killed my def tech studio monitor 450 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-20-2008, 06:23 PM - Thread Starter
jafo9's Avatar
well i fried my mid/low on my def tech studio monitor 450 watching Apollo 13 in HD DVD on my Denon 3808CI. I was a +17.5 on the volume control. I had the fronts set to small with the bass sent to a supercube I and a 2002 CLR center. the right main started smelling like smoke and the sound went bad. the mid is the most obvious dead part. can i replace this? i've pulled it and googled the part number on it with no results. thanks.
jafo9 is offline
post #2 of 5 Old 07-20-2008, 07:38 PM
Montekay's Avatar
Quoted: 28 Post(s)
Liked: 31
You probably need to contact the manufacturer on this one. If it were a sealed box you could probably just get any cheap 6 1/2" driver from PE or Madisound and get away with it but reading about this speaker it appears to have a side mounted 10" passive radiator. The tuning of this is more critical than a basic sealed system especially in such a small box. If you do choose to just get a replacement driver that fits then pay particular attention to the value of Qt, you're going to want something with a low value here probably 0.3 or lower.
If you want to continue listening at such high levels the best bet might be to just get them playing again with the cheapest workable driver you can find and then sell them so you can replace them with something capable of higher output without damage. Get something with multiple drivers...to share the current load on the coils. Also, get a bigger amplifier, you probably killed them with clipping.
Monte
Montekay is offline
post #3 of 5 Old 02-10-2013, 02:05 PM
Chazspaz's Avatar
If you are going to scrap your speaker, could I buy the binding posts from you?
Chazspaz is offline
post #4 of 5 Old 02-10-2013, 02:10 PM
UofAZ1's Avatar
Quoted: 50 Post(s)
Liked: 75
Contact Chet at Definitive and more than likely he will send you a replacement at little to no cost. DT is very good at taking care of their customer and switching out a speaker is very easy.
UofAZ1 is offline
post #5 of 5 Old 02-10-2013, 02:18 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
Guys. This a 4 1/2 year old thread you are jumpstarting. Let it stay dead. LOL
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
Reply Speakers
