3801 won't accept codes - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-14-2001, 09:16 PM - Thread Starter
DMGBob's Avatar
The remote for my 3801 won't accept codes for other AV components. After keying in the 4 digit code, the display on the remote reads "not valid". I'm getting the codes from the pamphlet that came with the receiver. Is my remote bad or am I doing something wrong?
DMGBob is offline
post #2 of 3 Old 05-15-2001, 06:40 AM
dmbatch's Avatar
I was able to program my remote for any device listed in the manual. The only time I saw the error you mention is when I was trying to enter a code for the wrong device, ie, I was programming a VCR but had put the code from a DSS box in. I was on the wrong chart.
Dave B.
ODAT
Dave B.
dmbatch is offline
post #3 of 3 Old 05-15-2001, 08:00 AM - Thread Starter
DMGBob's Avatar
I was careful to select the correct code. I tried several codes for dvd, tv, and cd. I guess my remote is bad. Thanks for the reply.
DMGBob is offline
Closed Thread Speakers
