What can I get for $700 - 2.0 or 5.0 - AVS Forum | Home Theater Discussions And Reviews
Old 09-24-2008, 07:01 PM - Thread Starter
rAInMo9's Avatar
Hey everyone,
I am looking to build up my first HT/Music system (70/30 maybe), and have a budget of $700. I also have a MFW-15 as a subwoofer; will probably be buying a Denon 888 or Onkyo 606 for the receiver, and a PS3 for the source. My question is, should I go 2.1 or 5.1? Also, I need to use bipoles/dipoles for the rear if I go 5.1. So at this pricepoint, do you guys think 2.1 or 5.1 is better? Is it worth it to lose quality on the mains to get the center and surrounds, or is it better to get some good quality mains? Any suggestions for either setup? Thanks.
I guess 3.1 is also a viable option, so feel free to recommend any of those too.
Oh yeah, my room is 15ft x 12ft x 8ft (speakers and seating are along the 15ft sides), so maybe I won't notice the lack of surrounds as much because the fronts will already fill the room nicely?
Here is a list of qualities I hope to get from the fronts:
Wide sweet spot
Large soundstage (both depth and width)
Good attack on instruments
Good attack & articulation of voices
Good imaging & separation of instruments/voices
Good response/decay times; i.e., I want to hear every note in a string of drum notes; I don’t want to hear all the notes slurred together
Punchy & tight bass
Dynamics (how loud they can get without breaking up, how soft they can get while keeping the whole sonic experience intact and w/o losing detail, how well they jump from something really soft to a passage really loud)
Intelligibility of voices (i.e. in movies and vocals)
By the way, if I go 2.1, will I still be able to get the sonic advantages of Dolby TrueHD and DTS-MA? I will still be able to select them, it's just that they will be downmixed to 2.1, right?
rAInMo9 is offline
Old 09-24-2008, 09:56 PM
Nuance's Avatar
Quoted: 21 Post(s)
Liked: 77
I say go with 2.1 and start with a real solid pair of fronts. Then just build around them when you have the available funds. A very solid 2.1 system will sound much nicer than an average 5.1 IMO.
I don't think you'll be able to run Dolby HD or DTS-MA since you won't have a full 5.1 or 7.1 system.
My journey to find the "perfect" speaker
No matter what measurements tell us, a loudspeaker isn’t good until it
sounds good. - Dr. Floyd Toole
Nuance is offline
Old 09-25-2008, 12:49 AM
ExAnim8r's Avatar
You'll be able to run TrueHD/DTS-MA just fine, the extra channels will just be mixed into the stereo channels by the receiver.
-Ex
ExAnim8r is offline
Old 09-25-2008, 04:22 AM
gunbunnysoulja's Avatar
I also agree to get a pair of mains with that budget. Many options that offer excellent sound quality.
If you have the capability to gradually integrate the other speakers in the near future, this is the route you want to take.
gunbunnysoulja is offline
Old 09-25-2008, 08:21 AM
Nuance's Avatar
Quoted: 21 Post(s)
Liked: 77
-Ex
Good to know, though it doesn't work on my Onkyo 805. Of course, I only have a 2.1 system right now.
Nuance is offline
Old 09-25-2008, 08:53 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
You've got the punchy and tight bass covered with your subwoofer. You may be able to get 2 fronts and a center for your $700. Check out these speakers.
http://www.ascendacoustics.com/pages...c/cmt340c.html
http://www.ascendacoustics.com/pages...m/cmt340m.html
The are running discounts now so you can get the 3 speaker package for $738.
Or if you can wait a while, the Rocket 450 tower for $699/pr shipped.
http://**********/component/page,shop...art/Itemid,37/
Afro GT
afrogt is offline
