NHT Classic vs. Definitive Technology Mythos - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-20-2008, 01:55 PM - Thread Starter
wadesi's Avatar
Hi Folks,
I'm trying to chose between two sets of speakers for my high traffic family room. Listening will be 90% TV/HT & 10% Music. The room is a "great room" setup so it's pretty big (20x40). Rear speakers are in ceiling polks, sub is a Klipsch 12". I'm trying to balance WAF vs performance vs price. Which of the below setups would you think I should lean towards? I'm all for the performance of the NHT's but the Def Techs look so good. All advice is appreciated!
Setup 1 - 2 Mythos One's for the L/R and a Mythos 3 for center. Total cost: $1100 (these will be gently used for less than one year)
Setup 2 - 2 NHT Classic Four for the L/R - Cost $1100 I will have to buy a Classic 3 center for another $450 to complete this setup. Total cost: $1550 (All these will be new in box)
I like good looking towers. If you can point me in the direction of any other speakers that will give me as good or better sound for a better price than the above feel free.
Cheers!
wadesi is offline
post #2 of 3 Old 10-21-2008, 12:32 PM - Thread Starter
wadesi's Avatar
I can't find any reviews on the Mythos One's. Does anyone know if these will stand up to the NHT Classics?
wadesi is offline
post #3 of 3 Old 10-21-2008, 01:06 PM
mark russ's Avatar
FWIW, here are the same set of objective measurements of the Fours and Threes as compared to the Mythos STs:
http://www.hometheatermag.com/floorl...ef/index2.html
http://www.hometheatermag.com/comple...ht/index2.html
mark russ is offline
Reply Speakers
