New player coming for 2K DCI Cinema - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 45Likes
post #91 of 122 Old 07-28-2014, 08:23 PM
ccool96's Avatar
Quoted: 330 Post(s)
Liked: 471
Congrats Alan,
I wish I could of made the demo this past weekend. By the way Peter talks, you have really outdone yourself.
I have had the pleasure of working with Alan over the past couple years and never have I met someone as enthusiastic about home cinema as him..... well and Peter too
I have bought both my Barco DP4K-23B and my DP4K-P from Alan. I have learned a ton from him over the past couple years, and he has helped me tweak my projectors to really get an incredible image.
I have had the pleasure of visiting his place and seeing his demo setup in the past, and sounds like it's about time for me to make another trip down.
And to put to rest anyone's concern about feeding a DCI machine alternative content, you can rest assured there is absolutely zero problems. I feed my projector everything from DCI content to blu-Ray to Directv to AppleTV to a Mac Mini to multiple game systems, and the list goes on and on. And feed it 3d bluray. All works flawlessly if you know how to setup your presets correctly. There is zero issue switching between sources or between DCI content and alternative content.
Congrats Alan. Can't wait to see what you had done to the NEC.
ccool96 is online now
post #92 of 122 Old 07-29-2014, 09:00 AM
PRETERNATURAL IMMERSOPHIL
CINERAMAX's Avatar
Quoted: 1681 Post(s)
Liked: 921
Send a message via Skype™ to CINERAMAX
Originally Posted by CinemaAndy View Post
It makes a lot more sharper and cleaner picture on larger screens. I have talked to some who have up-scaled 1080P to 4K on various DCI projectors. And got some mixed views, nothing great was what i came away with. Artifact heavy was how one described it.
On a large screen, up-scaled 1080x1920 to 1080x2048 adds enough pixels that it makes for better viewing, without artifacts. I don't know exactly why, but it does work very well.
Andy I agree with you on 80% of things and enjoy your anecdotes, but man some of the stuff you throw from left field I completely disagree with, why scale, on Barco 2k you must definetely not scale.
Sincerely, GC*
rAVe Best ATMOS DEMO CEDIA 2016. HOARDS AWARDS, ACCOLADES, 1ST ART CREDS.,WLD. RECORDS, & HI PERFORMANCE 16-24-32-48 CH. MIDI-PLF CINEMAS WW. - CUSTODIAN HIGH END IMMERSIVE CINEMAS TO SMPTE & ADV. IMAGING SOC. HELP Combat Channel Insufficiency with Altitude 48!*GC = GANGSTA C. genus: cineramus maximus. GC Twitter (Now staging Humanitarian Relief Aide to Great Bel-Air Circuit B-chain & 6P/HDR Projection Famine of 2017)
CINERAMAX is offline
post #93 of 122 Old 07-29-2014, 10:20 AM
donaldk's Avatar
Quoted: 413 Post(s)
Liked: 86
Actually small fraction scaling is the hardest thing to do right, and is hardly ever done without losses. So it isn't in the scaling, it can be that the TI processing chips handle that better, as there is some trickery going on in there, as mentioned by Peter above.
Now what can be done is lossless remapping of a smaller colourspace like rec.709 to DCi or Rec. 2020, or the LCD panels native colourspace. That may even be non-lineair, like LASER although with much wider spikes.
A lot of work on this was done at the old glowbulb factory down south.
donaldk is offline
post #94 of 122 Old 07-29-2014, 05:06 PM
CinemaAndy's Avatar
Quoted: 700 Post(s)
Liked: 136
Yes, well 80% is passing.
I don't pretend to know all things alternative content on DCI spec equipment. That is not my area. However, many a owner sees the money from renting out screens for presentation, birthday parties, private screenings, etc. So i am getting asked again and again how to do this so a 16 year old kid for a projectionist can do it.
I have found two products i really love, Christie SKA-3D, multiple input's, HDMI 1.4b, 3D BR. Easy to integrate with standard equipment, rack mount, will decode any audio, will run dual projectors for best 3D. Simple plug an play, just like home CE.
For HTPC, BlackMagic Design DeckLink 4K Extreme. As we both know, big projectors love HD-SDI inputs Audio takes some extra effort but can be done. I projected Planet Earth on BDR with this set up, on a 80 foot screen, you would be hard pressed to tell it was alternative content, you would have to look very hard and know what you are looking for. The owner told me nice, but i want Blu-Ray not DCP, and i told him, this is Blu-Ray! And it was a Barco 4K
Both of these are a easy way to get alternative content on large screens and look good.
And the payoff is never certain: Some observers contend that a generation has already been trained to be content with the small screen.
Some servers can do non-encrypted playback to an A/V projector, but it's just a ridiculously expensive media player if you don't have a cinema projector.
CinemaAndy is offline
post #95 of 122 Old 07-29-2014, 06:59 PM
CinemaAndy's Avatar
Quoted: 700 Post(s)
Liked: 136
Originally Posted by AV Science Sales 5 View Post
One piece. I tried to attach a drawing, but the file was too big.
Depth of projector with out lens shroud, 846.9mm
Depth of projector with lens shroud, 1,042mm
Width of projector, 700mm
Height of projector, 326mm
I would be interested to know if this projector can fire up a 10.6x25.2 foot screen with a 43-5 foot throw.
post #96 of 122 Old 07-30-2014, 10:53 AM
CINERAMAX's Avatar
Liked: 921
ive heard good things about the christie piece, used to do dimension 3d rigs but the christie is plug and play, now with the latest doremi D3D firmware you can triple the apparent clarity ,brightness and sharpness of the picture. So just as I thought i was out they pull me back in.:-D
I'll focaround with the blackmagic card, thanks for the tip.
Sincerely, GC*
post #97 of 122 Old 08-04-2014, 08:52 AM - Thread Starter
Mike Garrett's Avatar
Quoted: 5584 Post(s)
Liked: 3565
You did not give the gain of the screen, but yes it can fill that screen from 43'-5" using a choice of two lens, 1.33-2.1:1 or the 1.62-2.7:1 lens. Your throw range is 1.72.
Ericglo likes this.
mjgarrett100@gmail.com
Mike Garrett is offline
post #98 of 122 Old 08-04-2014, 09:27 AM
Art Sonneborn's Avatar
Quoted: 238 Post(s)
Liked: 295
What kind of lumen output are you getting after the two aperture plate modification ?
Art
My HT
iRule rules my theater
Art Sonneborn is offline
post #99 of 122 Old 08-04-2014, 12:21 PM - Thread Starter
Liked: 3565
Art
I hope to receive the specs this week. Will let you know.
Ericglo likes this.
post #100 of 122 Old 08-06-2014, 10:27 AM - Thread Starter
Liked: 3565
Art
With the modifications we were seeing 50FL with the light output cut down. This was on a 10' wide 0.8 gain scope screen. In high lamp we were seeing over 100FL. So that would mean in low, 3,511 lumens and high lamp is over 7,000 lumens, after mod.
Ericglo likes this.
post #101 of 122 Old 08-06-2014, 11:25 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3040 Post(s)
Liked: 2973
I've been complaining for years that most projectors aren't bright enough. Even my Lumis. With this projector, I'd have to eat my words for sure. And get a bigger screen !!
Ericglo likes this.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #102 of 122 Old 08-06-2014, 12:53 PM
LJG
LJG's Avatar
Quoted: 329 Post(s)
Liked: 142
Thanks Mike, and what is the respective On/Off with the Mod's in place?
LJG is online now
post #103 of 122 Old 08-06-2014, 01:38 PM - Thread Starter
Liked: 3565
I believe a little over 5,000:1. As everyone that has viewed this image said, the blacks looked very good.
Ericglo likes this.
post #104 of 122 Old 08-06-2014, 07:19 PM
Quoted: 238 Post(s)
Liked: 295
Great to hear !
Ericglo likes this.
My HT
post #105 of 122 Old 08-06-2014, 10:05 PM
donaldk's Avatar
Quoted: 413 Post(s)
Liked: 86
Not too much given away over the original 11K lumens. But does this still allow for a constant light-output like with the other LASER projectors, compensating for the lifetime dropp-off of 30(+) percent?
donaldk is offline
post #106 of 122 Old 08-08-2014, 04:24 PM
CINERAMAX's Avatar
Liked: 921
Guess what laser projector the color of this one reminds me of?
I am very particular about the barco colors, their new $350k laser 2 piece monsterprojector has incredible colors, barco whites are paper white, with their new laser 6p projectors the whites were to cry good. Well this little fvckr projector had very similar colorimetry to the Barco Laser DCI, but on Blu-ray.
Heres the Barco:
required chiller unit
projector head
quite the space savings for very familiar color, no?
ID:	203513   Click image for larger version
ID:	203521   Click image for larger version
Craig Peer likes this.
Sincerely, GC*
post #107 of 122 Old 08-08-2014, 05:09 PM - Thread Starter
Liked: 3565
Laser 3C cut sheet. Due to size restriction, I had to reduce this down. If anybody wants a larger version of this, shoot me your email address and I will send it to you.
Name:	cut sheet-6.png
Ericglo likes this.
post #108 of 122 Old 09-04-2014, 09:40 AM - Thread Starter
Liked: 3565
The Laser 3C is now available for demo on the west coast as well as the east coast. The modifications design has been completed and MIT has installed the modifications. If you would like to demo this projector, please let us know.
East coast demo's will take place in Bradenton, FL 34210.
West coast demo's will take place in Fountain Valley, CA 92708. (regular business hours MIT facility)
Ericglo likes this.
post #109 of 122 Old 09-26-2014, 10:10 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 2973
Anyone else see this projector yet?
Ericglo likes this.
post #110 of 122 Old 12-19-2014, 12:41 PM
ChopShop1's Avatar
Quoted: 293 Post(s)
Liked: 289
Why did this thread die so abruptly?? I actually just found it and was looking at this as being a possible contender...with some discussion of course. Has it not yet been made available or folks not gotten to demo??
ChopShop1 is offline
post #111 of 122 Old 12-19-2014, 07:44 PM
donaldk's Avatar
Quoted: 413 Post(s)
Liked: 86
4K happened. I basically asked the same question last week in a different thread: Projector for 14' to 15' Wide Cinemascope Screen!.
donaldk is offline
post #112 of 122 Old 12-22-2014, 02:18 PM
ChopShop1's Avatar
Quoted: 293 Post(s)
Liked: 289
Thanks, 4k hasn't grabbed me yet, though I will say it'd be tough to spend $30k on this without some seat time. Don't get me wrong, I'd love a 4k unit, but it doesn't feel settled enought yet. I had a real problem with my house/theater that is now corrected, but it will still be a while before I need to install a pj and screen, so I'll sit back and see what comes
post #113 of 122 Old 12-22-2014, 07:03 PM
rabident's Avatar
Quoted: 335 Post(s)
Liked: 107
Is it $30k ? The NEC bulb projector was around that. For the laser version I read under $50k for the PJ itself. That's for the stock projector without the after market mods for CR. I was only going to consider it if I could go ultra short throw on it, which I think makes sense for laser, but NEC didn't have the lens options for it. Like you, I had problems with my room build, so in no rush to buy a projector before the room is done.
rabident is offline
post #114 of 122 Old 12-23-2014, 12:36 PM
CINERAMAX's Avatar
Liked: 921
I do not know where the rumors of the smaller 4k dlp chips coming around the corner are coming from, TI built them and showed them to the cinema and consumer manufacturers who found the cost performance not worth it due to low demand hence companies like NEC and dpi are sticking to the cinema chip which is music to my ears because that is where the best lenses are.
Any DCI projector with a .98 chip will handle the 1.2 to 1 fixed lens. What we did at soho house rear projection.
Sincerely, GC*
post #115 of 122 Old 12-23-2014, 10:29 PM
rabident's Avatar
Quoted: 335 Post(s)
Liked: 107
Unless I'm misreading between the lines, this was written last year.
However, it will be some time before we see numerous mainstream 4K home cinema PJs. This is because Texas Instruments has partnered with digital cinema projector makers Barco and Christie Digital Systems to develop a 4K DLP solution, and as part of that deal has signed a non-compete clause which prevents it producing 4K DLP chips for home use. Alan Roser, managing director of SIM2 UK, told HCC: '4K is perfect for home cinema projection, but we won’t really see it until 2015 when TI is in a position to ship 4K chipsets. [Then] the floodgates will open.'
http://www.homecinemachoice.com/news...about-4k/16776
rabident is offline
post #116 of 122 Old 12-24-2014, 10:14 AM
donaldk's Avatar
Quoted: 413 Post(s)
Liked: 86
And Peter says this has passed already. Now if Sim2 would order 5K sets...
donaldk is offline
post #117 of 122 Old 12-24-2014, 10:22 PM
CINERAMAX's Avatar
Liked: 921
Thanks Rab, I was discussing this with MiT operations vp that said that everyone had taken a look at the smaller 4k chips and that both DCI and Home manufacturers PJ , did not jump on it. Why I do not know, mebbe 8k is coming faster than we know. Just Kidding.
Sincerely, GC*
post #118 of 122 Old 12-25-2014, 06:38 PM
donaldk's Avatar
Quoted: 413 Post(s)
Liked: 86
LCoS with E-shift, 8K projectors are already shipping Peter.
donaldk is offline
post #119 of 122 Old 12-29-2014, 12:56 PM
rabident's Avatar
Quoted: 335 Post(s)
Liked: 107
I was just pointing out what I thought the source of the "4k DLP in 2015" rumors were.
rabident is offline
post #120 of 122 Old 12-30-2014, 07:58 AM
LJG
LJG's Avatar
Quoted: 329 Post(s)
Liked: 142
So the consensus is no new Texas Instrument 4K smaller consumer chips for 2015? I guess consumer projector manufactures can purchase 4K cinema chips and implement those in there consumer 4K projector. Interested to see what Christis unveils in their new consumer line in 4K, or smaller compact 4K professional. Happy New Year to all!!!!!!!
LJG is online now
