Conceptualizing the Ultimate Front Soundstage System for CLEDIS - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #1 of 68 Old 04-03-2017, 02:45 AM - Thread Starter
CINERAMAX's Avatar
Quoted: 2273 Post(s)
Liked: 1296
Send a message via Skype™ to CINERAMAX
Smile A display so lifelike it will rival any 1oo million dollar view !
Someone mentioned that the eye can tell the difference between a 55 at 5 feet from lcd and 5000 projection.
Actually the 65 oled has better colors but it is the equivalent of looking at a 16 foot wide cledis from 18 feet if you seat 73" close to the OLED. on a 77 is like 1 to 1 relationship and this is better image than the 5000 by a long shot. For a single seat i understand the drama of the theater and all the family get together memories. Im done with new theaters after loge elara naiad and the old moons rgb updates, those that cannot be converted to cledis that is.
Thanks to the person that challenged me, as i now can go sell these with 2 tiles w controller and sony 77 oled.
Name:	cledis specifications.jpg
ID:	2065529   Click image for larger version
Name:	cledis 5 feet tall on hd times 4 for 4k the max.JPG
ID:	2065537   Click image for larger version
Name:	77 oled at 6.jpg
ID:	2213449   Click image for larger version
Name:	65 oled at 73.jpg
ID:	2213465   Click image for larger version
Name:	Cineramax SONY CLEDIS.jpg
CINERAMAX is offline
post #2 of 68 Old 04-03-2017, 02:47 AM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
Post Reserved to explain Slap echo from surrounds hitting glass screen
This will require some serious thought as it will degrade the quality of the sound in the auditorium, rear surrounds will have to be lifted and reangled so that they hit the glass on a downward slant. This will eliminate the backmost atmos tops as the rear wall ceiling zone soundfield could conflate with the newly elevated surrounds.
Re recfording rooms should by suitably adapted as well at some future point in time.
This post is for my friends at Atmos.
post #3 of 68 Old 04-03-2017, 02:48 AM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
Cool Horizontal Variant (X) Deployment
...This TORUS can work great with 3d remap, with the 9 foot tall cledis CL and CR can be added too for virtual SDDS. DUAL MONO CENTER.The vertical center of the LCR is only off by 8 inches or so. Easy fix.
To clear the lap pool we used periscopic projection.
One Hyde Park during installation custom dual mono.The square footage of that compact cinema costs over 10 million pounds.
RealD Passive 3d rearprojection- The World's first 1990.PANDORA SNUG at SOHO House.Dual Mono , sucker worked well.
narrow space ideal for dual mono...
ID:	2121465   Click image for larger version
post #4 of 68 Old 04-03-2017, 02:50 AM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
Reserved for Vertcal Over Under (Y) Variant deployments
post #5 of 68 Old 04-03-2017, 02:51 AM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
X-Y Hor and vertical array deployments 3 side speaker framing, 4 side speaker framing
....This one TORUS Room was supposed to be replete with Russian Musical Instruments, busts and paintings of the great classical composers of the land.
CINEOLED CONCEPT think CINECLEDIS now. James Loudspeakers, bespoke arrays.
fe: Horizontal dual mono in a yacht for 100" display... They were projecting oled 98 2 years ago..Right.
The width channels were also created phantomly at 55 degrees plus the surround side backs from a triple mono side speaker.
Triple mono speakers would be used to replace the 7.1 b&W cinema line. The surround position would project sound for the widths and the surround sides 2
Proposed Torus Dynaudio Acoustics for M Jordaan Moon Kiviuk (the 23rd moon of Saturn)
TORUS better than reald ultimate screen for HDR. ANSI cr preserving excellence.
DIONE-BLUMENAU BRAZIL 2005 giant dnp screen.
Prometheus Carl Fischer Estate Miami Beach FL.
EUROPA THE ONLY HOME THEATER IN THE WORLD co-DESIGNED with ZAHA HADID.3.25 Million Dollars.
EUROPA Work In progress halted by the democrats anti russian politics.Might as well go cledis when it resumes.
60 plus 10" woofers covered with 2 carats worth of diamond as a stiffening agent just to prevent compression.
multiple D'agostino amps
Engineering coordinated in 3D realtime with RHINO.
LR flanked, c below, lc and right center over under, all to be handled by 3D remap.
MSB amps below plate glass floor panel for that space age reactor look. (not aaccepted by ZH.
post #6 of 68 Old 04-03-2017, 02:52 AM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
MoreX-Y Hor and vertical array deployments 3 side speaker frame, 4 side speaker frame
Overloaded Images in a bove post. SINCE here is where the solution does lie I have added an extension.
Atlas,
aOn Prologic that tiny center channel was no match for the line arrays, i left the center off, sounded glorious, best sounding Torus room to date.
I will use alcons in the upcoming conceptauls L R line arrays over under partial array modules a la sdds.
This is how I know ARRAYS on the sides will totally KILL IT with CLEDIS. BTW first Barco 9"crt that later after measuring in My Home the weekend of the ISF formation Joel and Joe pushed Runco who went in 5 times to see my demo at Stereophile 94 (the home theater sensation of the Show-JGH). The lined was pulled from under me because of runco exclusive.Urghh.
Later Runco sold the company for 30 million thanks to me. All you guys had them Runcos I had ordered in 1992.
post #7 of 68 Old 04-03-2017, 02:54 AM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
driver types and complements
line arrays
partial arrays
coaxials
Driver dispersion requirements
post #8 of 68 Old 04-03-2017, 03:03 AM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
reserved
Here will come my moon experiments and conceptuals ... WE HAVE NOTHING TO FEAR BUT FEAR ITSELF. Psychoacoustics are in their infancy.GC.
Name:	CINERAMAX CINEOLED TRI-SPEAKER SMALL.jpg
ID:	2065185   Click image for larger version
ID:	2065201   Click image for larger version
post #9 of 68 Old 04-03-2017, 03:35 AM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
Cool Under screen soundbar like array
HERE IS A BIG ONE WITH SPEAKERS UNDERNEATH TOED UP.
Speakers under has been the only real problematic solution in some cases, best try to avoid unless at eye ear level.
Dan Marinos 1996 Confidence 3 rearpro setup has the speakers under but left right under the mC Racks due to academy aspect ratio. Sounded awesome
Pharrell's Jetson PH in Miami, synthesis one under the screen.
Hey if it is good enough to compose megahits like Happy on, ...
Inspiration For SONY HOUSE OF THE FUTURE in Paris 1991
My Coconut Grove Lab JBL synth one sounded awesome in that room.
Cant Believe I lost this original awesome Charles Harrison Pawley (rip) house overlooking biscayne bay with rearpro, great sounding due to acoustical ceiling.
Name:	mimas synthesis 1.jpg
ID:	2067273   Click image for larger version
ID:	2067281   Click image for larger version
ID:	2067289   Click image for larger version
ID:	2067297   Click image for larger version
Name:	one hyde park dUAL mONO.jpg
ID:	2067313   Click image for larger version
ID:	2067321   Click image for larger version
ID:	2067329   Click image for larger version
ID:	2067337   Click image for larger version
Name:	Telesto 13 D Marino.jpg
ID:	2068321   Click image for larger version
post #10 of 68 Old 04-03-2017, 04:12 AM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
The list goes on and on, it will time to complete this.
post #11 of 68 Old 04-03-2017, 06:32 AM
Art Sonneborn's Avatar
Quoted: 397 Post(s)
Liked: 511
What is the cost of the individual modules and how large are they ?
Art
Art Sonneborn is offline
post #12 of 68 Old 04-03-2017, 06:46 AM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
Art
SONY SAID THERE WOULD BE ECONOMIES OF SCALE FOR CINEMA. don't know if present or projected but I was told that the screen that size was under 150k. It's a steal. The glass does not reflect. Theoretically the pixar guys told me that they could max out hdr to 21f-stops with trillions of calculations per second. The maximum viable for cinematic live action HDR with todays high end cameras is 16 f-stops, CLEDIS handles it all with finesse.
I have pictures of the modules and will post dimensions necessary for 4k/1080p. One could start small and then quadruple i guess. In my case at least.
post #13 of 68 Old 04-03-2017, 07:17 AM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
roughly 11 by 17
The tileas appear to be a bit over 15 inches wide by 17 high,will double check.
The blooming is my camera but yiu can tell by chair and desk it was about 21 feet wide.
Close up did not reveal module structure.
Name:	CLEDIS 10 x 17.jpg
ID:	2065385   Click image for larger version
ID:	2065393   Click image for larger version
ID:	2065401   Click image for larger version
Name:	cledis dimensions.JPG
post #14 of 68 Old 05-06-2017, 12:08 PM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
these things will beat any view you might have in your home
...conceptuals. Please no critique on close seating distances and no immersive audio provisions, solutions abound, the very subject of this thread, I will share ideas as I go along.
My new message to mega million dollar PH Owners:"Widen your gaze..."
ID:	2120561   Click image for larger version
Name:	CINECLEDIS 40 chANNEL wIDEN yOUR gAZE.jpg
skoolpsyk likes this.
post #15 of 68 Old 05-06-2017, 04:13 PM
ccool96's Avatar
Quoted: 481 Post(s)
Liked: 679
Art
I dont know about the CLEDIS exactly, but as a comparison, DPI just released their Radiance Tiles.
A 4K setup would be a 20' wide 16:9 screen with their 1.58mm pixel pitch panels. The system cost $543,000.00
That system price includes 100 panels which makes up 4K.
Each panel is 23.94" x 13.46" with a resolution of 384x216. A 10x10 matrix of 100 panels gives the 3840x2160 resolution.
Each panel cost $5000.00. So $5,000.00 x 100 = $500,000.00 for the LED Tiles.
The additional $43,000.00 is for the controllers and mounting frame.
Their system is front serviceable and 1000nit brightness.
CINERAMAX likes this.
ccool96 is online now
post #16 of 68 Old 05-06-2017, 04:33 PM
mhafner's Avatar
Quoted: 190 Post(s)
Liked: 71
I'll wait for the acoustically transparent version that does 8K for 4K 3D at 3.5m wide so it fits into my room. :-)
mhafner is offline
post #17 of 68 Old 05-06-2017, 06:05 PM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
Samsung went from 3,500 to a three digits number per foot at cinemacon i believe theirs is bigger though,more than one theater chain bought in. the sony is 9x16 feet wide for 4k but it has only 4 x dvi, no kelidescape thats for sure. They need to add hdmi.
For the cinema it would be sweet if they just have an IMS that way you can even hookup the Dolby IMS with all digtal 34 channel atmos and dolby vision (my speculation that will happen as i am proposing right now to Andrew and Pat in the vp office.
Isn't my concept more luxurious and cool than what's going to a cinema to get the retinas pierced?
In any event this is the entry level folks, count the chairs in the front row that is 2 feet each that is what the samsung needs to do 4k 4 times the sony that is why its in theupper mid 3 digits per sq. foot. I am waiting to the closer to OLED looking CLEDIS with HDMI.
Above real image, looks like a best buy LCD, below...??? As a photoshop expert witness....
You will see these samsung cinemas popping up BY XMAS 2017. Yup.
Name:	samsung cinematiles 3.jpg
ID:	2121377   Click image for larger version
Name:	samsung cinematiles 2.jpg
ID:	2121385   Click image for larger version
Name:	samsung cinematiles 1.jpg
ID:	2121393   Click image for larger version
Name:	samsung cinematiles 4.jpg
post #18 of 68 Old 05-08-2017, 03:02 PM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
That worries me that there is a bigger gap than CLEDIS Hairline fracture look.
again the cledis in 4k is 9 by 16 feet, kind of a nice touch.Easy to do dual mono audio from the side if using alcons due to extreme phantom imaging potential.
post #19 of 68 Old 05-09-2017, 10:16 AM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
Talking Friends In High Places.....
Bryan , Adam had I known that Andrew was to become the CINEMA BOSS, i might have worded that: "What the Hell Where You Guys Thinking Of when You Left Out the widths out of DSU?" slightly different.
That was funny right guys.? I did give him great praise for 10 uninterrupted minutes leading to that part.
Another inside joke with Andrew, during the praising part (right guys?) i told him that other people at dolby cinema were suits that he was a true enthusiasts. He responded: "An Enthusiast Suit."
This guys will help the PROSUMER Home Cinema in ways few of you now can envision. DOLBY CINEMA FOR MICROPLF (projection or Micro Led), watch, you heard it from me first!!! I predict. You know my crystal ball.
CONGRATS ANDREW; Living proof that we are living in a new MERITOCRACY!!!!
Name:	andrew is boss.JPG
ID:	2127137   Click image for larger version
appelz likes this.
post #20 of 68 Old 07-01-2017, 11:13 AM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
Cool No More NEW Projection Moons for me.... just the existing here in progress &w updates
I'm going to get on the ground floor of this and seize and opportunity NOW while the price is 750k for a 16x9 4k screen. Will be focusing my efforts strictly on the cledis and a design collaboration with dynaudio, but i have scheduled meeting with the top design tower developers in Miami, and have tremendous incentive for the owners to recommend I sell 6 of these in their buildings... I leave the smarties here to figure out what the compelling enticement is.
WISH ME WELL YALL.
Billybobjimbob likes this.
post #21 of 68 Old 07-03-2017, 02:09 AM
mhafner's Avatar
Quoted: 190 Post(s)
Liked: 71
Cledis type tiles need to offer an accoustically transparent variant. Plain and simple. End of story.
mhafner is offline
post #22 of 68 Old 07-03-2017, 02:27 AM
donaldk's Avatar
Quoted: 499 Post(s)
Liked: 122
Guess who is the first to market LGD's transducer audio OLED...
donaldk is offline
post #23 of 68 Old 07-04-2017, 08:09 PM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
Cool
yup.
My Fourth of July foray in CLEDIS Grid analysis.
72" by 128" is not a bad size to aim for. But technically you can start with 2 panels and controller.
The practical minimum that would still look great is 2 x 4 panels is 74" diagonal, just increase your lego count a few blocks at a time.
Name:	CLEDIS TILE SIZE CALCULATION.jpg
post #24 of 68 Old 07-04-2017, 08:34 PM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
Cool
Originally Posted by mhafner View Post
Cledis type tiles need to offer an acoustically transparent variant. Plain and simple. End of story.
Sure thing, IF YOU CLONE YOURSELF and CRYO for 50 years.
You are making a big to do about nothing. Think remodelling your bat cave, knock a big window on the side. Rip out so much unneeded absorption, think rt300/400. Change your speakers to dynaudio.
Use this center channel below screen. Or three if you have lc rc as well. Ncore amps and Call it a day.
While the cabinet base features a mechanism that allows the angle of dispersion to be focused upwards or downwards to optimize such with regards to positioning the speaker below or above the video screen. The acoustic phase is further adjusted by a toggle switch to optimize the height of the soundstage in these same positioning scenarios.
post #25 of 68 Old 07-04-2017, 09:11 PM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
Personally now that we have atmos, I prefer the speakers to image at chin level instead of ear level or up to 30 cm above. One row of 3 or 4 dont worry about the rest. SELFISHNESS gets you MORE IMMERSION. without any doubt.
If You are real selfish and only have one seat you don't need a center.
Speaking of awesome chin level imaging speakers i would not mind being surrounded in 9.1.8 with arrayed sides so 10 of these for a single seat selfish SONY DYNAUDIO STRATO system, with 4 playstation 4's in quad as well...
post #26 of 68 Old 07-05-2017, 01:13 AM
mhafner's Avatar
Quoted: 190 Post(s)
Liked: 71
I don't see why. What is the big technological challenge here? The Sony tiles look like computers of the 50s. It won't take 50 years to get the laptop versions of today that perform far better for far less money.
mhafner is offline
post #27 of 68 Old 07-05-2017, 04:02 PM
appelz's Avatar
Quoted: 285 Post(s)
Liked: 266
I haven't seen any acoustically transparent laptops yet either!
Art Sonneborn likes this.
Adam Pelz ,Acoustic Mafia - Hear No Evil
Master ARCOS Calibrator, Cedia Designer, HAA Instructor LIII, THX HT1+ HT2+ Video
appelz is offline
post #28 of 68 Old 07-05-2017, 04:50 PM
Quoted: 397 Post(s)
Liked: 511
Art
post #29 of 68 Old 07-05-2017, 04:55 PM
donaldk's Avatar
Quoted: 499 Post(s)
Liked: 122
So why Dynaudio, and not Quested or Alcons?
donaldk is offline
post #30 of 68 Old 07-05-2017, 06:32 PM - Thread Starter
CINERAMAX's Avatar
Liked: 1296
Penthouse open spaces require a loudspeaker designed to sound excellent in those tough environments with minimal room tretment. They are very well integrated top to bottom, without any dsp,. So simplicity in achieving a good result. I also have found out that when you have 10 of these columns sharing the load specially with mild atmos or dts-x compression that it is extremely enveloping and natural. 7.1 former systems specially in treated room did stress out a bit, not now with a bed of 8 the lr load gets shared with the width and the surrounds don't pop as they did before. But the system maxes out at 105 db, a very neighborly thing in buildings like this ( ashoe in for my latest concept or what?")).
So Par for the course.
Cinemas I still use the q and a, but i think i always liked the idea of cinema with a view. And with this dynaudio system here, and a couple of tiles and a 77 oled. I'm ready.
