What do you think about Belden wiring being the "it" wire? - AVS Forum | Home Theater Discussions And Reviews
Old 02-10-2014, 10:53 AM - Thread Starter
ComputerTech0903's Avatar
They're commercial and probably have scientists working on their wire. I checked a while back on cable theory in characteristics of science terminology, and I found wire, ordered it and now I have it in my basement waiting for tech flex. Also, I have belden power cable, and they have a natural XLR wiring that is as good as blue jeans cable.
What do you think of Belden $1 a foot wire beating out a $30,000 pair of Oracle MIT speaker wiring or $1 a foot power cable beating out $15,000 power cables?
Generic Chinese connectors on eBay.
I might use home theater cable theory in a car audio system. Here's what I want:
Of course I'll solder all the wire connections.
Belden Speaker Wire Tex Flex in the back
Belden BJC-1 with Teck Flex in the back
Belden Power Wire with Tech Flex in the back X 3
http://www.woofersetc.com/p-11634-p9005-precision-power-5-channel-class-d-phantom-series-amplifier.aspx X 2
http://www.woofersetc.com/p-8450-es-63i-cdt-audio-65-2-way-braxial-coaxial-speakers.aspx X 2
http://www.parts-express.com/tc-sounds-lms-ultra-5400-18-dvc-subwoofer--293-666 X 2
http://www.woofersetc.com/p-2874-dqxs-audio-control-digital-equalizer-crossover.aspx
http://www.sonicelectronix.com/item_62699_Ground-Shaker-SQXL-1-15-BLACK.html X 2
http://www.parts-express.com/dayton-audio-ts400d-4-15-titanic-mk-4-subwoofer-4-ohm--295-405 X 2
http://www.woofersetc.com/p-5794-shc6030-stinger-hpm-30-farad-hybrid-digital-power-capacitor.aspx
http://www.woofersetc.com/p-4400-sp2150-stinger-power2-max-dry-cell-battery.aspx - Maybe? I have to check the new size when I get a new used AWD car for the winter with snow tires.
http://www.sonicelectronix.com/item_4291_Alpine-RUE-4190.html
http://www.sonicelectronix.com/item_76245_Pioneer-AVIC-8000NEX.html
I'll have to offer $1,000 for a craigslist installer, and buy a lot of stuff or as much as I can on eBay.com.
Screw factory direct dampening material and I'm going with dynamat.
There's no 18" subwoofer boxes.
I'll need a new high draw alternator, but it's ok I can spare some fuel efficiency and they're class D amplifiers, not AB.
The subwoofers will be crossover and be the bottom part of the L and R signal so accurate 2 channel with filler speakers in the back.
The daytons are more affordable and just as good for Audio anyways, not HT, and a lower FS, and maybe a better home theater subwoofer anways?
No Blu Ray in the car? What the F!? Lol.
Anyone can use this in a car they might own or own one day if they want!?
I personally might hold back on the capacitor and battery and maybe the head unit but probably not the head unit.
ComputerTech0903 is offline
Old 02-10-2014, 11:07 AM
isb
isb's Avatar
I just bought some 10-4 stranded copper power cable (less than $3 per foot), which I used to bi-wire a bedroom system this weekend. The system sounds great. I have some Transparent XL bi-wire in the den system. I should do an A-B one of these days! The idea came from a comparison test done years ago by one of the audio magazines (Stereophile?) The cheap power cable did surprisingly well.
isb is offline
Old 02-10-2014, 07:39 PM
Peter M's Avatar
Quoted: 162 Post(s)
Liked: 177
Cable war about to break out in 10, 9, 8, 7 ...
Cheers,
Peter M is offline
Old 02-11-2014, 12:32 PM
Glimmie's Avatar
Quoted: 732 Post(s)
Liked: 596
Cheers,
The OP is a troll, nothing more. He started a pointless thread last week that was sure to erupt so the moderator deleted it.
Glimmie is offline
Old 02-12-2014, 06:01 AM
isb
isb's Avatar
Sorry to add fuel - I didn't know.
isb is offline
