Paradigm Studio 100 v4 with CC-590 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-04-2008, 07:35 PM - Thread Starter
xtreme777's Avatar
Hello all,
I have a set of Paradigm Studio 100s with CC-590 which I bought last week.
Now, after a closer look at the specs... (i wish i did that sooner) I realized that CC-590 has way less power than 100s. It seems like 100s should go with CC-690, which are huge...
I would appreciate your input here. Heeelp!
BR,
xtreme777
xtreme777 is offline
post #2 of 5 Old 10-04-2008, 08:00 PM
PSBMAN's Avatar
Don't read too much into the spec's. Your 590 will be fine. Make sure your level's match.
If Jack Bauer were gay, he would be Chuck Norris
PSBMAN is offline
post #3 of 5 Old 10-04-2008, 08:05 PM - Thread Starter
xtreme777's Avatar
Please excuse my ignorance, but what levels are you talking about? EQ?
BR,
xtreme777
post #4 of 5 Old 10-04-2008, 08:49 PM
Warpdrv's Avatar
Using a SPL Meter, enter the setup of your receiver and either manually adjust the output of each speaker to the same level on the meter. Some receivers have an auto setup (like Audessey), but I prefer to manually adjust, with my particular equipment.
Warpdrv is offline
post #5 of 5 Old 10-05-2008, 01:19 PM
jakewash's Avatar
It is not the speaker that has the power it is the amp and the amp doesn't really care what the speakers are capable of, chances are you will be listening to your system at about 1 watt to reach 85-90dbs(reasonbly loud like in a movie theater) with peaks reaching 105 dbs requiring about 50-100W depending on the amount of bass in the sound and how far away you will be and room size etc.. As long as the power reaching the speakers is clean, not clipped or distorted(which can happen with too small of an amp) the speakers will be fine.
The more important part is that the center match the sonic signature the mains have for pans from Left to Right.
jakewash is offline
Reply Speakers
