Which is better? Coaxial or optical digital connection? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 05-16-2001, 02:26 PM - Thread Starter
Farid Muakkassa's Avatar
This may have been answered before. I need to connect a Pioneer Elite DV-37 to a Denon AVR 5800. Whic gives better audio quality,a coaxial or an optical digital connection?
Thanks for the response
Farid
Farid Muakkassa is offline
post #2 of 13 Old 05-16-2001, 03:17 PM
hhord2's Avatar
I've heard that it doesn't matter because it is a digital signal, but more people favor coax.
"Savor the Moment"
hhord2 is offline
post #3 of 13 Old 05-16-2001, 03:31 PM
Joel White's Avatar
I have personally not been able to see a difference. However, digital coax cables are usually less expensive than optical. I've also heard that optical are more susceptible to damage from bending.
Joel White
Editor CheapHomeTheater.com
Joel White
Joel White is offline
post #4 of 13 Old 05-16-2001, 03:31 PM
migliore's Avatar
migliore is offline
post #5 of 13 Old 05-17-2001, 10:31 AM
Will Binegar's Avatar
Liked: 29
It seems that most folks go with coax, given the choice. My CD player manual lists Coax as preferable to Toslink.
The one advantage of an optical connection is that since the connection isn't electrical, there aren't any grounding problems. So if you get a hum problem when connecting two components (probably because they are plugged into different electrical circuits), an optical connection between the two may be the solution. Toslink though is the "cheapest" implementation of an optical link. ATT glass is a better optical link, but the most products don't include that option.
Will Binegar is offline
post #6 of 13 Old 05-17-2001, 02:05 PM
Jerry Pease's Avatar
Originally posted by jaybird100:
The coaxial method can handle more bandwidth than optical, according to one wire manufacturer I know.
I think the cable manufacturers looking to sell more cable. Why all the telecom companies are changing from copper to fiber links? Bandwidth
I would say I have tried this comparison myself. I must admit I can hear a difference. I choose Coax.
JP
Jerry Pease is offline
post #7 of 13 Old 05-17-2001, 04:54 PM - Thread Starter
Thanks for all who replied to my question.
I am convinced now that coaxial is the way to go.
Farid
post #8 of 13 Old 05-17-2001, 06:24 PM
Buzz Goddard's Avatar
Jerry, thanks for proving my point. While fiber optics are great for very long runs, such as used by telcom's, short runs such as we use in our home theater systems benefit more from the coaxial cables. I tried both with my DVD player into my Denon AVR-
3300 receiver, and there was no comparison.
The theoretical acceptable distances for S/PDIF is longer on coax then on optical.
Buzz Goddard
TAG Mclaren Audio
Buzz Goddard
GoddardGroup
Buzz Goddard is offline
post #9 of 13 Old 05-17-2001, 07:15 PM
Thanks Buzz
JP
post #10 of 13 Old 05-17-2001, 11:59 PM
Timwit's Avatar
Why is it called coaxial when it has the same old RCA connecter?
I use coax for the link between my Panasonic H1000 and Denon AVR-5800 because I've heard the technophiles prefer this. But one of the manuals (I can't remember which) said if you have the choice use Toslink.
Why the recommendation for Toslink?
-Tim
Remember to e-mail ESPN, Fox Sports Net and Discovery Channel often, requesting HDTV.
Click here to e-mail ESPN
Click here to e-mail Fox Sports
Click here to e-mail Discovery Channel
Timwit is offline
post #11 of 13 Old 05-18-2001, 06:57 PM
Wireless's Avatar
Help me again with this. If a digital signal is either a 1 or a 0, the signal gets to the DAC with proper timing, how could there be a difference?
John
Wireless is offline
post #12 of 13 Old 05-18-2001, 09:00 PM
migliore's Avatar
Coax SPDIF has a higher theorhetical bandwidth than toslink.
Rob
Migliore Theater
migliore is offline
post #13 of 13 Old 05-18-2001, 09:36 PM
John Kotches's Avatar
Jerry et al,
ATT Glass fibre can carry higher bandwidth. IMO, that's the overall best solution out there. Now, how many consumer products use ATT Glass Fibre? Not many.
TOSLink uses plastic fibre, not Glass, and the connectors are cheesy. It's a shame really, because it has the potential of being superior to coax, but just doesn't deliver.
Contributing Writer,
Secrets of Home Theater and High Fidelity
Contributing Editor & Surround Music Reviewer Widescreen Review
Opinions are mine, not the publication I write for.
John Kotches is offline
Closed Thread Speakers
