Polk Audio TSi300....Other choice? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-13-2008, 12:15 PM - Thread Starter
french_guy's Avatar
Quoted: 14 Post(s)
Hello
I listened the TSi300, and found them great...Is there any other choice, cheaper? Or is there any good deal for the TSi300?
french_guy is offline
post #2 of 10 Old 09-13-2008, 12:30 PM
Erik Tracy's Avatar
Originally Posted by french_guy View Post
Hello
What's your price range?
Erik Tracy is offline
post #3 of 10 Old 09-13-2008, 01:24 PM - Thread Starter
french_guy's Avatar
Quoted: 14 Post(s)
TSi300 are $200 each...so cheaper!!!!
post #4 of 10 Old 09-13-2008, 02:58 PM
Erik Tracy's Avatar
You could bid on some RTI10s at Polk ebay's site for $207 for the pair.
Or RTI8s for $139 for the pair.
just stirring the pot....
post #5 of 10 Old 09-14-2008, 07:42 AM - Thread Starter
french_guy's Avatar
Quoted: 14 Post(s)
Are those supposed to be better than the Monitor 50?
post #6 of 10 Old 09-14-2008, 10:12 AM
Erik Tracy's Avatar
The RTi line is definitely a 'step up' in the Polk line of speakers.
Think BMW 328i then step up to the 528i.
Erik
post #7 of 10 Old 09-14-2008, 11:33 AM - Thread Starter
french_guy's Avatar
Quoted: 14 Post(s)
I went to Best Buy this morning (Magnolia) and told the guy i was looking for some floorstanding speaker, cheap and thin.
He immediately proposed me the Mirage Omnisat V2 FS (they are on sale at @300 each)
But I wasn't able to compare them with the TSi300...So it's hard to tell!! I wasn't impressed with the center, but the 2 main speakers sounded good...
how would you compare those speakers with the PolkAudio you mentioned?
thansk
post #8 of 10 Old 09-14-2008, 12:03 PM
Erik Tracy's Avatar
thansk
I have no sonic experience with the Mirage speakers....best advice is to go with what you like and what you think sounds best!
Enjoy the journey!
post #9 of 10 Old 09-14-2008, 12:57 PM - Thread Starter
french_guy's Avatar
Quoted: 14 Post(s)
I think my only option is to check at the return policy for each store, and then conduct my own trials at home!!!
post #10 of 10 Old 09-14-2008, 01:04 PM
tdogroeder's Avatar
Quoted: 41 Post(s)
Liked: 81
That is the best way to find out which set you will like best. Good luck with your trial!
John 14:6 & John 3:16
Yamaha RXV765 & Emotiva LPA-1
Ascend Sierra-2s(LCR), RSS300, Polk R15, SVS PB12 plus
Panasonic S65, Sony S5100, PS4, PS3, XBOX 360
tdogroeder is offline
Reply Speakers
