Suggestions for center channel and receiver based on the setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 06-17-2008, 11:19 PM
H(A&T)'s Avatar
Currently I am planning to use 6 Martin Logan Montages, for front left-right, sides and back speakers.
I will using this setup for movies 90% of the time. My room size is 16' wide x 21' length x 8' high.
So my questions are:
1. Is this a good setup for a watching movies?
2. What is a good center channel speaker that would complement these Montages?
I was looking into the ML Vignette (a good fit for my budget) or ML fresco (a little tough on my budget, but I could work it out if its a good match).
The Montages have impedance of 5 ohms. Vignette's impedance is 6 ohms and Fresco has an impedance of 5 ohms
3. What might be a good receiver for handling these speakers?
My main concern is will the receiver be able to handle if I choose to combine the montages with vignette, which have different impedance.
4. Also since the impedance is 5 ohms will the receiver get over heated?
FYI: I don't what impedance is but one of the sale's rep at bestbuy said that I can't use speakers with different ohms.
I am new to all this, so please excuse me for any inaccurate comments and consider them to be naive.
Really appreciate any comments / input / suggestions.
Thank you.
H(A&T) is offline
post #2 of 12 Old 06-17-2008, 11:45 PM
SleeperSupra's Avatar
I would look for a deal on a pre-owned ML Fresco on Audiogon, I have seen several mint ones go in the $500 range.
I would also look at a separate dedicated high current low impedance drive capable multichannel amplifier to drive all the speakers. I just don't think a receiver will be able to drive your setup to you liking...
SleeperSupra is offline
post #3 of 12 Old 06-17-2008, 11:49 PM
H(A&T)'s Avatar
Originally Posted by SleeperSupra View Post
I would look for a deal on a pre-owned ML Fresco on Audiogon.
Thanks for the suggestion. I will definitely look at it.
So you think I should use a amp in conjunction with the receiver? And if so, could you recommend me a good amp.
H(A&T) is offline
post #4 of 12 Old 06-17-2008, 11:53 PM
I would at least drive the front three channels with a seperate amplifier.
What's your price range?
post #5 of 12 Old 06-17-2008, 11:59 PM
H(A&T)'s Avatar
Well, I was looking into the denon avr 3805, 3808 or 2808 receivers. If you think none of these receivers can do the job, a amp that would nicely complement these is what I am looking for.
Price range is around $300-500
H(A&T) is offline
post #6 of 12 Old 06-18-2008, 12:08 AM
Adcom GFA 7000, 5 channel x 130W (8 ohm) or 5 x 200W (4 ohm) THX Certified amplifier.
ATI 1505, 5 x 150W (8 ohm) and I think it is 5 x 250 (4 ohm).
B&K AV 5000 ll, 105W x 5 (8 ohm) and I think it is 5 x170 (4 ohm).
All can be found pre-owned for around $500 - $700 on Audiogon.
I think the ATI would be the best choice but it will be closer to the $700 mark...
post #7 of 12 Old 06-18-2008, 12:13 AM
H(A&T)'s Avatar
Adcom GFA 7000, 5 channel x 130W (8 ohm) or 5 x 200W (4 ohm) THX Certified amplifier. Can be found for around $500 pre-owned on Audiogon.
B&K AV 5000 ll, 105W x 5 (8 ohm) and I think it is 5 x180 (4 ohm).
All can be found pre-owned for under $650. I think the ATI would be the best choice...
I was just looking up fresco and some other stuff on audiogon, a great website, for some awesome deals.
Thank you for these quick replies.
H(A&T) is offline
post #8 of 12 Old 06-18-2008, 12:18 AM
Yikes!!!
There is a VERY nice Parasound HCA-855a and Lexicon DC-1 v 2.10 on Audiogon now for only $385.00 obo. They were over $5,000 a few years ago...
Blow off the Denon. This stuff is the real deal...
This equipment is true high end gear. You will be very happy.
Just my .02c
http://www.parasound.com/vintage/hca855a.php
post #9 of 12 Old 06-18-2008, 12:20 AM
I pretty much buy most of my equipment off that site.
GREAT DEALS!!!
post #10 of 12 Old 06-18-2008, 12:24 AM
Whoops...
I misread the post.
Sorry.
"Get the pair for $675 plus shipping plus paypal 3%.
Individually:
Parasound Amp - $385
Lexicon DC-1 - $350"
Still a good deal...
post #11 of 12 Old 06-18-2008, 12:27 AM
Lots of options out there.
Good luck.
post #12 of 12 Old 06-18-2008, 07:52 AM
H(A&T)'s Avatar
realizing that the Montages require a lot of power, I am looking into Monitor audio Rs6 and Rs8 speakers. Because buying a receiver and an amp will put me over the budget.
Do you guys think, RS8 for left - right, RS6 for rear, RSClr for center and the FX for sides (being 6 ohms) require less power than the 6 montages that was planning to use and I can just buy a denon 2808 receiver to run them?
Also how do the RS8's compare with the Montages?
Thank you
H(A&T) is offline
Reply Speakers
