Sim2 Lumis Fan Noise - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-23-2014, 10:33 AM - Thread Starter
zantimisfit's Avatar
Hi,
I had a Sim2 C3X 1080 Projector but recently changed to the Sim2 Lumis. Fan noise is  louder. I was wondering if anyone has changed the fans out for  silent ones, or are these fans as quiet as they come. They state that the new Fuoriserie Projector has quiet fans fitted so maybe only now they have started using them..
zantimisfit is offline
post #2 of 7 Old 04-23-2014, 10:43 AM
thebland's Avatar
Quoted: 1490 Post(s)
Liked: 841
DO you have the fan mode in 'High Altitude' mode? I can't recall but there are a couple of modes to reduce such. Does your sit over your head?
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is offline
post #3 of 7 Old 04-24-2014, 05:08 AM - Thread Starter
hello,
Yes its at the lowest setting and  it does sit over my head.
post #4 of 7 Old 04-24-2014, 09:59 AM
thebland's Avatar
Liked: 841
I had a loud fan on mine. I sent it back and it was replaced (it was the exhaust fan rather than the intake fan).
thebland is offline
post #5 of 7 Old 04-24-2014, 03:12 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3037 Post(s)
Liked: 2969
Do you have the Lumis, or Super Lumis? I imagine the Super Lumis would have a bit more fan noise with a 350 watt lamp to cool, but I'm just guessing. My Lumis is in a projector closet, so I don't even know how loud that one is.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #6 of 7 Old 04-24-2014, 03:17 PM
Armand07's Avatar
Quoted: 74 Post(s)
The Superlumis actually has a bit less noise than the Lumis because of a new cooling system.
Armand07 is offline
post #7 of 7 Old 04-24-2014, 03:26 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 2969
Good to know !
