 7.1 layout and add a pair of speakers between the fronts and sides, what would you call them?
EDIT: Replaced graphic with newer, clearer, and more focused image (stolen!) from the next post. Thanks Roger!
It looks to me like Trinnov already has a speaker nomenclature in place for its Atmos configuration. I think I see 'speaker name abbreviations' under the speaker numbers on the Altitude display, so perhaps we should just wait to see some "more complete" Altitude documentation . . . in the absence of extant documentation from Dolby with anything more than "guessable values" for speaker azimuth and elevation.
And more generally, Report ITU-R BS.2159-6 (11/2013) Multichannel sound technology in home and broadcasting applications (link) FIGURE 60 "summarizes" IEC 62574 “Audio, video and multimedia systems – General channel assignment of multichannel audio" and similar|related SMPTE speaker naming standards (among others), but--like the Pirate Code--the contents of these docs are "more like suggestions"!
For extra confusion, be sure also to read Recommendation ITU-R BS.2051-0 (02/2014) Advanced sound system for programme production (link) . . . which at least has the mitigating factor of being the 'first release' of this particular doc!
_
[Home Office system schematic]
"My AV systems were created by man. They evolved. They rebelled. There are many speakers. And they have . . . A PLAN."
SoundChex is online now
post #187 of 3125 Old 09-03-2014, 03:30 PM
Roger Dressler's Avatar
Quoted: 1551 Post(s)
Liked: 739
I'm glad they did a firmware update on the GUI:
Before:
After:
Should sound less occluded.
Name:	Trinnov before.jpg
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
post #188 of 3125 Old 09-03-2014, 05:59 PM
LICENSED TO THRILL
CINERAMAX's Avatar
Liked: 1099
Originally Posted by Roger Dressler View Post
Do your customers use Prima Cinema service, or are they members of the Bel-Air Circuit?
In the usa it's possible to get 4k and hfr content on a blu-ray window type.
My clients can be in the bel air circuit but don't like the short window restrictions, like primas.
You will find that more and more enthusiasts are getting dci content in the blu-ray time window.
post #189 of 3125 Old 09-03-2014, 06:28 PM
Liked: 739
Thanks for the reply. It sounds like the DCI content is delivered some other way than Primas (download) or DCPs (Bel Air). What's the format, and how does one join the party?
Right now I suspect it is limited to 7.1. Is Atmos/Auro content available?
post #190 of 3125 Old 09-03-2014, 07:01 PM
LICENSED TO THRILL
CINERAMAX's Avatar
Liked: 1099
These are DCI packages hard drive from technicolor and usb drive key.ingest at projector or over network. You need a minimum 2k projector sever combo. like this laser one is under $50 but you must add ims internal server which is like 10. If you get the doremi ims 1000 and get a cp-850 which will do home atmos too in Q1 ( but now you are up to 90 ) then yes all the atmos you want. Those prices may include signup processing with each studio which is tedious. Will need to find out more but unlike cinema you have at least a couple of months to watch. You can order in hfr 4k 2d 3d aspect ratios, and sound format.
Send me a email to peter@cineramax.com and after cedia i will send you a comprehensive package on the software deal for the below projector talk to avs.
cheers
post #191 of 3125 Old 09-03-2014, 07:13 PM
Liked: 739
^^ Thanks!
Those figures are all in kilodollars, right?
post #192 of 3125 Old 09-04-2014, 05:54 PM
NorthSky's Avatar
Quoted: 7012 Post(s)
Liked: 3553
Cool Just for fun ...
* Scroll up & down that picture (graphic design), and see what it does.
NorthSky is offline
post #193 of 3125 Old 09-04-2014, 08:00 PM
LICENSED TO THRILL
CINERAMAX's Avatar
Liked: 1099
Originally Posted by Brucemck2 View Post
Looking forward to this product. Should be a great contribution to the high end.
I remain amazed by the flexibility (and stability) of the platform in day-to-day use, and find Curt's always there to help via phone and VNC a great addition to an already strong offering.
There appears to be a correlation of super-satisfied Trinnov clients to those were Curt actually did the calibration in room, me and one other person have preferred the datasat's dirac autopilot to the remote sessioned eq's from Curt as
- I just told Curt this. He did say you and Lon had Curt in da house: CORRELATION NOTED!
Soo.... I am going into the demo with a completely clean slate in my head ( procella Genelecky type sound filter engaged). If I perceive an approximation to the well roundedness, or equal or better than Dirac you will hear from me by Friday and I likely give trinnov 2 orders, there is much to be said by being the first with Atmos out the door, and having d-cine connectivity, and having active stereo rca out's for d-box 2.0, so expect an agnostic/unbiased opinion. And godspeed to my friend the genial Curt's demo.
post #194 of 3125 Old 09-04-2014, 08:14 PM
LICENSED TO THRILL
CINERAMAX's Avatar
Liked: 1099
Is it supposed to be psychedlic?
Unfortunately Im on an air mouse living room setup.
post #195 of 3125 Old 09-05-2014, 07:03 AM
LJG
LJG's Avatar
Quoted: 404 Post(s)
Liked: 207
There appears to be a correlation of super-satisfied Trinnov clients to those were Curt actually did the calibration in room, me and one other person have preferred the datasat's dirac autopilot to the remote sessioned eq's from Curt as they can be tedious and unpredictable if pressed for time my engineer is falling asleep - I just told Curt this. He did say you and Lon had Curt in da house: CORRELATION NOTED!
Peter:
As far as I am concerned Curt is the primary reason I am still with Trinnov, and I will continue on this long adventure with Trinnov as long as Curt is involved. After Curt came to my home initially each and every calibration thereafter took less than 15-20 minutes remotely.
CINERAMAX likes this.
LJG is online now
post #196 of 3125 Old 09-05-2014, 12:19 PM
thebland's Avatar
Quoted: 1541 Post(s)
Liked: 895
Originally Posted by LJG View Post
Peter:
Curt is a true professional and knows his stuff. He'd be in my theater if I end up with an Altitude. But it is true in my experience, you need an in-person visit. When I had Carl and Mark calibrate my Datasat, we would sit there ater all ws done and say, 'dialog too bright, dialog has too many sibilants, bass a bit aggressive, etc. These guys would listen to my comments, hear what I am hearing and simply go to the necessary frequencies to adjust.
Goodbye to a great audio and video genius and writer... JOHN GANNON. I enjoyed your friendship, wit and a nice long run we took around Indianapolis at CEDIA years back... and for buying my Runco 980 Ultra years back... you saved my ass! Rest in peace.
thebland is online now
post #197 of 3125 Old 09-05-2014, 12:32 PM
thebland's Avatar
Liked: 895
Peter:
post #198 of 3125 Old 09-05-2014, 05:50 PM
NorthSky's Avatar
Liked: 3553
Yes, it's a big animated wheel on a larger screen when you scroll it up and down.
NorthSky is offline
post #199 of 3125 Old 09-08-2014, 12:40 PM
kamenoff's Avatar
Quoted: 92 Post(s)
Liked: 29
First info on pricing...40,000 Euro! Ouch...
http://highend-hifi-shop.de/trinnove-altitude-32.html
kamenoff is offline
post #200 of 3125 Old 09-08-2014, 12:51 PM
djnickuk's Avatar
Quoted: 261 Post(s)
Liked: 64
So looks like the processing add ons have added a good €15k onto the original price of €25k. Still a dam sight cheaper than the Ada reference and quite a bit better I'd imagine.
djnickuk is online now
post #201 of 3125 Old 09-08-2014, 12:59 PM
sdrucker's Avatar
Quoted: 776 Post(s)
Liked: 527
For us non-Europeans, that's with 19% VAT.
Audio Gear: Trinnov Altitude 16/24, NAD M27 (2) and Wyred4Sound MMC-7 amps
Video (early June): JVC RS600, Seymour 100" UF Screen, Lumagen Radiance Pro 4442
Misc.: Oppo 103, Oppo 203 UHD player, JRiver
Speakers: PSB Imagine T3 LCR, Imagine T Wides and Rears, T2 Side Surrounds, PSB CS1000 ceilings (6), HSU ULS-15 Mk 2 subs (4) - 9.4.6
sdrucker is online now
post #202 of 3125 Old 09-08-2014, 01:10 PM
djnickuk's Avatar
Quoted: 261 Post(s)
Liked: 64
Lucky so and so. Saving a whole 1% over us Brits. Lol. I think the top altitude comes in at £32k in UK and the Ada reference is £48k.
post #203 of 3125 Old 09-08-2014, 02:15 PM
LICENSED TO THRILL
CINERAMAX's Avatar
Liked: 1099
New ADA Monster Atmos Preamp to be shown at HYATT
post #204 of 3125 Old 09-08-2014, 03:01 PM
djnickuk's Avatar
Quoted: 261 Post(s)
Liked: 64
Lol. I'm guessing an altitude 32/32 in a funky case but with a $75k price tag?
post #205 of 3125 Old 09-08-2014, 03:03 PM
thebland's Avatar
Liked: 895
But ADA has a penchant for making products that are NOT upgradable.
post #206 of 3125 Old 09-08-2014, 03:08 PM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 385 Post(s)
Liked: 273
With whose room correction? I've checked with Trinnov and they're not involved in any new ADA product.
RUR is offline
post #207 of 3125 Old 09-08-2014, 03:12 PM
sdurani's Avatar
Liked: 3204
There's a stack of miniDSP boxes inside the monster chasis.
Sanjay
sdurani is offline
post #208 of 3125 Old 09-08-2014, 03:18 PM
djnickuk's Avatar
Quoted: 261 Post(s)
Liked: 64
Quite true!
Hahaha! Good one.
Perhaps they will go back to PEQ so they can sell some TEQs.
post #209 of 3125 Old 09-08-2014, 03:20 PM
LICENSED TO THRILL
CINERAMAX's Avatar
Liked: 1099
here
invite
there is some kind of wifi antenna boner going on in there
post #210 of 3125 Old 09-08-2014, 05:37 PM
3D Audio Consultant
Curt_Trinnov's Avatar
Quoted: 72 Post(s)
Liked: 119
Peter/CINERAMAX, you have me guessing too. Sorry I can't add any details, but I can
squelch any speculations: Trinnov is not involved with ADA's new product offering.
Here's some additional Trinnov news: Dolby's link on consumer products with ATMOS-
http://www.dolby.com/us/en/technolog...-products.html
Trinnov Altitude 32in the lower right. Trinnov's Altitude 32 will be shown at CEDIA Booth 850.
Let me know if you're going to attend. It would be my pleasure to meet anyone here, including lurkers.
PM for my cellphone.
Cheers,
___________
Curt Hoyt
3D Audio Consultant
Trinnov Audio
USA
Curt_Trinnov is offline
