Upgrading fronts and center, suggestions needed/welcomed - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-14-2008, 11:18 AM - Thread Starter
ramzy's Avatar
I recently bought a house and have some breathing room in regards to audio. I am currently using a 6.1 set up with the Onkyo 805 as my receiver. I have M&K LCR 45s as my fronts and center. I have 2 M&K K-4s for the surrounds and an older Polk center as my rear center. I am also using a Definitive 10" as a sub.
I would like to replace the rear Polk center with the LCR 45s for a 7.1 set-up after purchasing the front speakers.
I am looking to spend no more than $1300, but will spend more if there is a compelling reason.
I am thinking of buying the Definitive Mythos 7 way for a center, and Mirage
4 1/2 as my fronts.
I realize mixing and matching is not the way to do it, but I must make due with what I have. I want a more dynamic audio experience with better voice reproduction, and I love hearing details. Any suggestions/opinions are welcome.
ramzy is offline
post #2 of 5 Old 07-14-2008, 11:21 AM
lwien's Avatar
Can you take a shot of your current set-up and post it here?
There "may" be something going on with your set-up that "could" negate the need to replace your speakers.
lwien is offline
post #3 of 5 Old 07-14-2008, 11:30 AM
sivadselim's Avatar
Quoted: 74 Post(s)
Liked: 95
Originally Posted by ramzy View Post
I am thinking of buying the Definitive Mythos 7 way for a center, and Mirage 4 1/2 as my fronts.
What is a "Mythos 7 way" and a "Mirage 4 1/2"?
If you have to mix brands, but plan to replace all 3 speakers of your front array, why wouldn't you at the very least try and match those 3 front speakers?
I would try to figure out what is not working well with your current perfectly matching front speakers, buy a lower cost pair of speakers to use as the side or rear surrounds (mixing brands not really such an issue with surrounds), and consider replacing your subwoofer. My $0.02.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #4 of 5 Old 07-14-2008, 11:35 AM - Thread Starter
ramzy's Avatar
At this point I cannot, since I have not moved in yet. I was judging my experience based upon my the sound in my apartment, which will have a very similar set up to where I am moving too. I'm do not pretend to be an expert, but I know some of the basics such as speaker angle, height, distance, etc.
If its not worth my time or money to upgrade, that would make the wife happy
ramzy is offline
post #5 of 5 Old 07-14-2008, 11:40 AM - Thread Starter
ramzy's Avatar
This the Definitive center
http://www.bestbuy.com/site/olspage....=1151658129611
Here are the fronts
http://www.bestbuy.com/site/olspage....=1153337017137
The reason I mixed on the fronts is the wife. Unfortunately, form factor can be an issue, and she wants some kind of piano finish. The Mirage seemed to be the best value I could find while fitting both our needs.
ramzy is offline
Reply Speakers
