Triads: One Platunum or Two Sliver Subs? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-16-2001, 09:42 AM - Thread Starter
joaquin's Avatar
Quoted: 39 Post(s)
Liked: 31
I'm in shop for subs. Previous owners, need advise. Thanks
joaquin is offline
post #2 of 7 Old 05-16-2001, 06:42 PM
JhnZ33's Avatar
Another overlooked advantage of using 2 subs, is that using 2, in the right locations can smooth out the overall response of the low frequencies.
"Nothing is impossible. You just need enough money."
JhnZ33 is offline
post #3 of 7 Old 05-16-2001, 10:33 PM
Mark Seaton's Avatar
Quoted: 512 Post(s)
Liked: 1328
How far are you sitting from the subs, and how large is your room. I haven't had a chance to look up the specs, but I believe the Platinum will get lower than the Silvers. Basically, I would say if you are worried about having enough output/volume, go for the pair of Silvers, if you aren't one to drive your system to it's limits very often, you will probably be happier with the Platinum.
I'm sure Paul can jump in with a reasonable comparison between the two options.
Mark Seaton
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is online now
post #4 of 7 Old 05-17-2001, 08:03 AM
Paul Scarpelli's Avatar
Liked: 54
Thanks for the two very astute responses, guys. Let me outline the strengths and differences between the Triad InRoom Platinum PowerSub and the InRoom Silver PowerSub...
The Platinum uses two of our amplifiers in bridged configuration, for an output of 500 watts into the 18" driver load. The Silver uses an unbridged variation for 250 watts into it's 12" driver. The amplifiers are expensive bipolar output Class AB with toroidal transformers...extremely rare in competitive subs that use cheaper Class D or other amps with poor damping factors. The cast-basket Eminence drivers used in both products have the same 3" edgewound voicecoil and enormous 120 ounce magnet assembly.
The Platinum, with it's huge driver, will typically do better at frequencies below 40-50 Hz, because of the control of the more powerful amp, less excursion for the same output, and more headroom. The lowpass on the Platinum is only 12 dB/octave, so I tend to set it at around 60 Hz with my Platinum LCRs. Although variable, the -3 dB points are almost the same; 18 Hz and 20 Hz.
The Silver PowerSub (also available in an InWall model) has a better motor/mass ratio, and is more articulate above 60 Hz. The articulation is perceptably better because of the dual 12 dB/octave lowpass controls, which allow tailoring of the lowpass, or tandem use of the controls for a steeper 24 dB/octave slope. This is a real fast audiophile sub, and two of them will provide a few dB more output than a Platinum over 50 Hz.
Both the Platinum and Silver have overbuilt enclosures. Anyone wanting to see the inside of the raw cabinet with it's extensive bracing, send me an e-mail and I'll send you some pics. No one uses bracing like this. You'll think we're nuts.
Another consideration is what front speakers are you using? The Platinum may work better with larger fronts that have decent LF response, while the Silver may mate better with smaller fronts.
I'll be out of town doing training after today, but feel free to e-mail with additional questions.
Paul Scarpelli, Director of Sales & Marketing, Triad Speakers, Inc.
Paul Scarpelli
Paul Scarpelli
aka TRIAD DUDE
I can tell people who are judgmental just by looking at them...
Paul Scarpelli is offline
post #5 of 7 Old 05-17-2001, 08:22 AM - Thread Starter
joaquin's Avatar
Quoted: 39 Post(s)
Liked: 31
I'm using InRoom Gold LCRs and InRoom Gold Center. Thanks
joaquin is offline
post #6 of 7 Old 05-17-2001, 12:33 PM
JhnZ33's Avatar
We have the In-wall Gold LCR's, 2 pair of In-wall Silver surrounds, and 2 In-wall Silver subs in one of our demo rooms.
The result is a well-balanced system that makes music sound articulate, dynamic, and full-bodied. Movies soundtracks are reproduced with authority and impact, giving a true theater experience. (Some of the movie soundtracks played in this system will downright scare the pants off ya!)
Whichever of the above subs meets your needs, you sure will be amazed!
JhnZ33 is offline
post #7 of 7 Old 05-17-2001, 12:53 PM
Liked: 54
Either the Platinum PowerSub ($2200 retail as of June 1st) or one or two Silver PowerSubs ($1250 retail) will work well with Gold LCRs, with room volume, output demands, taste, and sub location being some deciding factors. There is another alternative: The InRoom Gold PowerSub, which is very similar to the Silver, but it uses a slightly larger cabinet and a 15" version of the 12" in the Silver. There's a bit more headroom under 40 Hz, and about 2 dB more output (not trivial.) The Inroom Gold PowerSub retails for $1500.
Paul Scarpelli
jimmyk36 likes this.
Paul Scarpelli
aka TRIAD DUDE
Closed Thread Speakers
