How high is the jitter level on HDMI vs S/PDIF on a High-End Processor? - Page 6 - AVS Forum | Home Theater Discussions And Reviews
Old 03-19-2010, 02:58 PM
krabapple's Avatar
Quoted: 385 Post(s)
Liked: 373
Originally Posted by DonH50 View Post
Nick,
Good point about the PC noise (and the rest, natch). When the paper said the listeners used their own DACs, I took my experience out of context and assumed they'd provide a clean clock and data path (e.g. double-buffering the data, or loading the samples and then executing from a clean copy independent of the PC). Re-reading, if anything the opposite appears true. To my mind that almost completely invalidates the test, as such a high noise floor would likely mask any of the things they were trying to hear.
Cheers - Don
Why do you assume the noise of the PC -- noise in the soundcard output, really -- was high enough to be a problem?
krabapple is offline
Old 03-19-2010, 02:59 PM
amirm's Avatar
Quoted: 1334 Post(s)
Liked: 739
Originally Posted by krabapple View Post
I see your amirm and raise you a James Johnston.
Since JJ used to work in my group, not sure where that leaves you .
amirm is offline
Old 03-19-2010, 03:07 PM
krabapple's Avatar
Quoted: 385 Post(s)
Liked: 373
Originally Posted by dknightd View Post
Sorry in advance for taking this off topic (but related to this post)
I've tried this test - well not quite, but a related one. Years ago when I was deciding how to put music on my computer I compared mp3 at various bitrates to lossless.
I picked 10 songs more or less at random, but ones I thought would be a good test, and that I could stand listening to over and over.
128 vs lossless was easy - I stopped after "passing" on the first three songs.
All mp3 codecs are not created equal -- nor are codecs from years ago necessarily comparable to ones available today. Even 128kbps vs lossless stopped being easy some time ago, if you use the best codecs.
Occasionally I think I can hear problems at 320, so I rerip lossless and compare again. So far I have not been able to pass an abx at 95% confidence. Maybe that is because I subconsciously do not want to hear a difference - it would mean lots of work reripping. Maybe it is because I don't know what to listen for, or maybe I'm using the wrong tools.
Or maybe you're normal -- it's not typical to 'pass' an ABX of 320kbs vs lossless. MP3 codecs are really quite good.
Old 03-19-2010, 03:08 PM
krabapple's Avatar
Quoted: 385 Post(s)
Liked: 373
I know he did, amirm. It would be most interesting to get him here to talk about the audibility of jitter, and how one would verify it, as well as the audibility of high-bitrate lossy. He does post to AVSforum.
I'd also be interested to know about the selections you used in your high-bitrate AAC listening tests, what version of the codec you used, and how the ABX tests were performed and the statistics used.
Old 03-19-2010, 03:38 PM
amirm's Avatar
Liked: 739
All of which seems irrelevant to this thread, really. How would I go about doing an ABX to test my sensitivity to correlated jitter, amirm?
"Small moves Elli... Small moves!" So says the (alien) father to Jodi Foster's character in the movie Contact which she tries to get the answer to everything in the universe .
I will say more when I have time....
amirm is offline
Old 03-19-2010, 03:41 PM
krabapple's Avatar
Quoted: 385 Post(s)
Liked: 373
I think my request was rather smaller-scale than that.
Looking forward to it.
Old 03-19-2010, 05:12 PM
DonH50's Avatar
Quoted: 1797 Post(s)
Liked: 1331
Actually, the PC's sound card was not used. The testers provided their own DACs, amp, and speaker or headphones. The authors provided a PC and interface to the DAC using whatever output the DAC box required. I have measured jitter from PC busses to range from perhaps 100's of ps to well into the ns region, but have not measured them recently (might be an interesting thing to try in the lab). I do not know the specs of the interfaces they used between PC and DAC, nor the PC they used (the names etc. not stated in the paper). So, properly speaking, I assumed there was insufficient information in the paper to properly validate the tests. Nor do I know that they are invalid (throwing out the baby with the bath water), but in any event they do not address the original question I had about correlated vs. coherent/deterministic jitter levels, either present at the DAC's clock input or their threshold of audibility. In another thread the point was made that, for such low levels of jitter (few ns), it is unlikely that anyone could hear it if it were correlated or not, a valid point.
Honestly, for me this falls deep into the "sorry I asked" category. I was curious and hoped to get an answer, not start (continue) a huge squabble or get embroiled in semantics. There are obviously people with ears far more golden than mine, and credentials far greater than I'll ever have in this area, on both sides of the fence. I plan to sit on the sidelines (obviously not my strong suit) and continue to follow up the reading material various folk have provided before I get thrown off this board. Or perhaps that would be best...
I am tempted to sign off with a tag a friend uses" "Have a nice day, unless you've made other plans". It's clearly time for me to bow out.
Besides, I've got a foot of snow to shovel so my wife can get back in the garage when she gets home from work (spring in the Rockies).
G'day - Don
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
Old 03-20-2010, 12:36 AM
amirm's Avatar
Liked: 739
Well, I have learned that nothing about jitter is "small scale" as evidenced by your post claiming that what I said had nothing to do with the topic. Everything turns into a cat fight sooner or or later, sad to say. But I will go ahead and provide an answer, hoping you are true to your word that a simple response is all that was required.
I think we can all agree that jitter distortion is small and most people can't hear it. I hope we can also agree that one can arbitrary increase jitter until it becomes audible to everyone. In that sense, it completely mirrors compression artifacts. Everyone can hear compression artifacts at 64 kbps, but scant few can do so at much higher data rates such as 384kbps.
It also then follows that if you are not able to hear small compression artifacts which expert listeners can detect (i.e. proving that artifacts do exist), then you are not going to hear jitter either at similar levels that others could. In that sense, the opinion expressed that jitter must be inaudible because that person can't hear it, can be tested with something much easier, namely compression artifacts.
Second point was that hearing digital artifacts requires learning for many people. People don't know what small artifacts sound like and hence, are shooting in the dark as they go about testing themselves to hear it. By training yourself on compression artifacts, you learn to use your ear as an instrument rather than something that provides listening pleasure. Once there, I assure you that you can hear other small impairments such as jitter.
As I implied with my quote, think of my suggest as a "small move" toward becoming an expert listener. Keep working at it and I assure you that soon, you will have hearing acuity well above where you started and better than 99.9% of the general public.
amirm is offline
Old 03-20-2010, 01:12 AM
krabapple's Avatar
Quoted: 385 Post(s)
Liked: 373
That doesn't follow. Just because two different kinds of subtle artifacts become readily audible when you increase their level, doesn't mean they become audible at the same level. That someone is sensitive to compression artifacts doesn't determine they will be equally sensitive to jitter.
Again, small impairments are not necessarily alike in either magnitude or audibility by virtue of being 'small'.
Old 03-20-2010, 10:04 AM
amirm's Avatar
Liked: 739
Who said they became audible at the same level? That has nothing to do with the points I made. Are you able to answer the question put earlier on how one becomes a trained listener to hear compression artifacts better?
But the fact that you learn the skills necessary and scientific approach used to get there certainly does. To wit, when we test new methods in audio compression, expert listeners always rate much higher than general population in detecting its artifacts. By your logic, since the artifacts are different in new methods, they should not be able to detect any better than general public yet they clearly show better ability to detect them.
The commonality is not the distortion itself but your ears being able to tune to digital artifacts in general. That starts by knowing what artifact can be there, what selection of content reveals it, and then learning to search for it.
amirm is offline
Old 03-20-2010, 10:12 AM
amirm's Avatar
Liked: 739
I would LOVE to be able to abx 320mp3 from lossless. It really bugs me that I can throw away that much signal and NOT be able to tell. Maybe I'm using the wrong source material - maybe I should try doing it on speakers instead of headphones - maybe I just have not learned how to tell the difference.
Just wanted to let you know that I have not forgotten about your question . I will address it later. For now, you are absolutely doing the right thing by using headphones. It makes the testing simpler.
Second point, MP3 at 128kbps rolls off the high frequencies (at least most encoders do). That makes it easy to tell the difference from the original that way, meaning that you may not be looking for the right thing as at higher data rates, the roll off is not there.
Do you have any tips on how I might be able to reliably tell a 320 mp3 from a lossless file? Can you actually do this?
Yes, but the logic is rather inverted . I will explain later.
amirm is offline
Old 03-22-2010, 11:01 AM
jj_0001's Avatar
Quoted: 151 Post(s)
Liked: 66
Ok, I just came into this at the very end. I have no idea what the argument is about, but the first thing one must consider is the frequency spectrum of the jitter.
After all, sinusoidal jitter at .5555...Hz is called "decentered LP". Sinusoidal jitter at a high frequency will alias all sorts of things into your face.
Content with mostly high frequency content will be much more sensitive to jitter in general than low-passy signals. The mathematics is quite simple, error goes as the square of slew rate of the desired signal.
But I have no idea what you guys are arguing about.
James D. (jj) Johnston
jj_0001 is offline
Old 03-22-2010, 01:59 PM
AndreYew's Avatar
It is said that one needs to repeat something 6 times before people remember. Consider the importance of the jitter spectrum repeated twice now:
http://www.avsforum.com/avs-vb/showt...2#post11641082
I think it's like professional wrestling. The conflict is the draw, not the resolution or closure.
--Andre
AndreYew is offline
Old 03-22-2010, 02:43 PM
jj_0001's Avatar
Quoted: 151 Post(s)
Liked: 66
Has anyone noticed yet?
--Andre
"Soon the Gypsy Queen
In a blaze of vasiline
Will perform Guillotine
What a Scene
What a Scene"
I think that about says it.
jj_0001 is offline
