Speaker wire ?...Does "oxygen free matter"? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 03-31-2008, 01:36 PM - Thread Starter
jmass03's Avatar
Monoprice is out of stock of the speaker wire I need until the 8th of April...just got my speakers in (It's a surprise, I'll post pics of them up once I have everything installed), and I'm itching tog et them hooked up. Thinking of just taking a trip out to Circuit city, but they have a reel of 50ft Nextech cord that is "oxygen free" 12 gauge for $40 dollars and then they have a non oxygen free, just regular 12 gauge for like $20 dollars. Difference? Does it matter? Is speaker wire, speaker wire in the end? Thanks!
Jonathan
jmass03 is offline
post #2 of 13 Old 03-31-2008, 01:52 PM
plnorris's Avatar
Don't even worry about oxygen free. Just make sure they're H2o free.
plnorris is offline
post #3 of 13 Old 03-31-2008, 01:58 PM
BuckoNZ's Avatar
Quoted: 28 Post(s)
The 'oxygen free' factor doesn't increase sound quality, however in theory it's supposed to reduce corrosion and it's the degradation of the actual copper itself, which reduces sound quality.
It's like preservatives in food. They don't add to the flavour, but maintain the quality of the food for consumption.
Personally, I go for the 'oxygen free'. My front speakers are currently running off Monster XPHP and the copper looks as good as it did the day I bought it... 14 years ago.
Television: LG SUPER UHD 4K TV 55'' [55UH850T] / Receiver: DENON AVR-X2300W / Blu-Ray Player: OPPO UDP-203
Main Speakers: KLIPSCH KG 2.5 / Centre Speaker: KLIPSCH KV 1
Surround Speakers (x4): CAMBRIDGE AUDIO Minx 22 / Sub-Woofer: ENERGY XL-S8
BuckoNZ is offline
post #4 of 13 Old 03-31-2008, 02:02 PM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 816
Most wire sold today is oxygen free even if it's not specifically stated. Even if the wire you buy isn't, given its intended use (room temperature and not elevated temperatures) you don't have to worry about hydrogen embrittlement. Google it up.
"I've found that when you want to know the truth about someone that someone is probably the last person you should ask." - Gregory House
Chu Gai is offline
post #5 of 13 Old 03-31-2008, 02:29 PM
BloggingITGuy's Avatar
I would suggest getting wire from Bluejeanscable.com That's good quality cable and cut to the specific lengths you need.
BloggingITGuy is offline
post #6 of 13 Old 03-31-2008, 02:34 PM
PR Audio's Avatar
Where do you live? Right next to the beach? What Buck says is true, O2 Free is a corrosion resistance issue, nothing else. Your speakers are inside the house, not outdoors, where your system is located is probably a element tight area. So, the standard speaker wire will probably last 15-20 years. Can you live with 15+ years for the cables? If so, go and buy the regular 12 gauge from CC. Enjoy your system.
PR Audio is offline
post #7 of 13 Old 03-31-2008, 02:41 PM
fedders's Avatar
Jonathan
Define oxygen free for me. You will never get 100% oxygen free. I know Coleman only uses 99.97% oxygen-free copper feedstock for everything we make. Is that oxygen free? Do you mean 99.9997% oxygen free? Don't forget that oxygen is not the only impurity to worry about in copper...
Who knows what the importers (like mono) use. Actually, I wouldn't even trust them if they said it was oxy-free anyway. I wouldn't trust the Circuit City product either. Either way, you will not hear a difference. Use the least expensive cable you can find from a reputable manufacturer and you will be fine.
Carl
Carl Fedders
fedders is offline
post #8 of 13 Old 03-31-2008, 03:06 PM
PR Audio's Avatar
Carl
You are getting too technical with the 99.97% O2 Free...Don't confuse the OP any further. All O2 Free cable will say 99.997% or similar; don't know any 100% free, but it was obvious what the OP wanted.
And, I agree with using the least expensive cable 12 Ga., preferably USA Made you can find. I don't know if you have a local electronics shop nearby that caters to schools, church, choirs, bands, car audio, etc. Maybe a local music store. At my local mom & pop music/electronics store I buy 12 Ga. 2 Wire (12/2) Made in the USA cable for $0.30/ft. Went up, as 4 months ago was $0.25/ft. They also carry Made in China for $0.15/ft. Don't know the brand, but when I get home will check.
PR Audio is offline
post #9 of 13 Old 03-31-2008, 03:55 PM
fedders's Avatar
Too technical? I re-read my post and I'm not sure what you mean. Unfortunately, there is a lot of marketing hype out there that does tend to confuse the average joe consumer. And I was serious about the 99.97% oxygen free. If someone does not print the oxygen-free percent right on the cable, it is useless marketing (what is the point of calling it oxygen free?).
Carl
Carl Fedders
fedders is offline
post #10 of 13 Old 03-31-2008, 04:18 PM
PR Audio's Avatar
What I mean is that no cable is 100% O2 free. But, by saying that it is only 99.997% O2 Free you are getting too technical about it, as it is only .003% less than 100%.
It is my understanding that all manufacturers print the percentage in the label. At least the ones I have seen.
PR Audio is offline
post #11 of 13 Old 03-22-2014, 02:45 PM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
I am bucking the convention and using 18guage wire for my surround speakers. Audiophile Jesus is gonna send me straight to
HELL!!
Blazar!
blazar is offline
post #12 of 13 Old 03-22-2014, 03:01 PM
Bill Fitzmaurice's Avatar
Liked: 4628
HELL!!
Bill Fitzmaurice is online now
post #13 of 13 Old 03-22-2014, 03:56 PM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
Originally Posted by Bill Fitzmaurice View Post
Hmm this is news to me... I'll contact Elon Musk and have SpaceX park them in earth orbit for a couple of months on the dark side of the earth.
Blazar!
blazar is offline
Reply Speakers
