uni-polar vs. bipolar (or dipolar) surrounds - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-13-2008, 10:29 AM - Thread Starter
gibroni's Avatar
Quoted: 20 Post(s)
Which do you guys prefer, a standard profile speaker for surrounds or one of the surround style speakers with drivers facing in two directions? Just looking for opinions and discussion.
gibroni is offline
post #2 of 5 Old 09-13-2008, 06:54 PM
Montekay's Avatar
Quoted: 28 Post(s)
Liked: 31
Try doing a few searches on this topic. There are probably more opinions than people here regarding this.
Generally it depends on whether you want the surround sound to be very ambient seeming to come from all around or you want it to be more localized coming from the speaker location.
mk
Montekay is offline
post #3 of 5 Old 09-13-2008, 07:59 PM
Paul Scarpelli's Avatar
Liked: 53
I've posted my opinion on this a half dozen times, so ignore it if you have deja vu...
The smaller the room; the deader the room; and the more seats you have, the better dipoles tend to work. They have their own set of problems, but they don't "hot spot" and the surround field will be more uniform. If the room is larger, has live acoustics, and you don't have seating for twelve, direct-radiating works better. In a perfect world, you would have seven identical speakers all equidistant from the single seating area in a damped, acoustically-treated room.
The room, acoustics, and seating arrangements should determine what's best. Direct-radiating is best in theory, but if you find yourself sitting on a seat at the side with a direct-radiating speaker two feet from your head, the effect will be annoying. In that case, a dipole (with all it's inherent problems) may still be better.
Paul Scarpelli
aka TRIAD DUDE
I can tell people who are judgmental just by looking at them...
Paul Scarpelli is offline
post #4 of 5 Old 09-13-2008, 08:55 PM
craig john's Avatar
Quoted: 512 Post(s)
Liked: 716
To elaborate on what Paul and Monte have said, the differences between these speaker designs is related to their sound radiation patterns. Their usefulness in any given application depends on the priorities related to that application.
Monopoles radiate sound in one direction only; forward, in the direction they are facing. The coverage area will be determined by the width of their dispersion pattern in the frontal plane. Monopoles are very "directional", IOW, it's easy for the ear to tell where the sound is coming from.
Bipoles radiate sound in two planes and the output of both planes is in-phase, IOW, the drivers move out and in at the same time. With surround speakers, bipoles are usually designed with the drivers mounted at ~45 degree angles to the wall. The in-phase propagation gives a localizable nature to the sound and bipoles usually have a very broad coverage area. However, they also have significant reflected sound from the front and rear walls, so they can add a sense of ambiance.
Dipoles are similar to bipoles in that they are usually designed with the drivers at 45 or greater angles to the wall. The difference is that dipoles fire the opposing drivers out-of-phase; IOW, when one driver is moving out, the opposing driver is moving in, and vice-versa. This causes an area of cancellation immediately in front of the speaker. This is referred to as a "null" in the forward plane. The only thing the listener hears is the indirect sound of the reflections off the front an back walls.
Soooo... which do you pick for your surround sound system??? The choice comes down to what type of listening you do the most.
If you listen to a lot of discrete multi-channel sources, (i.e., 5.1, 6.1 or 7.1 discrete movies on Blu-Ray, DVD-A, or SACD multi-channel audio), the the "ambiance" is mixed into the discrete signals and you want speakers that will reproduce the recorded ambiance without adding additional ambiance of their own: monoples.
If you listen to a lot of stereo music or older stereo movies and you add multi-channel processing to it, (i.e., Dolby PLIIx Movies/Music, Neo-6 Movies/Music, etc.), then you want a very diffuse sound field: dipoles.
If you want some of each, (directionality and diffusion), then you want a speaker that can be directional when needed and diffuse when needed: bipoles.
Personally, I have side surround speakers that can be configured as either bipoles or dipoles. I have them configured as bipoles and I never change them. I like the directionality when called for. Otherwise, I rarely notice the surrounds at all, (i.e., they are adding "ambiance" which should never be noticed as "discrete" sound.) My rear surrounds are monopoles, which provide all the directionality I need for the limited amount of 7.1 material that is out there.
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #5 of 5 Old 09-13-2008, 09:25 PM
floridapoolboy's Avatar
I can't get over the term "uni-polar"!
floridapoolboy is offline
Reply Speakers
