Will playing 4ohm speakers be damaged by playing them on a 8 ohm receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 03-12-2008, 07:10 AM - Thread Starter
Hyper_Lite's Avatar
Specifically I'm talking about the Polk Audio LSi15's and Pioneer Elite VSX-92TXH.
On my Polk LSiC there is a single tweeter and two main mid drivers (5.25").
The driver on the left sounds great, but the driver on the right hardly has any sound coming out of it. Any idea's? Do I have a bad center?
Hyper_Lite is offline
post #2 of 26 Old 03-12-2008, 09:21 AM
MIkeDuke's Avatar
Quoted: 543 Post(s)
Liked: 216
Your receiver might struggle with speakers that are 4ohms. As a rule, 4ohm speakers are somewhat hard to drive by a receiver unless it is very beefy. It could be that the specific driver is blown out. What happens with this kind of issue is that you are probably overdriving the receiver and it is causing the amp to clip which is bad for your speaker. The damage comes from overdriving the speaker in trying to get to listening levels that you like. This may have damaged the speaker.
It ain't easy being green.
My System
MIkeDuke is offline
post #3 of 26 Old 03-12-2008, 10:04 AM
oztech's Avatar
Liked: 101
Swap the speaker leads with unit off and then turn unit back on keeping the levels normal and see if the problem is the speaker or the pio
as MikeDuke pointed out louds levels at 4ohms without an amp or rec that can handle 4ohm=damage.
oztech is offline
post #4 of 26 Old 03-12-2008, 10:35 AM
Paul Scarpelli's Avatar
Liked: 56
There's no such thing as a 4 ohm speaker, or an 8 ohm receiver, or a 3/4-ton pickup truck. The terms are nebulous, and they omit many other variables.
A speaker rated at 4 ohms may have resistance at various frequencies varying from 4 ohms to 20 ohms, or higher. Some 4 ohm speakers don't dip below 5 ohms at any frequency, but others dip to 3.2 ohms or lower, and they can cause amplifier problems and current limiting. Then there's the question of where the low resistance occurs. If it's for an LCR switched to "small" and the impedance is 3 ohms at 30 Hz, no big deal. Also, what is the speaker's sensitivity? If it's high, the receiver may not be pushed hard enough to draw enough current through the outputs to shut it down.
You can generally drive a 4 ohm speaker with a receiver not rated to drive below an 8 ohm load (I hate those, BTW), as long as you don't turn the volume up too toasty, and as long as you add NO treble or bass boost. It's living on the edge, though.
Paul Scarpelli
aka TRIAD DUDE
I can tell people who are judgmental just by looking at them...
Paul Scarpelli is offline
post #5 of 26 Old 03-12-2008, 10:44 AM
tvtommy's Avatar
I'm sure it's not an issue of the receiver being able to drive the load. That Pio should have generous amounts of power and the capability to drive 4 ohms. I'm guessing you have a bad driver, but I doubt it was the receiver, unless you are playing it unusually loud. you are more apt to wreck a speaker by underpowering it than overpowering it.
Gently push on the funky driver if it feels scratchy at all then you have a damaged driver. Are the speakers new? If it's always been that way then check the warranty, they are usually covered for a longer time than electronics are.
"What is truth?" - Pontius Pilate
"I am the way and the truth and the light" - Jesus Christ
tvtommy is offline
post #6 of 26 Old 03-12-2008, 10:55 AM
jjdche's Avatar
1.) Paul is quite correct. Some 4 ohm speakers will be relatively easy for a typical receiver to drive, some won't. You would need an impedance curve to truly answer the question.
2.) tvtommy is also correct, it doesn't sound like your problem has anything to do with the speaker impedance. It could be as simple as just having a bad connection on one woofer.
jjdche is offline
post #7 of 26 Old 03-12-2008, 11:36 AM
Sirquack's Avatar
ditto what Paul said. Generally, HK and Denons have been pretty compatible with most 4 ohm rated speakers.
___________
"Don't worry about the future, it is already tomorrow in Australia..."
My Website
Sirquack is offline
post #8 of 26 Old 03-12-2008, 02:06 PM
vinipux77's Avatar
Check your main speakers, they too, should be working a similar way. The two drivers are crossed over at different frequencies, and if center is set to small the mid-bass unit only goes from about 200Hz to the crossover frequency, which is usually 1 to 1 1/2 octaves only.
vinipux77 is offline
post #9 of 26 Old 03-12-2008, 02:32 PM
biffva's Avatar
Sounds like you permanently damaged both the Polks & the Pioneer while voiding both warranties in the process.
In a situation provided with maximum amplification, perform a disciplined action.
biffva is offline
post #10 of 26 Old 03-12-2008, 02:48 PM
lwien's Avatar
Uh..........doesn't sound like that to me.
Just an fyi......... most receivers and amps will shut down before any damage is done if they are driven to a load that they can't handle.
lwien is offline
post #11 of 26 Old 03-12-2008, 03:21 PM
Liked: 56
That's not correct, actually. The receiver will shut down if it overheats, too much current is being drawn through the output stage, or if the impedance is too low, but it has no idea how badly it's trashing the speakers.
Paul Scarpelli
aka TRIAD DUDE
post #12 of 26 Old 03-12-2008, 03:28 PM
lwien's Avatar
Question. Will a receiver that is trying to drive a 4 ohm load that is very sensitive to being driven to 4 ohm loads (ie, a receiver that is only designed to drive 8 ohm loads), will it overheat, will too much current be driven through the output stages, and by definition of the above scenario, the impedance is too low.........will that receiver shut down? It has only been my experience, Paul, that when the above happens, typically, a receiver or amp will shut down before any speaker damage is done.
lwien is offline
post #13 of 26 Old 03-12-2008, 03:59 PM
biffva's Avatar
lwien,
If you go back through the OP's previous posts, you'll find that he's trying to fill a large room while armed with little knowledge and no auditions. It's quite possible he wanted to try out his new gear and "cranked it"! Not sure about your experience but I've seen my share of blown drivers.
biffva is offline
post #14 of 26 Old 03-12-2008, 04:17 PM
lwien's Avatar
Yeah, I've seen quite a few blown drivers also from amps being driven to clipping, but most, if not all times, every time I've seen an amp trying to drive a 4 ohm load that is basically designed not to do that, the amp has shut down before any speaker damage occured. And even when an amp is being overdriven and clips, the audible distortion is usually enough to give the user enough time to run over and shut down the volume before any damage is done.
But you said he damaged not only his speakers but his receiver as well. I don't understand why you think that to be true. His speakers, maybe, but his receiver?-
lwien is offline
post #15 of 26 Old 03-12-2008, 04:25 PM
biffva's Avatar
Perhaps he didn't damage the receiver. (Though I think there's a solid possibility that he blew a driver.) But if he took the receiver somewhere to be benched, then he might--notice I said might--receive some face-to-face advice that would move him further along. Posting polls here while not performing any auditions isn't the best way to buy equipment.
biffva is offline
post #16 of 26 Old 03-12-2008, 04:34 PM
sourbeef's Avatar
Liked: 25
Alright then, on my Onkyo 705 receiver, there is a menu setting for speaker type... choose either 4ohm or >6ohm. So based on the limited info. in my manual, it seemed appropriate for me to choose >6ohm for my Polks. Besides, I kinda had the idea that most speakers were rated 8ohm type speakers.......So, just for chits and giggles, if I were to change it to the 4ohm setting, would my speakers play OK? Would I do damage to either the speakers or receiver by doing this?
TV - Panasonic 58PZ700U plasma
L/R - Ascend Sierra Towers with RAAL Tweets in piano black
C - Ascend Sierra Horizon with RAAL Tweet in piano black
Surr - Polk Fxi-A6
Sub - SVS PC-13 Ultra
AVR - Denon 4520-CI
Blu-ray - OPPO 103
Comcast Set Top Box
sourbeef is offline
post #17 of 26 Old 03-12-2008, 04:38 PM
lwien's Avatar
"Posting polls here while not performing any auditions isn't the best way to buy equipment."
----biffva
Best way to BUY equipment? Posting polls while not auditioning? Where did he say that he was in the market for new speakers?
lwien is offline
post #18 of 26 Old 03-12-2008, 04:40 PM
biffva's Avatar
----biffva
You familiar with the "Find More Posts by . . . " function?
biffva is offline
post #19 of 26 Old 03-12-2008, 04:42 PM
lwien's Avatar
Yeah, but I just take one thread at a time.
lwien is offline
post #20 of 26 Old 03-12-2008, 04:56 PM
biffva's Avatar
That explains quite a bit about you.
biffva is offline
post #21 of 26 Old 03-12-2008, 05:01 PM
Ron Temple's Avatar
Quoted: 163 Post(s)
Liked: 133
The LSiC has a cascade array crossover (I think that's what it's called), it's not unusal for one driver to be getting most of the work. It's the way it's designed.
I don't lurk as much as I used to and I NEVER listen. Comes from being old and cynical.
Ron Temple is offline
post #22 of 26 Old 03-12-2008, 05:02 PM
lilmike2069's Avatar
Driving a 4 Ohm speaker on a receiver that is designed for 8Ohm will put more stress on it. It more than likely will not cause damage unless you crank up the volume past half way
lilmike2069 is offline
post #23 of 26 Old 03-12-2008, 05:27 PM
mlankton's Avatar
Quoted: 14 Post(s)
Like Paul alluded to, there really isn't any way to determine how tough a load a loudspeaker presents an amplifier without seeing the impedance curve. Some 4 ohm rated loudspeakers may work just fine, others will trigger the amplifier's protection circuitry quite quickly.
AV receivers offer a lot for relatively little. The trade off is that they generally have feeble amplifier sections and are going to limit your loudspeaker choices somewhat.
I know that someone with a brand X flagship avr is going to chime in with how wrong I am about avr power sections. My reply to you: for what you paid for that thing you could have gotten some good used separates on audiogon.
mlankton is offline
post #24 of 26 Old 03-12-2008, 05:48 PM
lwien's Avatar
Uh..........okay..........
lwien is offline
post #25 of 26 Old 03-13-2008, 09:19 AM - Thread Starter
Hyper_Lite's Avatar
Any reason they do this?
post #26 of 26 Old 03-13-2008, 09:30 AM
vinipux77's Avatar
See my earlier comment.
Each driver in the array has a narrower frequency band, so the midrange doesn't also have to play the mid-bass. Also interference between the two identical drivers is reduced. Your end result is better imaging and clarity at a cost of pure BANG... but some people don't really appreciate that... Very sad.
- Val
Reply Speakers
