Long SPDIF cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 10-29-2007, 11:10 AM - Thread Starter
shaun5's Avatar
I'm moving my source equipment to a central equipment closet for the whole house. For my main room, the video processor in the closet will take care of switching audio and video. I'll need to run a 75 foot HDMI cable (video only) and 100 foot SPDIF cable to the processor. What should I consider? Since everything is currently in the same room, now is the time for me to evaluate the long runs...
shaun5 is offline
post #2 of 19 Old 10-29-2007, 01:35 PM
ChrisWiggles's Avatar
Not sure why this is in this forum, that's a long HDMI run you may need to look into extenders for that, or a really good hdmi cable. For SPDIF at that distance, just a really good shielded 75ohm cable should be fine. Try the usualy suspects, bluejeans etc for pro-grade Canare/Belden stuff.
ChrisWiggles is offline
post #3 of 19 Old 10-29-2007, 01:43 PM
Morbius's Avatar
Originally Posted by shaun5 View Post
I'm moving my source equipment to a central equipment closet for the whole house. For my main room, the video processor in the closet will take care of switching audio and video. I'll need to run a 75 foot HDMI cable (video only) and 100 foot SPDIF cable to the processor. What should I consider? ..
shaun5,
A run of 75 ft of HDMI is beyond the specs for HDMI.
You need an extender that converts HDMi-->Cat5-->HDMI.
http://www.projectorreviews.com/gefe...nder/index.php
which is one of many - just "Google" - "HDMI Extender"
Dr. Gregory Greenman
Physicist
Morbius is offline
post #4 of 19 Old 10-29-2007, 02:12 PM - Thread Starter
shaun5's Avatar
Chris, I posted this here because I need cables to connect my Hi-End HT Gear.
I am very concerned about jitter and/or signal degredation over this length of SPDIF cable. What is the longest SPDIF connection someone has actually tried?
HDMI is a only a secondary concern because: 1)There are several cable manufacturers that claim their cable will work and 2)I know that an HDMI extender will work, if a cable doesn't.
shaun5 is offline
post #5 of 19 Old 10-29-2007, 02:30 PM
Dizzman's Avatar
a coax SPDIF i have used over 100 feet. i know of people who have done 100 metres.
just hanging out, rollin with the flow.
Dizzman is offline
post #6 of 19 Old 10-29-2007, 07:51 PM
Andy Lammer's Avatar
You can always use a cheap Monarchy DIP 24/94 to boost the signal and do jitter reduction.
The DIP 24/96 will pass SPDIF.
- Andy
Andy Lammer is offline
post #7 of 19 Old 10-30-2007, 11:29 AM
Glimmie's Avatar
Quoted: 760 Post(s)
Liked: 625
SPDIF is a 75ohm source terminated generator so use RG59 or RG6. CATV cable with F to RCA adaptors is fine for 100 feet. Copper coated steel is also fine too as there's no DC power being transported and the frequency bandpass is in the video frequency range.
Glimmie is offline
post #8 of 19 Old 10-30-2007, 11:47 AM
Michael Grant's Avatar
Liked: 24
On the HDMI side, a CAT5-based extender isn't your only option; you can also go with an optical extender.
Michael
Michael Grant is offline
post #9 of 19 Old 10-30-2007, 01:50 PM
Morbius's Avatar
Michael,
Yes - the optical extenders are more expensive though.
The Gefen HDMI-1000 HD is an optical extender that requires 1 run of optical and 1 run of
Cat5. and extends to 100 meters or 330 ft:
http://www.gefen.com/kvm/product.jsp?prod_id=2484
The Gefen HDMI Cat 5 MS requires 2 runs of Cat 5 and goes to >300 ft:
http://www.gefen.com/kvm/product.jsp?prod_id=4504
There's also the HDMI Cat 5 which requires 2 runs of Cat 5 and goes to 200 ft:
http://www.gefen.com/kvm/product.jsp?prod_id=3872
Do you think the optical connection is worth the extra expense?
Physicist
Morbius is offline
post #10 of 19 Old 10-30-2007, 02:02 PM - Thread Starter
shaun5's Avatar
I just noticed Gefen has a digital audio extender, so that would work (if needed) until I change to AES/EBU format.
I'm tempted to try a 75 foot bluejean HDMI cable and a 100 foot Apogee Wyde SPDIF cable, but holding off in hope of hearing how others are making the connection....
shaun5 is offline
post #11 of 19 Old 10-30-2007, 02:02 PM
Liked: 24
Ah, OK, I see. The Gefen optical solutions are more expensive than the all-in-one optical HDMI cables, but the Cat-5 solutions come in cheaper still. DigitalConnection sells a 25-meter fiber optic HDMI cable for $579.
Michael
post #12 of 19 Old 10-30-2007, 02:13 PM
Morbius's Avatar
Michael,
So what would you do for a 15 meter run? I'll be upgrading to HDMI; but my current
VGA runs are about 15 meters [ 50 ft ] long. Should I go for the 200 ft Cat 5 ?
Or is there really an advantage of going optical for another $100 or so?
Physicist
Morbius is offline
post #13 of 19 Old 10-30-2007, 02:37 PM
Glimmie's Avatar
Quoted: 760 Post(s)
Liked: 625
Again any 75ohm cable be it RG59, RG6, or RG11 (overkill) will work fine for SPDIF at 100 feet. You can buy ready made CATV cable assemblies and use F to RCA adaptors. Or you can buy a 100 foot RG59 video cable with RCA's on each end. No need for esoteric brands here.
Glimmie is offline
post #14 of 19 Old 10-30-2007, 03:59 PM
FYI:
The Monarchy DIP as Toslink & Coax cable inputs, and will output via Coax or AES/EBU.
So it can do format conversion.
I have also had no problem with cheap dollar-store 50' Cable-TV cable, and using F-RCA connectors at each end.
- Andy
post #15 of 19 Old 10-30-2007, 03:59 PM
Liked: 24
Morbius, I honestly think you should go with the cheapest solution that works. If that's Gefen's CAT5, go for it!
Michael
post #16 of 19 Old 10-30-2007, 04:08 PM
Professionals regularly use cable lengths at least this long. Just use a good cable (belden etc as mentioned) and you should be just fine. It's a digital signal, so it either works or it doesn't. I have no comment as to jitter concerns.
post #17 of 19 Old 10-30-2007, 04:16 PM
Manic1!'s Avatar
Quoted: 197 Post(s)
Liked: 90
The HT guys tested a 100 foot HDMI cable and I dont think they had any problem with it.
Manic1! is online now
post #18 of 19 Old 10-31-2007, 03:19 PM
jjwinterberg's Avatar
Quoted: 67 Post(s)
Liked: 39
Originally Posted by Morbius View Post
Michael,
I used the Gefen HDMI CAT-5 Extreme for my 15m. run but that was just because it was easier to run CAT-5 then a good HDMI.
You might want to check out the Az Cable Co. for excellent HDMI cables at a good price:
http://www.azhifi.org/pictures/AZCablesInfo.pdf or
http://www.arizonacables.com/ John
jjwinterberg is offline
post #19 of 19 Old 11-02-2007, 12:44 PM
Krobar's Avatar
I have a 50M run using Baluhns and Cat5E and it works fine. Do you have an option to use XLR digital out, I imagine this would be more stable.
Krobar is offline
