help with home theatre setup in 11X10 room with good audio potential - AVS Forum | Home Theater Discussions And Reviews
Old 02-28-2008, 07:55 AM - Thread Starter
getufit's Avatar
just picked up a samsung HLS5088W and a marantz 8001.. looking for a decent set of speakers that will work in a loft/condo room measuring approx 11X10...
home theatre is important and would like great audio potential as well...
anyone have suggestions? see that FS has a sale on polk HTIB (RM10) and loudspeakers (RTiA5)...either worth considering given my television/receiver? i'll also need to add a component for cd/dvd/bluray.
getufit is offline
Old 02-28-2008, 08:09 AM
biffva's Avatar
The Marantz 8001 has a good amount of power to drive speakers.
How much are you willing to spend on speakers?
Also, realize that the 8001 is mucho overkill for a set of HTIB speakers.
In a situation provided with maximum amplification, perform a disciplined action.
biffva is offline
Old 02-28-2008, 09:01 AM - Thread Starter
getufit's Avatar
looking for the best value/quality... likely under 1500 bucks for a 5.1 setup.
ideally, the speakers would be sleek to conserve floor space.
in about a year the space will be much bigger (about 25X26) but with a kitchen in the space as well (non-designated room).
since it'll be in a loft, i won't be able to blow the neighbours ears out...
getufit is offline
