Ultra Short Throw Projection - AVS Forum
post #1 of 6 Old 12-18-2014, 08:24 PM - Thread Starter
taichi4's Avatar
Quoted: 151 Post(s)
Liked: 94
This may not be the right forum to post this in, but does anyone know of a 17,000 to 18,000 lumen projector-ultra short throw lens combination... something capable of filling a 60 foot wide 30 foot high screen from a very close distance?
taichi4 is offline
post #2 of 6 Old 12-18-2014, 11:41 PM
MovieTime's Avatar
Define "ultra" short throw. Go to digitalprojection.com and you'll see a number of projectors that fit your bill in lumens output. Most of them have fixed lens short throw options, somewhere between .6-.8. That's pretty darn short, but not like the new Sony that goes right underneath the screen. Others like Christie probably have something like that too.
Keep in mind it becomes much harder to get a sharp, high quality picture and even focus across your screen with a throw that short. You end up with a rounded lens to achieve throws that short others may chime in here with something specialty at that brightness I'm not aware of.
MovieTime is offline
post #3 of 6 Old 12-19-2014, 05:12 PM - Thread Starter
taichi4's Avatar
Quoted: 151 Post(s)
Liked: 94
Originally Posted by MovieTime View Post
...Most of them have fixed lens short throw options, somewhere between .6-.8.
With .6-.8, do you feel that sharp, high quality picture and even focus suffers, or were you referring to the Sony, which is more extreme?
taichi4 is offline
post #4 of 6 Old 12-19-2014, 05:37 PM
CINERAMAX's Avatar
Quoted: 276 Post(s)
Liked: 87
There is no sharper picture than a fixed short throw lens, period.
But what you are repeatedly failing to disclose is your throw distance in feet.
CINERAMAX is online now
post #5 of 6 Old 12-19-2014, 05:59 PM - Thread Starter
taichi4's Avatar
Quoted: 151 Post(s)
Liked: 94
I am not failing to disclose anything. This is for a story which I need to have grounded in fact. The throw distance needs to be as short as possible, but is not a determined distance. The screen can be from 50-60 feet wide, and 30 feet high.
Frankly, I was a bit confused by your initial comment regarding clarity. It appeared that you were saying that either short throw at .6-.8 OR Sony's extreme short throw compromised picture quality. I didn't know that you were apparently speaking of a variable lens vs a fixed lens.
taichi4 is offline
post #6 of 6 Unread Today, 07:31 PM
CINERAMAX's Avatar
Quoted: 276 Post(s)
Liked: 87
Unless they are Schneider Cinelux or better I would stay at 1 to 1
To minimize pincushion Toroidal geometric distortion I would recommend that you stick to 1 to 1 like in my old RealD 4D labs' 17 feet wide image thrown from 17 feet back..
YOU cannot imagine the MTF (detailed resolution in mid to high frequencies) of this setup. As I said I seldom use the zoom lenses since.
Here is info on schneider
