New to this please help with speaker wire thank you - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 05-20-2008, 08:20 PM - Thread Starter
skiguy1981's Avatar
Ok I would like to buy some 12-14 gauge speaker wire is there a difference between this Belden 5000 http://www.bluejeanscable.com/store/speaker/index.htm
and
the wire from mono price is about $25 cheaper...
any help would be great and like I said I am new to this thank you
Oh I am running Polk RTI10's and and CSI A4
skiguy1981 is offline
post #2 of 14 Old 05-20-2008, 08:26 PM
jacksong314's Avatar
Buy the wire from monoprice. Buy yourself a case of good beer with the money you save.
jacksong314 is offline
post #3 of 14 Old 05-20-2008, 08:30 PM - Thread Starter
skiguy1981's Avatar
thanks
post #4 of 14 Old 05-20-2008, 08:33 PM
SnkEyez95's Avatar
Just spend more...You'll think you got superior stuff.
SnkEyez95 is offline
post #5 of 14 Old 05-20-2008, 10:41 PM
Veda's Avatar
Quoted: 124 Post(s)
Liked: 89
Now now be nice to newcomers...
Veda is offline
post #6 of 14 Old 05-20-2008, 10:43 PM
Veda's Avatar
Quoted: 124 Post(s)
Liked: 89
What you need to know when it comes to wires are to run them as short as possible and use 10-12 gauge wires. The only reason to spend extra on the same gauge wire is to ensure they have good enough insulation against oxidation which can be a major problem in some tropical areas.
Veda is offline
post #7 of 14 Old 05-20-2008, 10:56 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
IS true, though.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #8 of 14 Old 06-12-2008, 12:50 PM
RickRock's Avatar
do anyone make good inexpensive premade cables with banana plugs?
RickRock is offline
post #9 of 14 Old 06-13-2008, 06:21 AM
m_vanmeter's Avatar
the on-line reference for speaker wire
http://www.roger-russell.com/wire/wire.htm
an interesting read about Mr. Russell
m_vanmeter is offline
post #10 of 14 Old 06-13-2008, 09:16 AM
daigo's Avatar
I just made my own speaker wires for the first time with monoprice 12 AWG wire and a bunch of their closed type banana plugs following an on-line guide I found after googling for 'how to use closed type banana plugs'. You really only need a wire cutter and a utility knife to get it done.
daigo is offline
post #11 of 14 Old 06-13-2008, 09:59 AM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
http://www.impactacoustics.com/produ...3102&sku=29176
That's about the cheapest I know of. Still not that cheap considering how much it costs to make your own.
HERE are some good banana plugs that are very easy to attach. See the instructions on that page. 20-pack is available, too.
post #12 of 14 Old 06-13-2008, 10:29 AM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
http://www.skycraftsurplus.com/index...ROD&ProdID=764
post #13 of 14 Old 06-14-2008, 11:29 AM
m_vanmeter's Avatar
"sivadselin"
is that the correct link ? connectors shown are "pin" connectors, not bananas
post #14 of 14 Old 06-14-2008, 12:03 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Originally Posted by m_vanmeter View Post
"sivadselin"
Yeah, I know. I just happened to stumble upon them. They didn't offer banana-terminated. The price was right, so I posted the link. Pins can still be used, especially at the speaker end, but can be tougher (if not impossible) with a receiver's binding posts.
Reply Speakers
