Runco projector help - AVS Forum
post #1 of 41 Old 01-03-2007, 04:01 PM - Thread Starter
Waterbeast's Avatar
I am new to the forums and have not been able to find much on Runco products. So I would like to ask a few questions.
I am looking at upgrading my current runco system and have pretty much limited my search back to runco as I do think they have a great product. There are three projectors that I have been looking at: RS-1100 Ultra,VX-2000d, VX-22d. All three with the CineWide to give the 2.35:1 but not the AutoScope because it will be projecting onto a dedicated 2.35 screen.
I have a dedicated room that is 17.5'x27' in size and going to use a screen that is 183" wide giving a diagonal of roughly 199" that is perforated. I am not sure if the single chip dlps can produce an excellent picture at that size as I think the 3 chip dlp could. There is a huge difference in price and want to know if it would be worth it to spend the extra bucks and get the 3 chip or would the single chip be able to supply a good picture to that size of screen. It will mainly be running blu ray/HD programing/480p DVDs.
I am looking to put it on a Stewart screen. Someone told me to use a GrayHawk LS withe cinema perforated and was wondering if anyone had any input if that would be the best material for gain and what not for my setup. Still looking at the curved screen as well.
Any information would be great. Thanks in advance.
Beast
Waterbeast is offline
post #2 of 41 Old 01-03-2007, 09:55 PM
jamin's Avatar
FWIW - I don't think there is any way that a single chip DLP will have the lumen output for a near 100 sq ft of screen. Single chippers have in the range of 400-600 Lumens after calibration from what I have seen and would in this case afford you only around 4-6 ft lamberts after cal on a new lamp. OUCH
Yes, screen gain would bump that up - but not much with the screen you are looking at.
You may want around 1600 lumens post cal and new lamp. Three chip is the only way you are going to get there. The 22D MAY get you there and almost certainly the 44d will. The lumen specs don't seem to be listed on the RUNCO site yet. I'm sure your dealer can get them though.
plug in to play
Acoustic Mafia - Hear No Evil
jamin is online now
post #3 of 41 Old 01-03-2007, 11:37 PM - Thread Starter
Waterbeast's Avatar
Jamin thank you for the reply.
The 44d is a little more than I wanted to spend. After adding on the anamorphic lens it really jumps up there in price. Is there any other options for projectors that would produce a great picture on that size of screen for around 50k including the anamorphic lens as they alone can go for 10-15k more?
Also, now I am being told that a FireHawk G3 would be the best screen for this application. Does that sound right?
Anyone know if Runco or other manufacturers of suitable projectors would allow me to demo the unit to see if I am happy with it before I make the purchase?
post #4 of 41 Old 01-04-2007, 05:34 AM
Curt Palme's Avatar
AS much as I don't subscribe to the hype that Runco uses to market their products, if you're sold on Runco and only Runco, then why not ask a Runco dealer? After all, they know their products the best and have been trained by what Runco feels to be the best. Asking a bunch of non Runco owners will probably give you answers that you don't want to hear as in suggesting other products.
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
post #5 of 41 Old 01-04-2007, 05:59 AM
AVS Club Gold
Dennis Erskine's Avatar
Liked: 43
Waterbeast...
You're not going to find a dealer that will give you a projector to evaluate in your home. We have a 22D here and are installing a 44D against a 14' wide screen. If you'd like to contact me, I can discuss your questions and issues...as well correct a potential misunderstanding you have with AutoScope and 2.35:1 screens (I'm not suggesting you must have AutoScope...it just appears you have a misconception there).
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Board of Directors
www.erskine-group.com
www.CinemaForte.net
Dennis Erskine is offline
post #6 of 41 Old 01-04-2007, 06:18 AM
mburnstein's Avatar
Dennis, how much does the 22D weigh? Will a hush box be required, or is it quiet?
mark
Top Home Theater's I hope to see: The Bland's
Art's and my buddy Steve Bruzonsky! And Oneobgyn if I ever make it to NorCal!
mburnstein is offline
post #7 of 41 Old 01-04-2007, 07:19 AM - Thread Starter
Waterbeast's Avatar
"Am I stuck to Runco?" No, after doing a little trolling it looks like there could be other options. Digital Projection's single-lamp TITAN 1080p-250 looks like it might be able to do the trick as well but not sure if it will stay under the 50k price range with the lens to make the 2.35 picture without black bars on it.
I did contact a Runco dealer and they had to call Runco to be sure on the specs or something since those are new. Then came back that"Runco says that I need to go with a VX55d or go with a smaller screen." A 100k+ PJ is out of the question as the wife would kill me. I am not a hardcore videophile or anything, I just like watching movies and want it to look very nice, not necessarily perfect.
I currently have a Runco DLC2000HD LCD PJ on a GrayHawk 120" wide (~137diag) Microperf screen in a 100% light controlled room and it looks good with 480p or better content. The 480i, well just plain sucks, and the CR is horrid but what do you expect out of a 5+ yr old projector I guess. What I am getting at is that back in the day they said that I should go no larger than a screen 96" wide. I did go against their suggestion and am happy with it, but I don't want to drop 50k+ and find out that I didn't get so lucky the second time around and that the VX 22d PJ is not going to give me a good picture I can live with.
Maybe I should just stay with what I have till the next round of PJ's come out.
post #8 of 41 Old 01-04-2007, 07:29 AM
Curt Palme's Avatar
For overall best PQ, consider a pair of Tim's blended 9" CRTs.
post #9 of 41 Old 01-04-2007, 07:35 AM
AVS Club Gold
Art Sonneborn's Avatar
Liked: 44
I think that SIM HT 5000 will also fill the bill for you but the Titan is at or near the limit with that 15' wide screen and in fact probably the SIM is also. With that size screen you are rather limited since only the light cannon three chip DLPs have the horsepower.This then means very large dollars.
Talk to Dennis he will give you good advice regarding Runco products.
Art
My HT
iRule rules my theater
"If she's amazing she won't be easy,if she's easy she won't be amazing"
Bob Marley
Art Sonneborn is offline
post #10 of 41 Old 01-04-2007, 09:18 AM
AVS Club Gold
Liked: 44
Perhaps true Curt but not on a 15' 6" wide screen.
Art
My HT
Bob Marley
post #11 of 41 Old 01-04-2007, 09:21 AM
AVS Club Gold
Liked: 43
....on the other hand, 183" screen is too much for a 27' room if you're going to have two rows of seats and good sound.
The VX22 shipping weight is the same as the VX2. It is quiet in the overall scheme of things but in a room with that kind of money invested in a projector, I'd never put the projector into the room naked.
www.CinemaForte.net
post #12 of 41 Old 01-04-2007, 09:27 AM
mburnstein's Avatar
So I see that is around 83Lbs without lens. Do they make hushboxes specifically for that projector? Would that hush box require its own ventillation system?
mark
post #13 of 41 Old 01-04-2007, 02:08 PM
CINERAMAX's Avatar
Quoted: 57 Post(s)
Liked: 39
Waterbeast...
KEEP YOUR EYE OUT FOR A FLICKER ISSUE ON THE 44d, BUMP IT UP TO THE 55D IF YOU CAN. THE 1K WATT CERMAX HAS A FLICKER ISSUE AT 1K HOURS.
CINERAMAX is offline
post #14 of 41 Old 01-04-2007, 02:10 PM
AVS Club Gold
Liked: 43
We build the hush boxes to fit the situation with Active Thermal Management exhaust systems.
www.CinemaForte.net
post #15 of 41 Old 01-04-2007, 02:50 PM
taker's Avatar
Dennis can you tell us how wide can you go with a Runco VX22D hopefully 168" 2:35 is not to wide
taker is offline
post #16 of 41 Old 01-04-2007, 03:20 PM
CINERAMAX's Avatar
Quoted: 57 Post(s)
Liked: 39
Taker:
I can tell you that that projector should clock 2200 ansi lumens calibrated. Definetely not powerful enough for a 168" single curve screen, affectionately called inside one of the largest screen manufactureres the "Belly Screen". As it has a protruding belly in the center.
Him and others recommending this screen ignore that eyesore and the fact that the image is half as bright on the top and bottom of the screen as it is in a horizontal center line.
Now if you want a great 168" 2.35 image with the vx-22 or better yet, if you are not going to be sliding in and out the anamorphic lens, the the DPI Titan is 15% better, simply becuase it's primaries are filtered to achieve near xenon response.
The Titan an isco3 or schneider fixed lens and the Torus Screen from Stewart available under certain conditions. That should be the ultimate screen pj combo.
With the custom ray traced Torus you can go as high as 2.8 gain and still preserve pristine colorimetry.
post #17 of 41 Old 01-04-2007, 04:04 PM
Jeffmac's Avatar
I'm off to CES next week to check out the Runco vx22, the DPI Titan and the Sim2 HT5000. I'm looking at a 133" wide 2.35 curved screen. Is there anything else I should be looking for?
Jeffmac is offline
post #18 of 41 Old 01-04-2007, 04:24 PM
TSHA222's Avatar
Liked: 54
I have a 16 foot wide 2.35 screen and my room is between 35 and 40 foot from screen to port hole. The screen is a Harkness Hall mini-perf 1.5 gain. I use a 3 chip DPI Highlite Gold and I have had a few single chippers in there just for giggles. Even with controlled light, you want as much brightness as you can get. Speaking of the DPI Titan 1080p, it looks like a great product. I saw it at Cedia, I believe it was in their booth. I think you could swing it with that one. Don't know about price with their Cinemawide system, though.
TSHA222 is offline
post #19 of 41 Old 01-04-2007, 04:30 PM
CINERAMAX's Avatar
Quoted: 57 Post(s)
Liked: 39
The Titan may not be there. But I can most definetely asure you that is the bes in class because of the filtering of excessive freen/blue spectra. I am a big fan of the Runco Vx-55 with the motrised lens rig.
post #20 of 41 Old 01-04-2007, 04:36 PM
CINERAMAX's Avatar
Quoted: 57 Post(s)
Liked: 39
Avoid the belly.
I can assure you that the biggest buzz word this year from Stewart in the Area of 2.35 will be the TORUS. They are even designing a masking system for it.
What the heck here is a promotional material I put together for the local market, if you can ignore/endure the self promotion part, everything else is 100% the truth.
I have meetings every day at ces with Stewart as we get the program off to an auspicious start.
post #21 of 41 Old 01-04-2007, 04:57 PM
jamin's Avatar
Taker --
2200 lumens on a 168" 2:35 screen would yield a shade over 26 Ft. Lamberts on a untiy gain screen. Many here would suggest that was more than plenty. On the other hand, not having measured the beast or seen the Runco spec, I would not speculate on the calibrated numbers being at that level.
plug in to play
jamin is online now
post #22 of 41 Old 01-04-2007, 05:12 PM - Thread Starter
Waterbeast's Avatar
I would like to thank everyone for the advise. I think I am going to go with the vx-22d. The viewing width of my screen is going to be 175.75" after taking the frame in to account. I found on Runco's site that they have recommended picture size widths of 80"-180" on a 16:9 screen and a Max width of 300" for the VX-22d. I am at the top end of what they recommend but with the 2.35 screen I should have less over all screen area than a 16:9 screen of the same width and should help me even more.
I'll get everything in and see how it looks. If its two dark on the edges or doesn't give the picture I am after I will just send the screen back and have it cut down to a smaller size that will look better.
I don't know how true it is but was told that the VX 1080p PJ's have not shipped yet and all the stats are still being tested (the reason they have not been posted yet) and should start shipping in a week or so. The VX-22d is 500 ANSI lumans more than the TITAN 1080p-250. They didn't have a CR or calibrated ansi lumens numbers. Hmm.... Guess their waiting for the show.
So anyone have any suggestions on the screen material to match up with the size and PJ being used? Still looking at the FireHawk G3 Microperf that has a 1.25gain or would it be better to go with a Ultramatte 150/200 giving a 1.5/2.0 gain white screen?
post #23 of 41 Old 01-04-2007, 06:46 PM
mburnstein's Avatar
Peter, can this this stewart torus screen be made acoutically transparent?
Originally Posted by CINERAMAX View Post
Taker:
mark
post #24 of 41 Old 01-04-2007, 08:02 PM
Jeffmac's Avatar
Thanks Peter.
The Torus screen makes sense to me but is Stewart even building them yet?
What's up with DPI not being at CES? That's one of the main reasons I was going.
Jeffmac is offline
post #25 of 41 Old 01-05-2007, 01:29 AM
MeridianMan's Avatar
One thing to note on light output and recommended screen sizes. Check with Runco if that is with the cinewide lens in place or not. The reason is each lens will reduce light output. The best lenses should do this with minimal light loss, but it is still a factor, especially if you are playing near the edges of their recommendations. Just something to be aware of.
best regards,
Jerry
MeridianMan is offline
post #26 of 41 Old 01-05-2007, 05:02 AM
AVS Club Gold
Liked: 43
...but, then again, Jamin will be playing with the first two VX22d's to be installed.
www.CinemaForte.net
post #27 of 41 Old 01-05-2007, 05:04 AM
AVS Club Gold
Liked: 43
Neither DPI nor Runco will be at CES.
Stewart has built Torus screens. Torus screens are not acoustically transparent...they could be made that way; but, you'd be replacing the fabric once a week.
www.CinemaForte.net
post #28 of 41 Old 01-05-2007, 12:32 PM
LJG
LJG's Avatar
What is a guess on the lumens from the VX22?
LJG is offline
post #29 of 41 Old 01-05-2007, 01:25 PM
AVS Club Gold
Liked: 43
Equal to or slightly better than the vx2
www.CinemaForte.net
post #30 of 41 Old 01-05-2007, 01:49 PM
LJG
LJG's Avatar
Thanks Dennis:
2500 Ansi before calibration, 1227 after
LJG is offline
User Tag List
