Need to make my wired speakers wireless - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-10-2008, 08:51 PM - Thread Starter
lopinc1's Avatar
I see products out there that take RCA inputs and transmit to a wireless receiver that can directly drive speakers, but I'm looking for something that takes the speaker output of my receiver (amp) and transmits that wirelessly...unless there is a way to turn amplified speaker output back to line level. The idea is not to have to buy a new reciever or speakers.
I need this for the rear speakers of my 5.1 setup as running wires back there would involve cutting and repairing holes in either my floor or ceiling. Thanks.
lopinc1 is offline
post #2 of 10 Old 10-11-2008, 08:19 AM
Kal Rubinson's Avatar
Quoted: 748 Post(s)
Liked: 518
There are a few devices that will take the RCA input to the transmitter and have a power amp in the receiver. I believe
Kenwood RFU-6100 would do this but it has had mediocre reviews. Also, there is a British unit but it is fairly pricey. Otherwise, any RCA in/out (line level) will do with an additional small amp.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #3 of 10 Old 10-11-2008, 08:34 AM
mackiefan's Avatar
KEF, I believe is the British product
mackiefan is offline
post #4 of 10 Old 10-11-2008, 08:56 AM - Thread Starter
lopinc1's Avatar
Thanks Kal, but as I stated in mu OP, I'm looking for something that transmits the speaker output of my reciever, not a RCA line output, I already knew about those. My reciever doesn't have RCA outputs for the seperate channels, just amplified outputs that go right into the speakers. thanks.
lopinc1 is offline
post #5 of 10 Old 10-11-2008, 10:03 AM
Liked: 62
Rocketfish?
http://www.bestbuy.com/site/olspage....=1171058476489
I've heard one and can't say I'd buy it, but it does work. There might be one or two others.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #6 of 10 Old 10-11-2008, 10:15 AM
Denophile's Avatar
i believe KEF makes one that may be the best bang for the buck.
http://www2.kef.com/us/technology/wireless
this is the one i would go with if I had to.
Denophile is offline
post #7 of 10 Old 10-11-2008, 10:43 AM - Thread Starter
lopinc1's Avatar
Originally Posted by Tulpa View Post
Rocketfish?
Bestbuy.. amazing.. always in the last place you look. thanks for your help.
lopinc1 is offline
post #8 of 10 Old 10-11-2008, 04:27 PM
Quoted: 748 Post(s)
Liked: 518
There are none. However, you can convert the speaker outputs to line-level with a simple adapter.
Kal Rubinson
post #9 of 10 Old 10-11-2008, 04:28 PM
Quoted: 748 Post(s)
Liked: 518
Not the one I was thinking of but that too. I was thinking of this: http://www.sonneteer.demon.co.uk/bard.htm
Kal Rubinson
post #10 of 10 Old 10-11-2008, 04:31 PM
Quoted: 748 Post(s)
Liked: 518
Oh, there's also the very neat AudioEngine AW-1.
http://www.stereophile.com/amplifica...tr/index1.html
Kal Rubinson
Reply Speakers
